GUI Composer
Expletives!!!!
What a confusing process to simply ask a question in the TI forum.
I am trying to ask a question about the GUI composer, which does not have a part number. It also appears this category/topic does not fit within the standard pidgeon holes/multitude of categories. So now what.
So apologies if I have ended up in the wrong forum.
I want to know how to debug in GUI composer as one widget works and another does not.
  • Gerriko,
    The Code Composer forum is the right place. In general if you are not sure just post in the forum for the device you are using and the forum moderators will take care of making sure it gets directed to the correct people.
    Can you provide some more info on what is going wrong?
    What device are you on?
    What communication channel to the device are you using, USB-UART, XDS, MQTT...?
    What HostOS are you on?
    What is your working widget connected to?
    What is your non-working widget connected to?
    If you connect the non-working widget to something else does it work?
    What do you mean by non working? Is it not displaying properly, is it not refreshing, is it not displaying the value you expect...
    John
  • Thanks for the helpful feedback John. I will post my query there.
