CCS/CC2640R2F: CCS/CC2640R2F
Part Number: CC2640R2F
Other Parts Discussed in Thread: CCSTUDIO
I have successfully compiled with CCS7.  I can find the .out file and the .hex file.  Now I am trying to compile from the command line with:
eclipsec -noSplash -data "C:\myapp" -application com.ti.ccstudio.apps.projectBuild -ccs.workspace -ccs.buildType clean
Where is the output?  The compile reported 0 errors.  However, I cannot find any output from the compile.
The command line was executed from the \ti\ccsv7\eclipse directory.  Where did not go?
  • The command you have shown is supposed to build all projects in the c:\myapp workspace. Does that workspace have more than one project?
    The .out file generated by command line build should be in the same location as it would be from a GUI build, (ie) inside the /Debug folder (or other build configuration folder) within the project directory.
  • Since I haven’t heard back from you, I’m assuming you were able to resolve this issue. If not, please post a reply with an update below (or create a new thread). Thanks!
