I recently had to wipe my laptop and am working with a fresh install of Windows 10. I am having difficulty installing CCS v7.4 on this fresh build, however. The installer always fails at the same place and I receive the dialog message (below). I've made sure to disable my antivirus and firewall and am certain that I have admin rights on my machine. The problem, from reviewing the logs, seems to be related to a failed file extraction;
02/02/2018 02:22:31(GMT) - extract - couldn't unzip C:/Users/ga009c/AppData/Local/Temp/ccs_3e6ad634-2552-40f8-4823-20ea2e6ce03b/jre_root_1.8.0.122: 'C:\Users\ga009c\AppData\Local\Temp\CCS_3E~1\util\7ZAEXE~1.BAT' is not recognized as an internal or external command,
operable program or batch file.
02/02/2018 02:22:41(GMT) - checkStatus - CCS_ERROR: Installer failed to install jre correctly. The 2 most common reasons for failure are:
1. Anti-virus on your computer could have impeded the executable.
2. Download is corrupted.
Please submit these logs to TI for analysis using the next dialog.
You may also visit the TI E2E CCS Support forum for additional help.
Complete logs also attached. I've even tried downloading v7.3 and v7.2 but have the exact same error. I'm hoping somebody can help, as I'm out of ideas.
Thanks!
