Part Number: CCSTUDIO-WCS
I'm facing an issue where I cannot build projects in CCS. Yesterday I was able to build, flash, and debug. This morning I restarted my computer. After that, I couldn't build any of the projects. Originally I was using CCS 7.3, so I decided to install the newer CCS 7.4. However, that did not help. Below is the console output. I tried to do change Path variable per
, but it hasn't worked for me. What should I do to resolve this issue?
**** Build of configuration Debug for project tirtos_builds_CC1310_LAUNCHXL_release_ccs ****
"C:\\ti\\ccsv7\\utils\\bin\\gmake" -k -j 4 all -O
'Building file: "../release.cfg"'
'Invoking: XDCtools'
"C:/ti/xdctools_3_50_04_43_core/xs" --xdcpath="C:/ti/simplelink_cc13x0_sdk_1_60_00_21/source;C:/ti/simplelink_cc13x0_sdk_1_60_00_21/kernel/tirtos/packages;C:/ti/ccsv7/ccs_base;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M3 -p ti.platforms.simplelink:CC1310F128 -r release -c "C:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.6.LTS" --compileOptions " -DDeviceFamily_CC13X0 " "../release.cfg"
making package.mak (because of package.bld) ...
subdir_rules.mk:12: recipe for target 'build-1317695535-inproc' failed
1 [main] ? (7372) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x10B88E0/0x10688E0.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version. The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution. Rebooting is also suggested if you
are unable to find another cygwin DLL.
0 [main] ? (-6404) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x10B88E0/0x11A88E0.
0 [main] ? (-7252) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x10B88E0/0x10C88E0.
1 [main] ? (18188) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x10B88E0/0x10088E0.
1 [main] ? (-11932) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x10B88E0/0x11388E0.
1 [main] sh 4064 fork: child -1 - died waiting for longjmp before initialization, retry -1, exit code 0xC0000142, errno 11
C:/Users/a0232184/AppData/Local/Temp/make16552-1.sh: Cannot fork: Resource temporarily unavailable
0 [main] ? (-9796) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11588E0/0x11A88E0.
1 [main] ? (-12144) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0xF588E0.
1 [main] ? (1968) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0xFB88E0.
1 [main] ? (-5432) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0xFA88E0.
1 [main] ? (-2184) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0x10488E0.
0 [main] ? (14116) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0xFB88E0.
0 [main] ? (15616) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0x10288E0.
1 [main] ? (9580) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0x10188E0.
0 [main] ? (-7012) C:\ti\xdctools_3_50_04_43_core\bin\echo.exe: *** fatal error - cygheap base mismatch detected - 0xF788E0/0x10688E0.
0 [main] ? (-10928) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0x10488E0.
0 [main] ? (15132) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0xF288E0.
0 [main] ? (18232) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0xF388E0.
0 [main] ? (18040) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0xF488E0.
1 [main] ? (8008) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0xF188E0.
0 [main] ? (4748) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0xF488E0.
0 [main] ? (14720) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0xF788E0.
1 [main] ? (15172) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0xFD88E0/0xF688E0.
0 [main] sh 10696 fork: child -1 - died waiting for longjmp before initialization, retry -1, exit code 0xC0000142, errno 11
C:/Users/a0232184/AppData/Local/Temp/make7708-1.sh: Cannot fork: Resource temporarily unavailable
gmake.exe: *** No rule to make target `.configuro'. Stop.
js: "C:/ti/xdctools_3_50_04_43_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[1]: *** [build-1317695535-inproc] Error 1
0 [main] ? (17688) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11188E0/0x10588E0.
0 [main] ? (9612) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11188E0/0x11B88E0.
1 [main] ? (17396) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11188E0/0x10488E0.
1 [main] ? (10536) C:\ti\xdctools_3_50_04_43_core\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11188E0/0x10588E0.
1 [main] sh 6812 fork: child -1 - died waiting for longjmp before initialization, retry -1, exit code 0xC0000142, errno 11
C:/Users/a0232184/AppData/Local/Temp/make8904-1.sh: Cannot fork: Resource temporarily unavailable
C:/ti/xdctools_3_50_04_43_core/packages/xdc/bld/xdc_rules.mak:307: *** Error: Specified build configuration file '' is not found. Stop.
gmake[2]: *** [build-1317695535-inproc] Error 1
gmake[1]: *** No rule to make target 'build-1317695535', needed by 'configPkg/linker.cmd'.
gmake[1]: Target 'configPkg/linker.cmd' not remade because of errors.
makefile:127: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
