Compiler: Compiler error version 8.2.2 in s__algo.c
I'm trying to port some projects from CCSv5.5 (compiler 7.4.21) to CCSv7.4 (compiler 8.2.2), this library was compiling fine but now I get compiler errors below in s__algo.c file, see below:
I've attached the projects that generate this error.
Any idea why it doesn't compile? Is compatibility broken between v7.4.21 to v8.2.2?
David.test_ini_ccsv5.ziptest_ini_ccsv7.zip
**** Clean-only build of configuration Debug for project test_ini_ccsv7 ****
"C:\\ti\\ccs740\\ccsv7\\utils\\bin\\gmake" -k -j 8 clean -O
DEL /F "test_ini_ccsv7.lib"
DEL /F "IniFile.obj"
DEL /F "IniFile.d"
Could Not Find C:\Users\d.luca\workspace_v7_pgm\test_ini_ccsv7\Debug\test_ini_ccsv7.lib
Could Not Find C:\Users\d.luca\workspace_v7_pgm\test_ini_ccsv7\Debug\IniFile.obj
'Finished clean'
**** Build Finished ****
**** Build of configuration Debug for project test_ini_ccsv7 ****
"C:\\ti\\ccs740\\ccsv7\\utils\\bin\\gmake" -k -j 8 all -O
'Building file: "../IniFile.cpp"'
'Invoking: C6000 Compiler'
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/bin/cl6x" -mv6740 -O3 --opt_for_speed=0 -ms3 --include_path="C:/Users/d.luca/workspace_v7_pgm/test_ini_ccsv7" --include_path="C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include" --define=c6748 -g --diag_warning=225 --diag_wrap=off --display_error_number --preproc_with_compile --preproc_dependency="IniFile.d_raw" "../IniFile.cpp"
>> Compilation failure
subdir_rules.mk:9: recipe for target 'IniFile.obj' failed
"..\.\inifile.h", line 113: warning #1-D: last line of file ends without a newline
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 87: error #2036: function "CIniFile::DescendingSectionSort::operator()" cannot be called with the given argument list
argument types are: (const CIniFile::Record, const CIniFile::Record)
object type is: CIniFile::DescendingSectionSort
detected during:
instantiation of "const _Tp &std::priv::__median(const _Tp &, const _Tp &, const _Tp &, _Compare) [with _Tp=CIniFile::Record, _Compare=CIniFile::DescendingSectionSort]" at line 985
instantiation of "void std::priv::__introsort_loop(_RandomAccessIter, _RandomAccessIter, _Tp *, _Size, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Tp=CIniFile::Record, _Size=int, _Compare=CIniFile::DescendingSectionSort]" at line 1013
instantiation of "void std::sort(_RandomAccessIter, _RandomAccessIter, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Compare=CIniFile::DescendingSectionSort]" at line 473 of "../IniFile.cpp"
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 89: error #2036: function "CIniFile::DescendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 93: error #2036: function "CIniFile::DescendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 100: error #2036: function "CIniFile::DescendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 104: error #2036: function "CIniFile::DescendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 87: error #2036: function "CIniFile::AscendingSectionSort::operator()" cannot be called with the given argument list
object type is: CIniFile::AscendingSectionSort
detected during:
instantiation of "const _Tp &std::priv::__median(const _Tp &, const _Tp &, const _Tp &, _Compare) [with _Tp=CIniFile::Record, _Compare=CIniFile::AscendingSectionSort]" at line 985
instantiation of "void std::priv::__introsort_loop(_RandomAccessIter, _RandomAccessIter, _Tp *, _Size, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Tp=CIniFile::Record, _Size=int, _Compare=CIniFile::AscendingSectionSort]" at line 1013
instantiation of "void std::sort(_RandomAccessIter, _RandomAccessIter, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Compare=CIniFile::AscendingSectionSort]" at line 475 of "../IniFile.cpp"
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 89: error #2036: function "CIniFile::AscendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 93: error #2036: function "CIniFile::AscendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 100: error #2036: function "CIniFile::AscendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 104: error #2036: function "CIniFile::AscendingSectionSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 87: error #2036: function "CIniFile::DescendingRecordSort::operator()" cannot be called with the given argument list
object type is: CIniFile::DescendingRecordSort
detected during:
instantiation of "const _Tp &std::priv::__median(const _Tp &, const _Tp &, const _Tp &, _Compare) [with _Tp=CIniFile::Record, _Compare=CIniFile::DescendingRecordSort]" at line 985
instantiation of "void std::priv::__introsort_loop(_RandomAccessIter, _RandomAccessIter, _Tp *, _Size, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Tp=CIniFile::Record, _Size=int, _Compare=CIniFile::DescendingRecordSort]" at line 1013
instantiation of "void std::sort(_RandomAccessIter, _RandomAccessIter, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Compare=CIniFile::DescendingRecordSort]" at line 484 of "../IniFile.cpp"
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 89: error #2036: function "CIniFile::DescendingRecordSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 93: error #2036: function "CIniFile::DescendingRecordSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 100: error #2036: function "CIniFile::DescendingRecordSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 104: error #2036: function "CIniFile::DescendingRecordSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 87: error #2036: function "CIniFile::AscendingRecordSort::operator()" cannot be called with the given argument list
object type is: CIniFile::AscendingRecordSort
detected during:
instantiation of "const _Tp &std::priv::__median(const _Tp &, const _Tp &, const _Tp &, _Compare) [with _Tp=CIniFile::Record, _Compare=CIniFile::AscendingRecordSort]" at line 985
instantiation of "void std::priv::__introsort_loop(_RandomAccessIter, _RandomAccessIter, _Tp *, _Size, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Tp=CIniFile::Record, _Size=int, _Compare=CIniFile::AscendingRecordSort]" at line 1013
instantiation of "void std::sort(_RandomAccessIter, _RandomAccessIter, _Compare) [with _RandomAccessIter=CIniFile::Record *, _Compare=CIniFile::AscendingRecordSort]" at line 486 of "../IniFile.cpp"
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 89: error #2036: function "CIniFile::AscendingRecordSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 93: error #2036: function "CIniFile::AscendingRecordSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 100: error #2036: function "CIniFile::AscendingRecordSort::operator()" cannot be called with the given argument list
detected during:
"C:/ti/ccs740/ccsv7/tools/compiler/ti-cgt-c6000_8.2.2/include/s__algo.c", line 104: error #2036: function "CIniFile::AscendingRecordSort::operator()" cannot be called with the given argument list
detected during:
20 errors detected in the compilation of "../IniFile.cpp".
gmake: *** [IniFile.obj] Error 1
gmake: Target 'all' not remade because of errors.
  • I have a partial answer.  If you add const to all the arguments to the operator() functions in the Sort classes in IniFile.h, then it builds clean.  Like this ...
    	struct AscendingSectionSort
    		bool operator()(const Record& Start, const Record& End)
    			return Start.Section < End.Section;
    	struct DescendingSectionSort
    			return Start.Section > End.Section;
    	struct AscendingRecordSort
    			return Start.Key < End.Key;
    	struct DescendingRecordSort
    			return Start.Key > End.Key;
    At this point, I'm not sure why this works.  That's next.  In the meantime, I didn't want you to wait.
    Thanks and regards,
    -George
  • Thanks George, that solved my issue. I'm surprised compiler didn't give me const error instead.
    To have this investigated, I filed CODEGEN-4407 in the SDOWP system.  You are free to follow it with the SDOWP link below in my signature.
    Thanks and regards,
    -George
