Part Number: TMDSLCDK138
Other Parts Discussed in Thread: OMAPL138, SYSBIOS, TCI6638K2K, 66AK2H12, TCI6630K2L, 66AK2E05, 66AK2G02, AM5728, AM3359, AM4379, CCSTUDIO, AMIC110, MATHLIB
Windows- CCSv7.2 + XDCtools 3.32.2.25 + SYS/BIOS 6.51.0.15 + OMAPL138PDK 1.0.1 + processor_sdk_rtos_omapl138 4.00.00.04 + GPIO_LedBlink_lcdkOMAPL138_c674xTestProject
. - Building results of 10 errors as follows:
* \file gpio_test.cfg
* \brief Sysbios config file for GPIO test project on OMAPL138 LCDK.
* Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Load all required BIOS/XDC runtime packages */
var Memory = xdc.useModule('xdc.runtime.Memory');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var HeapBuf = xdc.useModule('ti.sysbios.heaps.HeapBuf');
var Log = xdc.useModule('xdc.runtime.Log');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.family.c64p.Hwi');
var ECM = xdc.useModule('ti.sysbios.family.c64p.EventCombiner');
var core = xdc.useModule('ti.sysbios.hal.Core');
var Cache = xdc.useModule ("ti.sysbios.hal.Cache");
var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup');
var Platform = xdc.useModule('ti.platforms.evmOMAPL138.Platform');
var devType = "omapl138"
/* Load the OSAL package */
var osType = "tirtos"
var Osal = xdc.useModule('ti.osal.Settings');
Osal.osType = osType;
Osal.socType = devType;
/*use CSL package*/
var Csl = xdc.loadPackage('ti.csl');
Csl.Settings.deviceType = devType;
/* Load the Board package and set the board name */
var Board = xdc.loadPackage('ti.board');
Board.Settings.boardName = "lcdkOMAPL138";
/* Load Profiling package */
/*var Utils = xdc.loadPackage('ti.utils.profiling');*/
/* Load the gpio package */
var Gpio = xdc.loadPackage('ti.drv.gpio');
Gpio.Settings.enableProfiling = false;
Gpio.Settings.socType = devType;
/* Load the uart package */
var Uart = xdc.useModule('ti.drv.uart.Settings');
Uart.socType = devType;
/* Load the I2C package - required by board */
var I2c = xdc.loadPackage('ti.drv.i2c');
I2c.Settings.socType = devType;
var System = xdc.useModule('xdc.runtime.System');
SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
/* Load and use the CSL packages */
var Csl = xdc.useModule('ti.csl.Settings');
Csl.deviceType = devType;
/* Create a default system heap using ti.bios.HeapMem. */
var heapMemParams1 = new HeapMem.Params;
heapMemParams1.size = 8192 * 25;
heapMemParams1.sectionName = "systemHeap";
Program.global.heap0 = HeapMem.create(heapMemParams1);
/* No runtime stack checking is performed */
Task.checkStackFlag = false;
/* Reduce the number of task priorities */
Task.numPriorities = 4;
/* ================ Task configuration ================ */
var task0Params = new Task.Params();
task0Params.instance.name = "echo";
task0Params.stackSize = 0x1000;
Program.global.echo = Task.create("&gpio_test", task0Params);
/* This is the default memory heap. */
Memory.defaultHeapInstance = Program.global.heap0;
Program.sectMap["systemHeap"] = Program.platform.stackMemory;
Program.sectMap[".fardata:benchmarking"] = "DDR";
/****** IPC - Shared Memory Settings ********/
/* IPC packages */
var memmap = Program.cpu.memoryMap;
/*Startup = xdc.useModule('xdc.runtime.Startup');
Startup.firstFxns.$add('&myStartupFxn');*/
/* Enable BIOS Task Scheduler */
BIOS.taskEnabled = true;
* Enable Event Groups here and registering of ISR for specific GEM INTC is done
* using EventCombiner_dispatchPlug() and Hwi_eventMap() APIs
var exception = xdc.useModule('ti.sysbios.family.c64p.Exception');
exception.enablePrint = true;
* @(#) ti.sysbios.genx; 2, 0, 0, 0,275; 4-29-2009 15:45:06; /db/vtree/library/trees/avala/avala-k25x/src/
/* Define and add one Task Hook Set */
/*Task.addHookSet({
registerFxn: '&TaskRegisterId',
switchFxn: '&mySwitch',
LoggingSetup.sysbiosSwiLogging = true;
LoggingSetup.sysbiosHwiLogging = true;
LoggingSetup.sysbiosSemaphoreLogging = true;
LoggingSetup.loadHwiLogging = true;
LoggingSetup.loadSwiLogging = true;
LoggingSetup.loadTaskLogging = true;
Itzhak Kroin
