CCS/CCSTUDIO: problem with install
Part Number: CCSTUDIO
Hi
I uninstalled ccs and then tried to reinstall and I am getting an error message. I could not run the installed version because of error log so I decided to start from scratch and reinstall but now I am running into issues installing, the install is frozen
!SESSION 2018-01-19 09:25:20.930 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -application org.eclipse.equinox.p2.director -repository software-dl.ti.com/.../p2appfRepo -installiu com.ti.ccstudio.p2appf.feature.group
Command-line arguments: -os win32 -ws win32 -arch x86 -application org.eclipse.equinox.p2.director -repository software-dl.ti.com/.../p2appfRepo -installiu com.ti.ccstudio.p2appf.feature.group
!ENTRY org.eclipse.equinox.event 4 0 2018-01-19 09:25:21.352
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.event [76]
Unresolved requirement: Import-Package: org.osgi.service.event; version="[1.3.0,1.4.0)"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.cdt.build.crossgcc 4 0 2018-01-19 09:25:21.375
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.build.crossgcc [31]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
!ENTRY org.eclipse.cdt.build.gcc.core 4 0 2018-01-19 09:25:21.375
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.build.gcc.core [32]
!ENTRY org.eclipse.cdt.codan.checkers 4 0 2018-01-19 09:25:21.376
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.codan.checkers [33]
!ENTRY org.eclipse.cdt.codan.checkers.ui 4 0 2018-01-19 09:25:21.376
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.codan.checkers.ui [34]
Unresolved requirement: Require-Bundle: org.eclipse.core.resources
!ENTRY org.eclipse.cdt.codan.core 4 0 2018-01-19 09:25:21.376
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.codan.core [35]
!ENTRY org.eclipse.cdt.codan.core.cxx 4 0 2018-01-19 09:25:21.377
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.codan.core.cxx [36]
!ENTRY org.eclipse.cdt.codan.ui 4 0 2018-01-19 09:25:21.377
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.codan.ui [37]
Unresolved requirement: Require-Bundle: org.eclipse.cdt.core
Unresolved requirement: Require-Bundle: org.eclipse.cdt.codan.core
-> Bundle-SymbolicName: org.eclipse.cdt.codan.core; bundle-version="4.0.0.201606062011"; singleton:="true"
!ENTRY org.eclipse.cdt.codan.ui.cxx 4 0 2018-01-19 09:25:21.377
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.codan.ui.cxx [38]
Unresolved requirement: Require-Bundle: org.eclipse.ui
!ENTRY org.eclipse.cdt.debug.ui.memory.floatingpoint 4 0 2018-01-19 09:25:21.377
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.debug.ui.memory.floatingpoint [41]
Unresolved requirement: Require-Bundle: org.eclipse.debug.core; bundle-version="3.7.100"
!ENTRY org.eclipse.cdt.debug.ui.memory.search 4 0 2018-01-19 09:25:21.378
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.debug.ui.memory.search [42]
Unresolved requirement: Import-Package: org.eclipse.debug.ui.memory
!ENTRY org.eclipse.cdt.debug.ui.memory.transport 4 0 2018-01-19 09:25:21.378
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.debug.ui.memory.transport [43]
!ENTRY org.eclipse.cdt.doc.user 4 0 2018-01-19 09:25:21.378
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.doc.user [44]
Unresolved requirement: Require-Bundle: org.eclipse.help
!ENTRY org.eclipse.cdt.dsf.gdb.ui 4 0 2018-01-19 09:25:21.379
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.dsf.gdb.ui [45]
Unresolved requirement: Import-Package: com.ibm.icu.text
!ENTRY org.eclipse.cdt.gdb.ui 4 0 2018-01-19 09:25:21.379
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.gdb.ui [46]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="3.6.0"
!ENTRY org.eclipse.cdt.launch.remote 4 0 2018-01-19 09:25:21.379
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.launch.remote [47]
Unresolved requirement: Require-Bundle: org.eclipse.cdt.launch
!ENTRY org.eclipse.cdt.managedbuilder.gnu.ui 4 0 2018-01-19 09:25:21.379
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.cdt.managedbuilder.gnu.ui [48]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="[3.2.0,4.0.0)"
!ENTRY org.eclipse.compare.win32 4 0 2018-01-19 09:25:21.380
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.compare.win32 [50]
Unresolved requirement: Require-Bundle: org.eclipse.compare; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.core.externaltools 4 0 2018-01-19 09:25:21.380
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.core.externaltools [52]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.dstore.core 4 0 2018-01-19 09:25:21.380
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.dstore.core [56]
!ENTRY org.eclipse.dstore.extra 4 0 2018-01-19 09:25:21.381
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.dstore.extra [57]
!ENTRY org.eclipse.ecf 4 0 2018-01-19 09:25:21.381
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ecf [59]
Unresolved requirement: Import-Package: org.eclipse.core.runtime.jobs
!ENTRY org.eclipse.ecf.filetransfer 4 0 2018-01-19 09:25:21.381
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ecf.filetransfer [60]
!ENTRY org.eclipse.ecf.identity 4 0 2018-01-19 09:25:21.381
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ecf.identity [61]
Unresolved requirement: Require-Bundle: org.eclipse.equinox.common
!ENTRY org.eclipse.ecf.provider.filetransfer 4 0 2018-01-19 09:25:21.382
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ecf.provider.filetransfer [62]
Unresolved requirement: Import-Package: org.eclipse.core.net.proxy; resolution:="optional"
!ENTRY org.eclipse.ecf.provider.filetransfer.httpclient4 4 0 2018-01-19 09:25:21.383
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ecf.provider.filetransfer.httpclient4 [63]
Unresolved requirement: Import-Package: org.apache.http; version="4.1.0"
!ENTRY org.eclipse.egit.core 4 0 2018-01-19 09:25:21.383
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.core [68]
Unresolved requirement: Import-Package: org.eclipse.core.net.proxy; bundle-version="[1.1.0,2.0.0)"
!ENTRY org.eclipse.egit.doc 4 0 2018-01-19 09:25:21.383
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.doc [69]
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.core; bundle-version="[2.0.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.core.ant; bundle-version="[2.0.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.wikitext.mediawiki.core; bundle-version="[2.0.0,3.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.ui.cheatsheets; bundle-version="[3.3.0,4.0.0)"
!ENTRY org.eclipse.egit.ui 4 0 2018-01-19 09:25:21.384
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.egit.ui [70]
Unresolved requirement: Import-Package: org.eclipse.egit.core; version="[4.4.0,4.5.0)"
-> Export-Package: org.eclipse.egit.core; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.4.0.201606070830-r"; version="4.4.0"; x-friends:="org.eclipse.egit.ui, org.eclipse.egit.ui.test, org.eclipse.egit.mylyn.ui, org.eclipse.egit.gitflow.test, org.eclipse.egit.gitflow.ui"
Unresolved requirement: Import-Package: org.eclipse.egit.core.internal; version="[4.4.0,4.5.0)"
-> Export-Package: org.eclipse.egit.core.internal; bundle-symbolic-name="org.eclipse.egit.core"; bundle-version="4.4.0.201606070830-r"; version="4.4.0"; x-friends:="org.eclipse.egit.ui,org.eclipse.egit.import,org.eclipse.egit.gitflow.ui"
!ENTRY org.eclipse.epp.mpc.core 4 0 2018-01-19 09:25:21.384
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.epp.mpc.core [71]
Unresolved requirement: Import-Package: org.apache.http; version="4.3.0"
!ENTRY org.eclipse.epp.mpc.ui 4 0 2018-01-19 09:25:21.384
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.epp.mpc.ui [73]
!ENTRY org.eclipse.equinox.concurrent 4 0 2018-01-19 09:25:21.384
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.concurrent [74]
Unresolved requirement: Import-Package: org.eclipse.core.runtime; common="split"; version="3.4.0"
!ENTRY org.eclipse.equinox.http.jetty 4 0 2018-01-19 09:25:21.385
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.http.jetty [77]
Unresolved requirement: Import-Package: javax.servlet; version="[2.6.0,4.0.0)"
!ENTRY org.eclipse.equinox.http.servlet 4 0 2018-01-19 09:25:21.385
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.http.servlet [79]
Unresolved requirement: Import-Package: javax.servlet; version="[2.3.0,4.0.0)"
!ENTRY org.eclipse.equinox.jsp.jasper 4 0 2018-01-19 09:25:21.385
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper [80]
Unresolved requirement: Import-Package: javax.servlet; version="[2.4.0,3.2.0)"
!ENTRY org.eclipse.equinox.jsp.jasper.registry 4 0 2018-01-19 09:25:21.385
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.jsp.jasper.registry [81]
Unresolved requirement: Import-Package: javax.servlet; version="2.4.0"
Unresolved requirement: Import-Package: org.eclipse.equinox.jsp.jasper
-> Export-Package: org.eclipse.equinox.jsp.jasper; bundle-symbolic-name="org.eclipse.equinox.jsp.jasper"; bundle-version="1.0.500.v20150119-1358"; version="1.0.0"
!ENTRY org.eclipse.equinox.p2.console 4 0 2018-01-19 09:25:21.386
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.console [84]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.core.helpers
!ENTRY org.eclipse.equinox.p2.director.app 4 0 2018-01-19 09:25:21.386
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.director.app [85]
Unresolved requirement: Import-Package: org.eclipse.equinox.app
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2018-01-19 09:25:21.386
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.directorywatcher [86]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.artifact.repository.simple
!ENTRY org.eclipse.equinox.p2.discovery.compatibility 4 0 2018-01-19 09:25:21.386
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.discovery.compatibility [88]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="3.3.0"
!ENTRY org.eclipse.equinox.p2.extensionlocation 4 0 2018-01-19 09:25:21.387
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.extensionlocation [89]
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 0 2018-01-19 09:25:21.387
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.transport.ecf [91]
Unresolved requirement: Require-Bundle: org.eclipse.equinox.p2.core; bundle-version="2.0.100"
Unresolved requirement: Require-Bundle: org.eclipse.ecf; bundle-version="3.1.0"
-> Bundle-SymbolicName: org.eclipse.ecf; bundle-version="3.8.0.v20160823-2221"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.ecf.filetransfer; bundle-version="4.0.0"
-> Bundle-SymbolicName: org.eclipse.ecf.filetransfer; bundle-version="5.0.0.v20160823-2221"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.ecf.provider.filetransfer; bundle-version="3.1.0"
-> Bundle-SymbolicName: org.eclipse.ecf.provider.filetransfer; bundle-version="3.2.200.v20160823-2221"; singleton:="true"
!ENTRY org.eclipse.equinox.p2.ui.importexport 4 0 2018-01-19 09:25:21.387
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.ui.importexport [93]
Unresolved requirement: Import-Package: org.eclipse.equinox.internal.p2.metadata.repository.io
!ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 4 0 2018-01-19 09:25:21.387
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.ui.sdk.scheduler [94]
Unresolved requirement: Import-Package: com.ibm.icu.util; version="4.0.1"
!ENTRY org.eclipse.equinox.p2.updatechecker 4 0 2018-01-19 09:25:21.388
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.updatechecker [95]
!ENTRY org.eclipse.equinox.p2.updatesite 4 0 2018-01-19 09:25:21.388
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.updatesite [96]
Unresolved requirement: Import-Package: org.eclipse.equinox.app; version="1.1.0"
!ENTRY org.eclipse.help.ui 4 0 2018-01-19 09:25:21.388
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.help.ui [98]
!ENTRY org.eclipse.help.webapp 4 0 2018-01-19 09:25:21.388
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.help.webapp [99]
Unresolved requirement: Import-Package: com.ibm.icu.text; version="3.8.0"
!ENTRY org.eclipse.jsch.core 4 0 2018-01-19 09:25:21.389
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jsch.core [103]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="[3.3.0,4.0.0)"
!ENTRY org.eclipse.jsch.ui 4 0 2018-01-19 09:25:21.389
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jsch.ui [104]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.remote.console 4 0 2018-01-19 09:25:21.389
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.console [109]
Unresolved requirement: Import-Package: org.eclipse.core.commands
!ENTRY org.eclipse.remote.core 4 0 2018-01-19 09:25:21.389
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.core [110]
Unresolved requirement: Import-Package: org.eclipse.cdt.utils.pty
!ENTRY org.eclipse.remote.jsch.core 4 0 2018-01-19 09:25:21.390
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.jsch.core [112]
Unresolved requirement: Import-Package: org.eclipse.core.filesystem
!ENTRY org.eclipse.remote.jsch.ui 4 0 2018-01-19 09:25:21.390
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.jsch.ui [113]
!ENTRY org.eclipse.remote.serial.core 4 0 2018-01-19 09:25:21.390
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.serial.core [114]
!ENTRY org.eclipse.remote.serial.ui 4 0 2018-01-19 09:25:21.390
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.serial.ui [115]
Unresolved requirement: Import-Package: org.eclipse.core.expressions
!ENTRY org.eclipse.remote.telnet.core 4 0 2018-01-19 09:25:21.391
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.telnet.core [116]
!ENTRY org.eclipse.remote.telnet.ui 4 0 2018-01-19 09:25:21.391
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.telnet.ui [117]
!ENTRY org.eclipse.remote.ui 4 0 2018-01-19 09:25:21.392
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.remote.ui [118]
!ENTRY org.eclipse.rse.connectorservice.dstore 4 0 2018-01-19 09:25:21.393
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.connectorservice.dstore [120]
!ENTRY org.eclipse.rse.connectorservice.local 4 0 2018-01-19 09:25:21.393
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.connectorservice.local [121]
!ENTRY org.eclipse.rse.connectorservice.ssh 4 0 2018-01-19 09:25:21.393
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.connectorservice.ssh [122]
!ENTRY org.eclipse.rse.connectorservice.telnet 4 0 2018-01-19 09:25:21.393
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.connectorservice.telnet [123]
!ENTRY org.eclipse.rse.core 4 0 2018-01-19 09:25:21.394
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.core [124]
!ENTRY org.eclipse.rse.dstore.security 4 0 2018-01-19 09:25:21.394
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.dstore.security [126]
!ENTRY org.eclipse.rse.efs 4 0 2018-01-19 09:25:21.394
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.efs [127]
!ENTRY org.eclipse.rse.files.ui 4 0 2018-01-19 09:25:21.394
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.files.ui [129]
!ENTRY org.eclipse.rse.importexport 4 0 2018-01-19 09:25:21.395
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.importexport [130]
!ENTRY org.eclipse.rse.processes.ui 4 0 2018-01-19 09:25:21.395
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.processes.ui [131]
!ENTRY org.eclipse.rse.services 4 0 2018-01-19 09:25:21.395
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.services [132]
!ENTRY org.eclipse.rse.services.dstore 4 0 2018-01-19 09:25:21.395
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.services.dstore [133]
!ENTRY org.eclipse.rse.services.files.ftp 4 0 2018-01-19 09:25:21.396
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.services.files.ftp [134]
!ENTRY org.eclipse.rse.services.local 4 0 2018-01-19 09:25:21.396
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.services.local [135]
!ENTRY org.eclipse.rse.services.ssh 4 0 2018-01-19 09:25:21.396
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.services.ssh [136]
!ENTRY org.eclipse.rse.services.telnet 4 0 2018-01-19 09:25:21.396
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.services.telnet [137]
!ENTRY org.eclipse.rse.shells.ui 4 0 2018-01-19 09:25:21.397
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.shells.ui [138]
!ENTRY org.eclipse.rse.subsystems.files.core 4 0 2018-01-19 09:25:21.397
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.files.core [139]
!ENTRY org.eclipse.rse.subsystems.files.dstore 4 0 2018-01-19 09:25:21.397
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.files.dstore [140]
!ENTRY org.eclipse.rse.subsystems.files.ftp 4 0 2018-01-19 09:25:21.397
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.files.ftp [141]
!ENTRY org.eclipse.rse.subsystems.files.local 4 0 2018-01-19 09:25:21.398
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.files.local [142]
!ENTRY org.eclipse.rse.subsystems.files.ssh 4 0 2018-01-19 09:25:21.398
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.files.ssh [143]
!ENTRY org.eclipse.rse.subsystems.processes.core 4 0 2018-01-19 09:25:21.398
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.processes.core [144]
Unresolved requirement: Require-Bundle: org.eclipse.rse.services; bundle-version="[3.0.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.rse.services; bundle-version="3.3.0.201506120731"; singleton:="true"
!ENTRY org.eclipse.rse.subsystems.processes.dstore 4 0 2018-01-19 09:25:21.398
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.processes.dstore [145]
!ENTRY org.eclipse.rse.subsystems.processes.local 4 0 2018-01-19 09:25:21.399
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.processes.local [146]
!ENTRY org.eclipse.rse.subsystems.processes.shell.linux 4 0 2018-01-19 09:25:21.399
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.processes.shell.linux [147]
!ENTRY org.eclipse.rse.subsystems.shells.core 4 0 2018-01-19 09:25:21.399
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.shells.core [148]
!ENTRY org.eclipse.rse.subsystems.shells.dstore 4 0 2018-01-19 09:25:21.399
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.shells.dstore [149]
!ENTRY org.eclipse.rse.subsystems.shells.local 4 0 2018-01-19 09:25:21.400
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.shells.local [150]
!ENTRY org.eclipse.rse.subsystems.shells.ssh 4 0 2018-01-19 09:25:21.400
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.shells.ssh [151]
!ENTRY org.eclipse.rse.subsystems.shells.telnet 4 0 2018-01-19 09:25:21.400
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.subsystems.shells.telnet [152]
!ENTRY org.eclipse.rse.ui 4 0 2018-01-19 09:25:21.400
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rse.ui [153]
Unresolved requirement: Import-Package: com.ibm.icu.lang
!ENTRY org.eclipse.tm.terminal.connector.local 4 0 2018-01-19 09:25:21.401
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.connector.local [154]
Unresolved requirement: Import-Package: org.eclipse.cdt.utils.pty; mandatory:="native"
!ENTRY org.eclipse.tm.terminal.connector.process 4 0 2018-01-19 09:25:21.401
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.connector.process [155]
!ENTRY org.eclipse.tm.terminal.connector.serial 4 0 2018-01-19 09:25:21.401
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.connector.serial [156]
Unresolved requirement: Require-Bundle: org.eclipse.core.expressions; bundle-version="3.4.400"
!ENTRY org.eclipse.tm.terminal.connector.ssh 4 0 2018-01-19 09:25:21.401
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.connector.ssh [157]
!ENTRY org.eclipse.tm.terminal.connector.telnet 4 0 2018-01-19 09:25:21.402
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.connector.telnet [158]
!ENTRY org.eclipse.tm.terminal.control 4 0 2018-01-19 09:25:21.402
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.control [159]
!ENTRY org.eclipse.tm.terminal.view.core 4 0 2018-01-19 09:25:21.402
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.view.core [160]
!ENTRY org.eclipse.tm.terminal.view.ui 4 0 2018-01-19 09:25:21.402
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.tm.terminal.view.ui [161]
!ENTRY org.eclipse.ui.externaltools 4 0 2018-01-19 09:25:21.403
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.externaltools [162]
Unresolved requirement: Require-Bundle: org.eclipse.ui.ide; bundle-version="[3.2.0,4.0.0)"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.core.resources; bundle-version="[3.2.0,4.0.0)"
!ENTRY org.eclipse.ui.intro.quicklinks 4 0 2018-01-19 09:25:21.403
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.intro.quicklinks [163]
Unresolved requirement: Require-Bundle: org.eclipse.ui.intro; bundle-version="3.4.0"
!ENTRY org.eclipse.ui.intro.universal 4 0 2018-01-19 09:25:21.403
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.intro.universal [164]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="[3.6.0,4.0.0)"
!ENTRY org.eclipse.ui.monitoring 4 0 2018-01-19 09:25:21.403
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.monitoring [165]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="[3.10.0,4.0.0)"
!ENTRY org.eclipse.ui.net 4 0 2018-01-19 09:25:21.404
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.net [166]
Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.3.0,4.0.0)"
!ENTRY org.eclipse.update.configurator 4 0 2018-01-19 09:25:21.404
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.update.configurator [169]
Unresolved requirement: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.2.0,4.0.0)"
!ENTRY org.eclipse.userstorage 4 0 2018-01-19 09:25:21.404
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.userstorage [170]
Unresolved requirement: Require-Bundle: org.eclipse.core.runtime; bundle-version="[3.0.0,4.0.0)"
!ENTRY org.eclipse.userstorage.ui 4 0 2018-01-19 09:25:21.404
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.userstorage.ui [171]
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2018-01-19 09:25:21.405
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.equinox.p2.reconciler.dropins [90]
Unresolved requirement: Import-Package: org.eclipse.equinox.app; version="1.0.0"
!ENTRY org.eclipse.osgi 4 0 2018-01-19 09:25:21.405
!MESSAGE Bundle initial@reference:file:../../../ti/ccsv7/eclipse/plugins/org.eclipse.equinox.event_1.3.200.v20160324-1850.jar was not resolved.
!MESSAGE Bundle initial@reference:file:../../../ti/ccsv7/eclipse/plugins/org.eclipse.equinox.p2.reconciler.dropins_1.1.400.v20160504-1450.jar was not resolved.
!ENTRY org.eclipse.equinox.p2.discovery.compatibility 2 0 2018-01-19 09:25:21.446
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.discovery.compatibility [88]
!ENTRY org.eclipse.rse.dstore.security 2 0 2018-01-19 09:25:21.447
!MESSAGE Could not resolve module: org.eclipse.rse.dstore.security [126]
!ENTRY org.eclipse.ecf.filetransfer 2 0 2018-01-19 09:25:21.447
!MESSAGE Could not resolve module: org.eclipse.ecf.filetransfer [60]
!ENTRY org.eclipse.core.net.win32.x86 2 0 2018-01-19 09:25:21.447
!MESSAGE Could not resolve module: org.eclipse.core.net.win32.x86 [54]
Unresolved requirement: Fragment-Host: org.eclipse.core.net; bundle-version="1.1.0"
!ENTRY org.eclipse.equinox.security.win32.x86 2 0 2018-01-19 09:25:21.447
!MESSAGE Could not resolve module: org.eclipse.equinox.security.win32.x86 [97]
Unresolved requirement: Fragment-Host: org.eclipse.equinox.security; bundle-version="[1.0.0,2.0.0)"
!ENTRY org.eclipse.cdt.build.gcc.core 2 0 2018-01-19 09:25:21.448
!MESSAGE Could not resolve module: org.eclipse.cdt.build.gcc.core [32]
!ENTRY org.eclipse.rse.processes.ui 2 0 2018-01-19 09:25:21.448
!MESSAGE Could not resolve module: org.eclipse.rse.processes.ui [131]
!ENTRY org.eclipse.equinox.jsp.jasper.registry 2 0 2018-01-19 09:25:21.448
!MESSAGE Could not resolve module: org.eclipse.equinox.jsp.jasper.registry [81]
!ENTRY org.eclipse.ecf.provider.filetransfer.httpclient4 2 0 2018-01-19 09:25:21.448
!MESSAGE Could not resolve module: org.eclipse.ecf.provider.filetransfer.httpclient4 [63]
!ENTRY org.eclipse.epp.mpc.ui 2 0 2018-01-19 09:25:21.449
!MESSAGE Could not resolve module: org.eclipse.epp.mpc.ui [73]
!ENTRY org.eclipse.rse.services.files.ftp 2 0 2018-01-19 09:25:21.449
!MESSAGE Could not resolve module: org.eclipse.rse.services.files.ftp [134]
!ENTRY org.eclipse.ui.externaltools 2 0 2018-01-19 09:25:21.449
!MESSAGE Could not resolve module: org.eclipse.ui.externaltools [162]
!ENTRY org.eclipse.cdt.codan.ui.cxx 2 0 2018-01-19 09:25:21.449
!MESSAGE Could not resolve module: org.eclipse.cdt.codan.ui.cxx [38]
!ENTRY org.eclipse.egit.core 2 0 2018-01-19 09:25:21.450
!MESSAGE Could not resolve module: org.eclipse.egit.core [68]
!ENTRY org.eclipse.egit.doc 2 0 2018-01-19 09:25:21.450
!MESSAGE Could not resolve module: org.eclipse.egit.doc [69]
!ENTRY org.eclipse.help.webapp 2 0 2018-01-19 09:25:21.450
!MESSAGE Could not resolve module: org.eclipse.help.webapp [99]
!ENTRY org.apache.batik.css 2 0 2018-01-19 09:25:21.450
!MESSAGE Could not resolve module: org.apache.batik.css [11]
Unresolved requirement: Require-Bundle: org.w3c.css.sac; bundle-version="[1.3.0,1.4.0)"
!ENTRY org.eclipse.equinox.p2.ui.importexport 2 0 2018-01-19 09:25:21.450
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.ui.importexport [93]
!ENTRY org.eclipse.remote.ui 2 0 2018-01-19 09:25:21.451
!MESSAGE Could not resolve module: org.eclipse.remote.ui [118]
!ENTRY org.eclipse.rse.subsystems.shells.ssh 2 0 2018-01-19 09:25:21.451
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.shells.ssh [151]
!ENTRY org.apache.batik.parser 2 0 2018-01-19 09:25:21.451
!MESSAGE Could not resolve module: org.apache.batik.parser [15]
Unresolved requirement: Require-Bundle: org.w3c.dom.svg; bundle-version="[1.1.0,1.3.0)"
!ENTRY org.eclipse.equinox.event 2 0 2018-01-19 09:25:21.451
!MESSAGE Could not resolve module: org.eclipse.equinox.event [76]
!ENTRY org.apache.batik.dom 2 0 2018-01-19 09:25:21.452
!MESSAGE Could not resolve module: org.apache.batik.dom [12]
Unresolved requirement: Import-Package: org.apache.xerces.parsers; resolution:="optional"
-> Export-Package: org.apache.xerces.parsers; bundle-symbolic-name="org.apache.xerces"; bundle-version="2.9.0.v201101211617"; version="2.9.0"
org.apache.xerces [28]
Unresolved requirement: Require-Bundle: javax.xml; bundle-version="[1.3.4,2.0.0)"; visibility:="reexport"
Unresolved requirement: Require-Bundle: org.apache.batik.css; bundle-version="[1.6.0,1.7.0)"
-> Bundle-SymbolicName: org.apache.batik.css; bundle-version="1.6.0.v201011041432"
!ENTRY org.eclipse.ui.intro.universal 2 0 2018-01-19 09:25:21.452
!MESSAGE Could not resolve module: org.eclipse.ui.intro.universal [164]
!ENTRY org.eclipse.remote.jsch.ui 2 0 2018-01-19 09:25:21.452
!MESSAGE Could not resolve module: org.eclipse.remote.jsch.ui [113]
!ENTRY org.eclipse.rse.importexport 2 0 2018-01-19 09:25:21.452
!MESSAGE Could not resolve module: org.eclipse.rse.importexport [130]
!ENTRY org.apache.batik.bridge 2 0 2018-01-19 09:25:21.453
!MESSAGE Could not resolve module: org.apache.batik.bridge [10]
Unresolved requirement: Require-Bundle: org.apache.batik.dom.svg; bundle-version="[1.6.0,1.7.0)"
-> Bundle-SymbolicName: org.apache.batik.dom.svg; bundle-version="1.6.0.v201011041432"
org.apache.batik.dom.svg [13]
Unresolved requirement: Require-Bundle: org.apache.batik.dom; bundle-version="[1.6.0,1.7.0)"
-> Bundle-SymbolicName: org.apache.batik.dom; bundle-version="1.6.1.v201505192100"
Unresolved requirement: Require-Bundle: org.apache.batik.parser; bundle-version="[1.6.0,1.7.0)"
-> Bundle-SymbolicName: org.apache.batik.parser; bundle-version="1.6.0.v201011041432"
!ENTRY org.eclipse.rse.connectorservice.local 2 0 2018-01-19 09:25:21.453
!MESSAGE Could not resolve module: org.eclipse.rse.connectorservice.local [121]
!ENTRY org.apache.batik.transcoder 2 0 2018-01-19 09:25:21.454
!MESSAGE Could not resolve module: org.apache.batik.transcoder [18]
Unresolved requirement: Require-Bundle: org.apache.batik.bridge; bundle-version="[1.6.0,1.7.0)"
-> Bundle-SymbolicName: org.apache.batik.bridge; bundle-version="1.6.0.v201011041432"
!ENTRY org.eclipse.equinox.p2.updatesite 2 0 2018-01-19 09:25:21.454
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.updatesite [96]
!ENTRY org.eclipse.ecf.provider.filetransfer 2 0 2018-01-19 09:25:21.454
!MESSAGE Could not resolve module: org.eclipse.ecf.provider.filetransfer [62]
!ENTRY org.eclipse.rse.subsystems.shells.telnet 2 0 2018-01-19 09:25:21.454
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.shells.telnet [152]
!ENTRY org.eclipse.ecf.provider.filetransfer.httpclient4.ssl 2 0 2018-01-19 09:25:21.454
!MESSAGE Could not resolve module: org.eclipse.ecf.provider.filetransfer.httpclient4.ssl [64]
Unresolved requirement: Fragment-Host: org.eclipse.ecf.provider.filetransfer.httpclient4; bundle-version="1.0.0"
-> Bundle-SymbolicName: org.eclipse.ecf.provider.filetransfer.httpclient4; bundle-version="1.1.100.v20160823-2221"; singleton:="true"
!ENTRY org.eclipse.platform 2 0 2018-01-19 09:25:21.455
!MESSAGE Could not resolve module: org.eclipse.platform [106]
Unresolved requirement: Require-Bundle: org.eclipse.ui.intro; bundle-version="[3.2.0,4.0.0)"
!ENTRY org.eclipse.tm.terminal.connector.local 2 0 2018-01-19 09:25:21.455
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.connector.local [154]
!ENTRY org.eclipse.equinox.p2.extensionlocation 2 0 2018-01-19 09:25:21.455
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.extensionlocation [89]
!ENTRY org.eclipse.rse.subsystems.processes.local 2 0 2018-01-19 09:25:21.455
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.processes.local [146]
!ENTRY org.eclipse.userstorage.ui 2 0 2018-01-19 09:25:21.456
!MESSAGE Could not resolve module: org.eclipse.userstorage.ui [171]
!ENTRY org.eclipse.cdt.managedbuilder.gnu.ui 2 0 2018-01-19 09:25:21.456
!MESSAGE Could not resolve module: org.eclipse.cdt.managedbuilder.gnu.ui [48]
!ENTRY org.eclipse.remote.telnet.ui 2 0 2018-01-19 09:25:21.456
!MESSAGE Could not resolve module: org.eclipse.remote.telnet.ui [117]
!ENTRY org.eclipse.platform.doc.user 2 0 2018-01-19 09:25:21.456
!MESSAGE Could not resolve module: org.eclipse.platform.doc.user [107]
Unresolved requirement: Require-Bundle: org.eclipse.help; bundle-version="[3.2.0,4.0.0)"
!ENTRY org.eclipse.rse.subsystems.shells.dstore 2 0 2018-01-19 09:25:21.456
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.shells.dstore [149]
!ENTRY org.eclipse.equinox.http.registry 2 0 2018-01-19 09:25:21.457
!MESSAGE Could not resolve module: org.eclipse.equinox.http.registry [78]
Unresolved requirement: Import-Package: javax.servlet; version="2.3.0"
!ENTRY org.eclipse.ecf.ssl 2 0 2018-01-19 09:25:21.457
!MESSAGE Could not resolve module: org.eclipse.ecf.ssl [66]
!ENTRY org.eclipse.ui.themes 2 0 2018-01-19 09:25:21.457
!MESSAGE Could not resolve module: org.eclipse.ui.themes [167]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.css.swt.theme
!ENTRY org.eclipse.tm.terminal.connector.process 2 0 2018-01-19 09:25:21.457
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.connector.process [155]
!ENTRY org.eclipse.tm.terminal.connector.serial 2 0 2018-01-19 09:25:21.458
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.connector.serial [156]
!ENTRY org.eclipse.core.externaltools 2 0 2018-01-19 09:25:21.458
!MESSAGE Could not resolve module: org.eclipse.core.externaltools [52]
!ENTRY org.eclipse.jetty.continuation 2 0 2018-01-19 09:25:21.458
!MESSAGE Could not resolve module: org.eclipse.jetty.continuation [100]
Unresolved requirement: Import-Package: javax.servlet; version="[2.6.0,3.2.0)"
!ENTRY org.eclipse.cdt.codan.checkers.ui 2 0 2018-01-19 09:25:21.458
!MESSAGE Could not resolve module: org.eclipse.cdt.codan.checkers.ui [34]
!ENTRY org.eclipse.core.databinding.beans 2 0 2018-01-19 09:25:21.459
!MESSAGE Could not resolve module: org.eclipse.core.databinding.beans [51]
!ENTRY org.eclipse.rse.shells.ui 2 0 2018-01-19 09:25:21.459
!MESSAGE Could not resolve module: org.eclipse.rse.shells.ui [138]
!ENTRY org.eclipse.ecf.identity 2 0 2018-01-19 09:25:21.459
!MESSAGE Could not resolve module: org.eclipse.ecf.identity [61]
!ENTRY javax.el 2 0 2018-01-19 09:25:21.459
!MESSAGE Could not resolve module: javax.el [8]
Unresolved requirement: Import-Package: javax.servlet; version="2.5.0"
!ENTRY org.eclipse.cdt.dsf.gdb.ui 2 0 2018-01-19 09:25:21.460
!MESSAGE Could not resolve module: org.eclipse.cdt.dsf.gdb.ui [45]
!ENTRY org.eclipse.remote.serial.ui 2 0 2018-01-19 09:25:21.460
!MESSAGE Could not resolve module: org.eclipse.remote.serial.ui [115]
!ENTRY org.eclipse.rse.subsystems.processes.dstore 2 0 2018-01-19 09:25:21.460
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.processes.dstore [145]
!ENTRY org.eclipse.ecf 2 0 2018-01-19 09:25:21.460
!MESSAGE Could not resolve module: org.eclipse.ecf [59]
!ENTRY org.eclipse.cdt.codan.core 2 0 2018-01-19 09:25:21.461
!MESSAGE Could not resolve module: org.eclipse.cdt.codan.core [35]
!ENTRY org.eclipse.rse.efs 2 0 2018-01-19 09:25:21.461
!MESSAGE Could not resolve module: org.eclipse.rse.efs [127]
!ENTRY org.eclipse.equinox.concurrent 2 0 2018-01-19 09:25:21.461
!MESSAGE Could not resolve module: org.eclipse.equinox.concurrent [74]
!ENTRY org.eclipse.equinox.p2.directorywatcher 2 0 2018-01-19 09:25:21.461
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.directorywatcher [86]
!ENTRY org.eclipse.rse.efs.ui 2 0 2018-01-19 09:25:21.461
!MESSAGE Could not resolve module: org.eclipse.rse.efs.ui [128]
!ENTRY org.eclipse.ui.monitoring 2 0 2018-01-19 09:25:21.462
!MESSAGE Could not resolve module: org.eclipse.ui.monitoring [165]
!ENTRY org.eclipse.cdt.codan.checkers 2 0 2018-01-19 09:25:21.462
!MESSAGE Could not resolve module: org.eclipse.cdt.codan.checkers [33]
!ENTRY org.eclipse.dstore.extra 2 0 2018-01-19 09:25:21.462
!MESSAGE Could not resolve module: org.eclipse.dstore.extra [57]
!ENTRY org.eclipse.remote.serial.core 2 0 2018-01-19 09:25:21.462
!MESSAGE Could not resolve module: org.eclipse.remote.serial.core [114]
!ENTRY org.eclipse.cdt.core.win32.x86 2 0 2018-01-19 09:25:21.462
!MESSAGE Could not resolve module: org.eclipse.cdt.core.win32.x86 [40]
Unresolved requirement: Fragment-Host: org.eclipse.cdt.core.native; bundle-version="[5.7.0,6.0.0)"
!ENTRY org.eclipse.rse.ui 2 0 2018-01-19 09:25:21.463
!MESSAGE Could not resolve module: org.eclipse.rse.ui [153]
!ENTRY org.eclipse.ui.net 2 0 2018-01-19 09:25:21.463
!MESSAGE Could not resolve module: org.eclipse.ui.net [166]
!ENTRY org.eclipse.e4.ui.dialogs 2 0 2018-01-19 09:25:21.463
!MESSAGE Could not resolve module: org.eclipse.e4.ui.dialogs [58]
Unresolved requirement: Require-Bundle: org.eclipse.jface; bundle-version="3.11.0"
!ENTRY org.eclipse.rse.subsystems.shells.local 2 0 2018-01-19 09:25:21.463
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.shells.local [150]
!ENTRY org.eclipse.rse.services 2 0 2018-01-19 09:25:21.463
!MESSAGE Could not resolve module: org.eclipse.rse.services [132]
!ENTRY org.eclipse.rse.files.ui 2 0 2018-01-19 09:25:21.464
!MESSAGE Could not resolve module: org.eclipse.rse.files.ui [129]
!ENTRY org.eclipse.rse.subsystems.shells.core 2 0 2018-01-19 09:25:21.464
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.shells.core [148]
!ENTRY org.eclipse.epp.mpc.core 2 0 2018-01-19 09:25:21.464
!MESSAGE Could not resolve module: org.eclipse.epp.mpc.core [71]
!ENTRY org.eclipse.epp.mpc.help.ui 2 0 2018-01-19 09:25:21.464
!MESSAGE Could not resolve module: org.eclipse.epp.mpc.help.ui [72]
Unresolved requirement: Require-Bundle: org.eclipse.help; bundle-version="3.5.0"
!ENTRY org.eclipse.tm.terminal.view.ui 2 0 2018-01-19 09:25:21.464
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.view.ui [161]
!ENTRY org.eclipse.egit.ui 2 0 2018-01-19 09:25:21.465
!MESSAGE Could not resolve module: org.eclipse.egit.ui [70]
!ENTRY org.eclipse.remote.console 2 0 2018-01-19 09:25:21.465
!MESSAGE Could not resolve module: org.eclipse.remote.console [109]
!ENTRY org.eclipse.rse.subsystems.files.dstore 2 0 2018-01-19 09:25:21.465
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.files.dstore [140]
!ENTRY org.eclipse.equinox.http.jetty 2 0 2018-01-19 09:25:21.466
!MESSAGE Could not resolve module: org.eclipse.equinox.http.jetty [77]
!ENTRY org.eclipse.remote.jsch.core 2 0 2018-01-19 09:25:21.466
!MESSAGE Could not resolve module: org.eclipse.remote.jsch.core [112]
!ENTRY org.eclipse.tm.terminal.control 2 0 2018-01-19 09:25:21.466
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.control [159]
!ENTRY org.eclipse.rse.services.ssh 2 0 2018-01-19 09:25:21.466
!MESSAGE Could not resolve module: org.eclipse.rse.services.ssh [136]
!ENTRY org.eclipse.tm.terminal.view.core 2 0 2018-01-19 09:25:21.466
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.view.core [160]
!ENTRY org.eclipse.rse.connectorservice.telnet 2 0 2018-01-19 09:25:21.467
!MESSAGE Could not resolve module: org.eclipse.rse.connectorservice.telnet [123]
!ENTRY org.eclipse.help.ui 2 0 2018-01-19 09:25:21.467
!MESSAGE Could not resolve module: org.eclipse.help.ui [98]
!ENTRY org.eclipse.jsch.core 2 0 2018-01-19 09:25:21.467
!MESSAGE Could not resolve module: org.eclipse.jsch.core [103]
!ENTRY org.eclipse.cdt.codan.ui 2 0 2018-01-19 09:25:21.467
!MESSAGE Could not resolve module: org.eclipse.cdt.codan.ui [37]
!ENTRY org.eclipse.cdt.debug.ui.memory.transport 2 0 2018-01-19 09:25:21.468
!MESSAGE Could not resolve module: org.eclipse.cdt.debug.ui.memory.transport [43]
!ENTRY org.eclipse.cdt.codan.core.cxx 2 0 2018-01-19 09:25:21.468
!MESSAGE Could not resolve module: org.eclipse.cdt.codan.core.cxx [36]
!ENTRY org.eclipse.dstore.core 2 0 2018-01-19 09:25:21.468
!MESSAGE Could not resolve module: org.eclipse.dstore.core [56]
!ENTRY org.eclipse.equinox.http.servlet 2 0 2018-01-19 09:25:21.468
!MESSAGE Could not resolve module: org.eclipse.equinox.http.servlet [79]
!ENTRY org.eclipse.equinox.p2.discovery 2 0 2018-01-19 09:25:21.469
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.discovery [87]
!ENTRY org.eclipse.tm.terminal.connector.telnet 2 0 2018-01-19 09:25:21.469
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.connector.telnet [158]
!ENTRY org.eclipse.update.configurator 2 0 2018-01-19 09:25:21.469
!MESSAGE Could not resolve module: org.eclipse.update.configurator [169]
!ENTRY org.slf4j.impl.log4j12 2 0 2018-01-19 09:25:21.469
!MESSAGE Could not resolve module: org.slf4j.impl.log4j12 [173]
Unresolved requirement: Import-Package: org.apache.log4j
!ENTRY org.eclipse.tm.terminal.connector.ssh 2 0 2018-01-19 09:25:21.470
!MESSAGE Could not resolve module: org.eclipse.tm.terminal.connector.ssh [157]
!ENTRY org.eclipse.cdt.core.win32 2 0 2018-01-19 09:25:21.470
!MESSAGE Could not resolve module: org.eclipse.cdt.core.win32 [39]
!ENTRY org.eclipse.cdt.launch.remote 2 0 2018-01-19 09:25:21.470
!MESSAGE Could not resolve module: org.eclipse.cdt.launch.remote [47]
!ENTRY org.eclipse.rse.subsystems.files.core 2 0 2018-01-19 09:25:21.470
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.files.core [139]
!ENTRY org.eclipse.cdt.debug.ui.memory.floatingpoint 2 0 2018-01-19 09:25:21.470
!MESSAGE Could not resolve module: org.eclipse.cdt.debug.ui.memory.floatingpoint [41]
!ENTRY org.eclipse.rse.subsystems.files.local 2 0 2018-01-19 09:25:21.471
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.files.local [142]
!ENTRY org.eclipse.rse.services.local 2 0 2018-01-19 09:25:21.471
!MESSAGE Could not resolve module: org.eclipse.rse.services.local [135]
!ENTRY org.eclipse.userstorage 2 0 2018-01-19 09:25:21.471
!MESSAGE Could not resolve module: org.eclipse.userstorage [170]
!ENTRY javax.servlet.jsp 2 0 2018-01-19 09:25:21.471
!MESSAGE Could not resolve module: javax.servlet.jsp [9]
Unresolved requirement: Import-Package: javax.el; version="2.2.0"
-> Export-Package: javax.el; bundle-symbolic-name="javax.el"; bundle-version="2.2.0.v201303151357"; version="2.2.0"
javax.el [8]
!ENTRY org.apache.batik.dom.svg 2 0 2018-01-19 09:25:21.472
!MESSAGE Could not resolve module: org.apache.batik.dom.svg [13]
!ENTRY org.eclipse.cdt.debug.ui.memory.search 2 0 2018-01-19 09:25:21.472
!MESSAGE Could not resolve module: org.eclipse.cdt.debug.ui.memory.search [42]
!ENTRY org.eclipse.rse.core 2 0 2018-01-19 09:25:21.472
!MESSAGE Could not resolve module: org.eclipse.rse.core [124]
!ENTRY org.eclipse.equinox.p2.console 2 0 2018-01-19 09:25:21.472
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.console [84]
!ENTRY org.eclipse.rse.services.dstore 2 0 2018-01-19 09:25:21.472
!MESSAGE Could not resolve module: org.eclipse.rse.services.dstore [133]
!ENTRY org.eclipse.cdt.build.crossgcc 2 0 2018-01-19 09:25:21.473
!MESSAGE Could not resolve module: org.eclipse.cdt.build.crossgcc [31]
!ENTRY org.eclipse.compare.win32 2 0 2018-01-19 09:25:21.474
!MESSAGE Could not resolve module: org.eclipse.compare.win32 [50]
!ENTRY com.sun.el 2 0 2018-01-19 09:25:21.474
!MESSAGE Could not resolve module: com.sun.el [3]
Unresolved requirement: Import-Package: javax.servlet.http; version="2.5.0"
javax.el [8]
!ENTRY org.eclipse.rse.services.telnet 2 0 2018-01-19 09:25:21.475
!MESSAGE Could not resolve module: org.eclipse.rse.services.telnet [137]
!ENTRY org.eclipse.core.filesystem.win32.x86 2 0 2018-01-19 09:25:21.475
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.win32.x86 [53]
Unresolved requirement: Fragment-Host: org.eclipse.core.filesystem; bundle-version="[1.4.0,2.0.0)"
!ENTRY org.eclipse.core.resources.win32.x86 2 0 2018-01-19 09:25:21.475
!MESSAGE Could not resolve module: org.eclipse.core.resources.win32.x86 [55]
Unresolved requirement: Fragment-Host: org.eclipse.core.resources; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2018-01-19 09:25:21.475
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.transport.ecf [91]
!ENTRY org.eclipse.equinox.p2.director.app 2 0 2018-01-19 09:25:21.476
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.director.app [85]
!ENTRY org.eclipse.equinox.jsp.jasper 2 0 2018-01-19 09:25:21.476
!MESSAGE Could not resolve module: org.eclipse.equinox.jsp.jasper [80]
!ENTRY org.eclipse.ecf.provider.filetransfer.ssl 2 0 2018-01-19 09:25:21.476
!MESSAGE Could not resolve module: org.eclipse.ecf.provider.filetransfer.ssl [65]
Unresolved requirement: Fragment-Host: org.eclipse.ecf.provider.filetransfer; bundle-version="2.0.0"
!ENTRY org.eclipse.ui.win32 2 0 2018-01-19 09:25:21.476
!MESSAGE Could not resolve module: org.eclipse.ui.win32 [168]
Unresolved requirement: Fragment-Host: org.eclipse.ui.ide; bundle-version="[3.2.0,4.0.0)"
!ENTRY org.eclipse.equinox.p2.updatechecker 2 0 2018-01-19 09:25:21.476
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.updatechecker [95]
!ENTRY org.eclipse.ui.intro.quicklinks 2 0 2018-01-19 09:25:21.477
!MESSAGE Could not resolve module: org.eclipse.ui.intro.quicklinks [163]
!ENTRY org.apache.jasper.glassfish 2 0 2018-01-19 09:25:21.477
!MESSAGE Could not resolve module: org.apache.jasper.glassfish [27]
javax.el [8]
!ENTRY org.eclipse.rse.subsystems.processes.shell.linux 2 0 2018-01-19 09:25:21.477
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.processes.shell.linux [147]
!ENTRY org.eclipse.rse.subsystems.files.ftp 2 0 2018-01-19 09:25:21.477
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.files.ftp [141]
!ENTRY org.apache.xerces 2 0 2018-01-19 09:25:21.478
!MESSAGE Could not resolve module: org.apache.xerces [28]
!ENTRY org.eclipse.rse.connectorservice.ssh 2 0 2018-01-19 09:25:21.478
!MESSAGE Could not resolve module: org.eclipse.rse.connectorservice.ssh [122]
!ENTRY org.eclipse.cdt.gdb.ui 2 0 2018-01-19 09:25:21.478
!MESSAGE Could not resolve module: org.eclipse.cdt.gdb.ui [46]
!ENTRY org.eclipse.rse.connectorservice.dstore 2 0 2018-01-19 09:25:21.478
!MESSAGE Could not resolve module: org.eclipse.rse.connectorservice.dstore [120]
!ENTRY org.eclipse.remote.doc.isv 2 0 2018-01-19 09:25:21.478
!MESSAGE Could not resolve module: org.eclipse.remote.doc.isv [111]
Unresolved requirement: Require-Bundle: org.eclipse.remote.console
-> Bundle-SymbolicName: org.eclipse.remote.console; bundle-version="1.1.0.201612062149"; singleton:="true"
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 2 0 2018-01-19 09:25:21.479
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.reconciler.dropins [90]
!ENTRY org.eclipse.jsch.ui 2 0 2018-01-19 09:25:21.479
!MESSAGE Could not resolve module: org.eclipse.jsch.ui [104]
!ENTRY org.eclipse.rse.subsystems.files.ssh 2 0 2018-01-19 09:25:21.479
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.files.ssh [143]
!ENTRY org.apache.batik.pdf 2 0 2018-01-19 09:25:21.479
!MESSAGE Could not resolve module: org.apache.batik.pdf [16]
Unresolved requirement: Import-Package: org.apache.batik.bridge; version="[1.6.0,1.7.0)"
-> Export-Package: org.apache.batik.bridge; bundle-symbolic-name="org.apache.batik.bridge"; bundle-version="1.6.0.v201011041432"; version="1.6.0"
!ENTRY org.eclipse.remote.telnet.core 2 0 2018-01-19 09:25:21.480
!MESSAGE Could not resolve module: org.eclipse.remote.telnet.core [116]
!ENTRY org.eclipse.equinox.p2.ui.discovery 2 0 2018-01-19 09:25:21.480
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.ui.discovery [92]
!ENTRY org.eclipse.rse.subsystems.processes.core 2 0 2018-01-19 09:25:21.480
!MESSAGE Could not resolve module: org.eclipse.rse.subsystems.processes.core [144]
!ENTRY org.eclipse.equinox.p2.ui.sdk.scheduler 2 0 2018-01-19 09:25:21.480
!MESSAGE Could not resolve module: org.eclipse.equinox.p2.ui.sdk.scheduler [94]
!ENTRY org.eclipse.cdt.doc.user 2 0 2018-01-19 09:25:21.480
!MESSAGE Could not resolve module: org.eclipse.cdt.doc.user [44]
!ENTRY org.eclipse.remote.core 2 0 2018-01-19 09:25:21.481
!MESSAGE Could not resolve module: org.eclipse.remote.core [110]
!ENTRY org.eclipse.osgi 4 0 2018-01-19 09:25:21.481
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:78)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
