Is there any way to clear the history from the drop down "Address" text box of the Memory View window?
Inadvertently I have typed in a few non valid addresses there that come up as soon as I click on the box, and it's quite annoying...
There isn't a way to remove the history from the UI, however if you don't want to remove your workspace as John has suggested, than you can edit an xml file manually. The xml file is located at <dir>\workspace\.metadata\.plugins\org.eclipse.ui.workbench\dialog_setting.xml
Patrick
