Other Parts Discussed in Thread: CONTROLSUITE, POWERSUITE
Dear Support Team,
we are trying to evaluate Vienna Rectifier based design based on www.ti.com/tool/TIDM-1000. We solved some issues yet, but the GUI will not load.
Let me sum up, what I did until now:
The PC is running Windows 7 64bit in German
.NET Framework 4.7 was already installed
installed Code Composter Studio 7.3.0.00019
fixed some proxy issues
installed GUI Composer Runtime 6.1.0.2 from the CCS App Center
installed controlSUITE 3.4.7 including powerSUITE 1.7.0.00
run F28377D Project from he TI Resource Explorer classic
main.cfg PowerSuite window stays blank
Code Composer Studio gave warnings, so i installed compiler 6.4.6 and XDCtools 3.31.00.24
-> no effect
according to https://e2e.ti.com/support/microcontrollers/c2000/f/171/t/600473:
- open with XGCONF -> no effect
- switched powerSUITE versions -> only 1.7.0.00 worked to run
- same results with different projects
- GUI Composer Test App is running
- chrome debugging gives error as follows:
Installing suggested updates an Eclipse GMF Framework didn't change the result
