Part Number: TMDX570LC43HDK
Good morning,
it is possible to debug two different board with two instance of CCS on the same computer, or otherwise is necessary a pc for every board?
Good morning,
I've tried to follow the first video,
in my configuration I've two TMDX570LC43HDK connect to the same CCSV7,
the output of xds100serial.exe is the following and seems that the serial number is the same for the two board.
I've to change something else in the board config or directly on the board??
Antonio
The Wiki entry Q: Can I change the serial number on my XDS100v2? has information on how to change the serial number in a XDS100v2, which should allow you to program a different serial number into each of your XDS100v2 emulators.Etantonio said:I've to change something else in the board config or directly on the board??
