Part Number: IWR1443BOOST
Other Parts Discussed in Thread: MMWAVE-SDK
I am trying to build 4k FFT demo in CCS7.3 on Linux ubantu 16.04. The mmwave sdk version is mmwave_sdk_01_00_00_05. Using resource manager, I am able to import the project and able to build.
But build is failing in post build steps and following error is displayed.
<Linking>
Finished building target: xwr14xx_4k_fft_lab_mss.xer4f
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe xwr14xx_4k_fft_lab_mss.xer4f xwr14xx_4k_fft_lab_mss.bin 0x200000
makefile:195: recipe for target 'post-build' failed
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 1: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: MZ����@���: not found
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 2: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: : not found
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 1: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: .rsrc�: not found
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 2: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: ~�X��BN�: not found
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 131: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: �-X�-o7: not found
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 132: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: {�r�p�: not found
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 132: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: o7: not found
/home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: 133: /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/out2rprc/out2rprc.exe: Syntax error: "(" unexpected
gmake[3]: [post-build] Error 2 (ignored)
gmake[3]: perl.exe: Command not found
gmake[3]: [post-build] Error 127 (ignored)
perl.exe /home/shailen/ti/mmwave_sdk_01_00_00_05/packages/scripts/ImageCreator/xwr14xx/append_bin_crc/gen_bincrc32.pl xwr14xx_4k_fft_lab_mss.bin
**** Build Finished ****
The post build setps are defined as follows.
${COM_TI_MMWAVE_SDK_INSTALL_DIR}/packages/scripts/ImageCreator/${MMWAVE_SDK_DEVICE}/out2rprc/out2rprc.exe ${MMWAVE_SDK_DEVICE}_${ProjName}_mss.xer4f ${MMWAVE_SDK_DEVICE}_${ProjName}_mss.bin ${LOAD_ADDRESS}
perl.exe ${COM_TI_MMWAVE_SDK_INSTALL_DIR}/packages/scripts/ImageCreator/${MMWAVE_SDK_DEVICE}/append_bin_crc/gen_bincrc32.pl ${MMWAVE_SDK_DEVICE}_${ProjName}_mss.bin
It looks like that I need to put proper post build steps in project settings. Can any one help to resolve this?
Shailendra
