Part Number: LAUNCHXL-CC1310
For some reason CCS no longer shows debug console from my application.
I'm using System_printf with SysMin as usual, and loadti.sh works fine, giving expected debug information from my code.
If I pause CCS and check the SysMin module, it says the buffer is drained, since System_flush is being called regularly and appears to succeed.
If I check the buffer manually, it contains the expected text. The pointers indicate a successfully drained buffer.
I can't find any settings related to whether CCS chooses to pick up debug information from SysMin's System_flush, or any details on how specifically they communicate with each other.
Since everything works perfectly with loadti.sh, I suspect that the issue is within CCS somewhere.
Any ideas on what to check, or why this might be happening?
