CCS/IWR1443BOOST: IWR1443BOOST
Part Number: IWR1443BOOST
Other Parts Discussed in Thread: CCSTUDIO
We have CCS 7.4.0 running for mmWave but cannot get it to work on another development computer.  We tried un-install and re-install.  I think this is a Resource Explorer connect issue.
Can we start CCS without it trying to start Resource Explorer?
Is there a file that we should uninstall then reinstall CCS to get it to work?
When booting, it says 'an error has occurred. see log file...
Thanks, Peter
----------------------LOG FILE BELOW--------------------------------------------------------------------
!SESSION 2017-12-14 13:48:38.994 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product -data C:\Users\Peter McCormick\workspace_v7 -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 4 0 2017-12-14 13:48:41.126
!MESSAGE path=ccs_base/DebugServer
!MESSAGE debugServerDir=C:/ti/ccsv7/ccs_base/DebugServer
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 13:48:42.307
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@27a3a2 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@13a9db4, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@27a3a2 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@13a9db4, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), AttName=children, EventType=ADD, Position=4, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@1c20a91 (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@8fca83, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)}, AttName=children, EventType=ADD, Position=4, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@1c20a91 (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@8fca83, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@1576ff8
!STACK 0
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4559)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.TaskBar.createHandle(TaskBar.java:103)
at org.eclipse.swt.widgets.TaskBar.<init>(TaskBar.java:96)
at org.eclipse.swt.widgets.Display.getSystemTaskBar(Display.java:2597)
at org.eclipse.ui.internal.StandardTrim.createProgressBar(StandardTrim.java:72)
at org.eclipse.ui.internal.StandardTrim.createWidget(StandardTrim.java:49)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:54)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:308)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:108)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:51)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer.createWidget(ToolControlRenderer.java:108)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(PartRenderingEngine.java:296)
at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:80)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:294)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
at org.eclipse.ui.internal.WorkbenchWindow.populateStandardTrim(WorkbenchWindow.java:1149)
at org.eclipse.ui.internal.WorkbenchWindow.populateBottomTrimContributions(WorkbenchWindow.java:1254)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:671)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:118)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1525)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1499)
at com.ti.ccstudio.debug.ui.targetStatus.TargetStatusManager.addStatusBar(TargetStatusManager.java:379)
at com.ti.ccstudio.debug.ui.targetStatus.statusBar.TargetStatusBar.fill(TargetStatusBar.java:44)
at com.ti.ccstudio.debug.ui.targetStatus.statusBar.CCSStatusBar.createControl(CCSStatusBar.java:39)
at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:105)
at org.eclipse.ui.internal.menus.CompatibilityWorkbenchWindowControlContribution.construct(CompatibilityWorkbenchWindowControlContribution.java:90)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlContribution.createControl(ToolControlContribution.java:58)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:101)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:343)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.subscribeTopicUpdateToBeRendered(ToolBarManagerRenderer.java:213)
at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4813)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:345)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarContributionRecord.updateVisibility(ToolBarContributionRecord.java:74)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$5.changed(ToolBarManagerRenderer.java:479)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:324)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processAddition(ToolBarManagerRenderer.java:471)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.generateContributions(ToolBarManagerRenderer.java:447)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContribution(ToolBarManagerRenderer.java:413)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createWidget(ToolBarManagerRenderer.java:373)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:341)
at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.processAddition(ContributionsAnalyzer.java:370)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.addTrimContributions(TrimBarRenderer.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:143)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:747)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 13:48:42.987
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1ebbf1e (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@16939e1, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1ebbf1e (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@16939e1, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized}, AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@12a5064
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException:
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:64)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:304)
at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:196)
at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:134)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:190)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:567)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:776)
Caused by: java.lang.IllegalArgumentException:
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:145)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:394)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:380)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getActivePerspective(ModelServiceImpl.java:959)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.getElementsToMinimize(MinMaxAddon.java:680)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.maximize(MinMaxAddon.java:655)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:363)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
... 150 more
!ENTRY com.ti.common.project.core 4 0 2017-12-14 13:52:17.073
!MESSAGE This project requires product 'SYS/BIOS' v6.50.1.12, or equivalent. Please install this product before importing this project.
!ENTRY com.ti.common.project.core 4 0 2017-12-14 13:57:07.598
!ENTRY com.ti.common.project.core 4 0 2017-12-14 13:59:07.594
!SESSION 2017-12-14 14:05:30.045 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:05:31.105
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:05:36.447
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:134)
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:05:36.457
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:05:36.457
!MESSAGE Widget is disposed
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.widgets.Display.error(Display.java:1262)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:747)
at org.eclipse.swt.widgets.Display.getShells(Display.java:2248)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getModalShellExcluding(ProgressManagerUtil.java:321)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getDefaultParent(ProgressManagerUtil.java:376)
at org.eclipse.ui.internal.statushandlers.InternalDialog.<init>(InternalDialog.java:155)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerImpl.java:260)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.addStatusAdapter(WorkbenchStatusDialogManagerImpl.java:197)
at org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager.addStatusAdapter(WorkbenchStatusDialogManager.java:158)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStatusAdapter(WorkbenchErrorHandler.java:95)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.access$0(WorkbenchErrorHandler.java:88)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler$1.run(WorkbenchErrorHandler.java:55)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.handle(WorkbenchErrorHandler.java:52)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handle(IDEWorkbenchErrorHandler.java:101)
at org.eclipse.ui.internal.WorkbenchErrorHandlerProxy.handle(WorkbenchErrorHandlerProxy.java:31)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:189)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:231)
at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:302)
at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:161)
at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:103)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:88)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:217)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:189)
at org.eclipse.osgi.internal.log.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
at org.eclipse.osgi.internal.log.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
at org.eclipse.osgi.internal.log.LoggerImpl.log(LoggerImpl.java:54)
at org.eclipse.osgi.internal.log.EquinoxLogFactory$1.log(EquinoxLogFactory.java:52)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:251)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:05:36.467
!MESSAGE
!STACK 0
java.lang.NullPointerException
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:209)
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:227)
at org.eclipse.ui.part.WorkbenchPart.dispose(WorkbenchPart.java:100)
at org.eclipse.ui.part.MultiPageEditorPart.dispose(MultiPageEditorPart.java:533)
at org.eclipse.ui.forms.editor.FormEditor.dispose(FormEditor.java:402)
at com.ti.dvt.internal.resource.explorer.editors.ResourceExplorerEditor.dispose(ResourceExplorerEditor.java:63)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:238)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:394)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:161)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:191)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.lang.Thread.run(Thread.java:745)
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.eclipse.swt.SWTException: Device is disposed
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:710)
at org.eclipse.ui.internal.WorkbenchWindow$9.changed(WorkbenchWindow.java:726)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:343)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
!SESSION 2017-12-14 14:05:41.047 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:05:42.128
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:05:47.016
!STACK 1
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:05:47.018
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:05:47.018
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:05:47.028
!MESSAGE
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:05:47.038
!STACK 0
!SESSION 2017-12-14 14:06:03.679 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:06:04.729
!ENTRY com.ti.common.core 4 0 2017-12-14 14:06:04.739
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:06:09.451
!STACK 1
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:06:09.461
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:06:09.461
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:06:09.471
!MESSAGE
!STACK 0
!STACK 0
!SESSION 2017-12-14 14:06:17.077 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:06:19.777
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 14:06:21.918
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@1b84841 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@1582db6, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@1b84841 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@1582db6, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), AttName=children, EventType=ADD, Position=4, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@4509b7 (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@da64f2, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)}, AttName=children, EventType=ADD, Position=4, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@4509b7 (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@da64f2, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@11be56b
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 14:06:22.679
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@11e15de (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@16e0f9d, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@11e15de (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@16e0f9d, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized}, AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@1f2e475
!STACK 0
at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
... 150 more
!ENTRY org.eclipse.ui 4 0 2017-12-14 14:06:43.038
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:354)
at org.eclipse.swt.widgets.Label.setText(Label.java:402)
at org.eclipse.jface.wizard.ProgressMonitorPart.done(ProgressMonitorPart.java:173)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:999)
at org.eclipse.rtsc.project.ui.extdiscovery.InstallExtensionSitesWizard.performFinish(InstallExtensionSitesWizard.java:92)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:790)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:423)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4410)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4228)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3816)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.rtsc.project.ui.extdiscovery.PromptExtensionSitesJob.runInUIThread(PromptExtensionSitesJob.java:97)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:97)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4203)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3819)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
!ENTRY org.eclipse.equinox.p2.updatechecker 4 0 2017-12-14 14:06:43.930
!MESSAGE Exception in update check thread
!STACK 0
org.eclipse.core.runtime.OperationCanceledException
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:125)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:156)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:735)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:657)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:166)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:106)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:768)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:668)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:151)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:129)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:73)
!ENTRY org.eclipse.core.jobs 4 2 2017-12-14 14:06:43.933
!MESSAGE An internal error occurred during: "Replace IU Job".
!STACK 0
at com.ti.ccstudio.app.center.internal.CCSAppCenter.log(CCSAppCenter.java:452)
at com.ti.ccstudio.app.center.internal.CCSAppCenter._replaceIusWithLatest(CCSAppCenter.java:420)
at com.ti.ccstudio.app.center.internal.CCSAppCenter.access$3(CCSAppCenter.java:364)
at com.ti.ccstudio.app.center.internal.CCSAppCenter$2.run(CCSAppCenter.java:240)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!SESSION 2017-12-14 14:06:44.238 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:06:49.671
!ENTRY com.ti.ccstudio.branding 4 0 2017-12-14 14:06:52.322
!MESSAGE No setBarVisibilty method for ViewIntroAdapterPart
!STACK 0
java.lang.reflect.InvocationTargetException
at com.ti.ccstudio.branding.internal.CCSIntroPart.setBarVisibility(CCSIntroPart.java:173)
at com.ti.ccstudio.branding.internal.CCSIntroPart.access$2(CCSIntroPart.java:167)
at com.ti.ccstudio.branding.internal.CCSIntroPart$4.run(CCSIntroPart.java:153)
at org.eclipse.swt.widgets.Display.release(Display.java:3873)
at org.eclipse.swt.graphics.Device.dispose(Device.java:298)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:154)
Caused by: java.lang.NullPointerException
at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:2830)
at org.eclipse.ui.internal.WorkbenchWindow.setCoolBarVisible(WorkbenchWindow.java:2627)
at org.eclipse.ui.internal.ViewIntroAdapterPart.setBarVisibility(ViewIntroAdapterPart.java:243)
... 26 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:06:52.332
!STACK 1
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.widgets.Control.setRedraw(Control.java:3671)
at com.ti.ccstudio.branding.internal.CCSIntroPart$4.run(CCSIntroPart.java:154)
... 17 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:06:52.332
!MESSAGE
!STACK 0
at org.eclipse.ui.internal.WorkbenchWindow.setPerspectiveBarVisible(WorkbenchWindow.java:2668)
at org.eclipse.ui.internal.ViewIntroAdapterPart.setBarVisibility(ViewIntroAdapterPart.java:244)
at org.eclipse.ui.internal.ViewIntroAdapterPart.dispose(ViewIntroAdapterPart.java:159)
!SESSION 2017-12-14 14:07:49.483 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:07:50.573
!ENTRY com.ti.ccstudio.branding 4 0 2017-12-14 14:07:53.300
!STACK 0
... 26 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:07:53.320
!STACK 1
... 17 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:07:53.330
!MESSAGE
!STACK 0
!SESSION 2017-12-14 14:08:17.780 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:08:20.000
!ENTRY com.ti.common.core 4 0 2017-12-14 14:08:20.010
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 14:08:21.202
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@1c44ce8 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@585e83, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@1c44ce8 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@585e83, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), AttName=children, EventType=ADD, Position=4, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@e77c5b (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@360c3b, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)}, AttName=children, EventType=ADD, Position=4, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@e77c5b (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@360c3b, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@ed692d
!STACK 0
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 14:08:21.892
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@a21ea6 (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@3426a9, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@a21ea6 (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@3426a9, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized}, AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {}, NewValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@928399
!STACK 0
... 150 more
!ENTRY com.ti.ccstudio.project.core 2 0 2017-12-14 14:15:17.447
!MESSAGE Unrecognized option setting '--elf' for tool 'com.ti.ccstudio.buildDefinitions.TMS470_16.9.exe.compilerDebug.32852887'
!ENTRY com.ti.ccstudio.project.core 2 0 2017-12-14 14:15:17.487
!MESSAGE Unrecognized option setting '--elf' for tool 'com.ti.ccstudio.buildDefinitions.TMS470_16.9.exe.compilerRelease.1026502922'
!ENTRY org.eclipse.cdt.core 1 0 2017-12-14 14:15:20.850
!MESSAGE Indexed 'high_accuracy_14xx_lab' (5 sources, 53 headers) in 1.62 sec: 3,796 declarations; 5,822 references; 67 unresolved inclusions; 0 syntax errors; 417 unresolved names (4.2%)
!ENTRY org.eclipse.cdt.core 1 0 2017-12-14 14:15:31.300
!MESSAGE Indexed 'high_accuracy_14xx_lab' (5 sources, 54 headers) in 0.772 sec: 3,799 declarations; 6,189 references; 65 unresolved inclusions; 0 syntax errors; 84 unresolved names (0.83%)
!SESSION 2017-12-14 14:19:43.912 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:19:45.152
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:19:50.097
!STACK 1
!ENTRY org.eclipse.osgi 4 0 2017-12-14 14:19:50.107
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:19:50.107
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:19:50.117
!MESSAGE
!STACK 0
at org.eclipse.ui.part.PageBookView.dispose(PageBookView.java:513)
at org.eclipse.ui.internal.console.ConsoleView.dispose(ConsoleView.java:351)
!ENTRY org.eclipse.ui.workbench 4 2 2017-12-14 14:19:50.127
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
at org.eclipse.ui.actions.RetargetAction.partDeactivated(RetargetAction.java:186)
at org.eclipse.ui.internal.PartService$4.run(PartService.java:123)
at org.eclipse.ui.internal.PartService.partDeactivated(PartService.java:120)
at org.eclipse.ui.internal.WorkbenchPage$18.run(WorkbenchPage.java:5030)
at org.eclipse.ui.internal.WorkbenchPage.firePartDeactivated(WorkbenchPage.java:5027)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:5020)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partDeactivated(WorkbenchPage.java:222)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$4.run(PartServiceImpl.java:266)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartDeactivated(PartServiceImpl.java:263)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:688)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.setPart(PartServiceImpl.java:221)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:90)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:358)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:197)
!ENTRY org.eclipse.ui.workbench 4 2 2017-12-14 14:19:50.137
!STACK 0
!STACK 0
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 2 2017-12-14 14:19:50.147
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
at org.eclipse.debug.internal.ui.actions.RetargetAction.clearPart(RetargetAction.java:218)
at org.eclipse.debug.internal.ui.actions.RetargetAction.partDeactivated(RetargetAction.java:228)
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 2 2017-12-14 14:19:50.157
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
at org.eclipse.swt.widgets.Display.getActiveShell(Display.java:1481)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getActiveWindow(WorkbenchSourceProvider.java:426)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActivePart(WorkbenchSourceProvider.java:458)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.checkActivePart(WorkbenchSourceProvider.java:296)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.checkActivePart(WorkbenchSourceProvider.java:291)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$1.partDeactivated(WorkbenchSourceProvider.java:236)
!ENTRY org.eclipse.ui.workbench 4 2 2017-12-14 14:19:50.167
!STACK 0
!STACK 0
at org.eclipse.tm.terminal.view.ui.listeners.WorkbenchPartListener.partDeactivated(WorkbenchPartListener.java:93)
at org.eclipse.ui.internal.PartService$9.run(PartService.java:188)
at org.eclipse.ui.internal.PartService.partDeactivated(PartService.java:185)
at org.eclipse.ui.internal.WorkbenchPage$19.run(WorkbenchPage.java:5039)
at org.eclipse.ui.internal.WorkbenchPage.firePartDeactivated(WorkbenchPage.java:5036)
!ENTRY org.eclipse.e4.ui.workbench 4 2 2017-12-14 14:19:50.167
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench".
!STACK 0
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partDeactivated(WorkbenchPage.java:227)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-12-14 14:19:50.167
!MESSAGE An exception occurred while notifying part listeners
!STACK 0
!STACK 0
!ENTRY org.eclipse.jface 4 0 2017-12-14 14:19:50.297
!MESSAGE An error has occurred. See error log for more details.
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:19:50.297
!STACK 0
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler$2.run(WorkbenchErrorHandler.java:63)
at org.eclipse.swt.widgets.Display.msgFilterProc(Display.java:3533)
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:19:50.307
!STACK 0
!ENTRY org.eclipse.jface 4 0 2017-12-14 14:19:50.307
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!ENTRY org.eclipse.jface 4 0 2017-12-14 14:19:50.317
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:19:50.317
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!ENTRY org.eclipse.jface 4 0 2017-12-14 14:19:50.327
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:19:50.327
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!ENTRY org.eclipse.jface 4 0 2017-12-14 14:19:50.337
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:19:50.337
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!ENTRY org.eclipse.jface 4 0 2017-12-14 14:19:50.347
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-12-14 14:19:50.347
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!STACK 0
!SESSION 2017-12-14 14:20:27.606 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2017-12-14 14:20:29.816
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 14:20:31.017
!STACK 0
!ENTRY org.eclipse.equinox.event 4 0 2017-12-14 14:20:31.697
!STACK 0
... 150 more
!SESSION 2018-02-03 19:22:30.218 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2018-02-03 19:22:37.036
!ENTRY com.ti.common.core 4 0 2018-02-03 19:22:37.052
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 19:22:56.141
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4514)
at org.eclipse.swt.widgets.Widget.checkParent(Widget.java:291)
at org.eclipse.swt.widgets.Widget.<init>(Widget.java:158)
at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:82)
at org.eclipse.swt.widgets.Composite.<init>(Composite.java:96)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.createWidget(SashRenderer.java:122)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.createElement(PartServiceImpl.java:1253)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1218)
at org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1309)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1274)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.java:4316)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4312)
at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin$1.run(IDEWorkbenchPlugin.java:367)
at org.eclipse.swt.widgets.Display.runTimer(Display.java:4329)
at org.eclipse.swt.widgets.Display.messageProc(Display.java:3418)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2552)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3814)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 19:22:56.145
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@ae402b (elementId: null, tags: [], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer@10203de, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true)
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 19:22:56.145
!STACK 0
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:58)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.createElement(PartServiceImpl.java:1257)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 19:22:56.146
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@175fb1c (elementId: org.eclipse.ui.views.ProblemView, tags: [], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer@18c6261, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: false)
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 19:22:56.147
!STACK 0
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:401)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1278)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 19:22:56.147
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 19:22:56.148
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 19:22:56.148
!STACK 0
!ENTRY org.eclipse.ui.ide 4 4 2018-02-03 19:22:56.149
!MESSAGE Could not create Problems view
!ENTRY org.eclipse.ui 4 0 2018-02-03 19:22:56.150
!MESSAGE Abnormal Workbench Condition
!ENTRY org.eclipse.osgi 4 0 2018-02-03 19:22:56.164
!STACK 1
!ENTRY org.eclipse.osgi 4 0 2018-02-03 19:22:56.187
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2018-02-03 19:22:56.188
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 19:22:56.197
!MESSAGE
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 19:22:56.200
!STACK 0
!SESSION 2018-02-03 20:08:33.686 -----------------------------------------------
!ENTRY com.ti.common.core 4 0 2018-02-03 20:08:37.346
!ENTRY com.ti.common.core 4 0 2018-02-03 20:08:37.423
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 20:08:55.070
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 20:08:55.076
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.PartSashContainerImpl@12e6b0b (elementId: null, tags: [], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer@1213a74, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (horizontal: true)
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 20:08:55.078
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 20:08:55.079
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.advanced.impl.PlaceholderImpl@37f145 (elementId: org.eclipse.ui.views.ProblemView, tags: [], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer@47c08c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (closeable: false)
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 20:08:55.080
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 20:08:55.081
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2018-02-03 20:08:55.081
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 20:08:55.082
!STACK 0
!ENTRY org.eclipse.ui.ide 4 4 2018-02-03 20:08:55.083
!ENTRY org.eclipse.ui 4 0 2018-02-03 20:08:55.083
!ENTRY org.eclipse.osgi 4 0 2018-02-03 20:08:55.100
!STACK 1
!ENTRY org.eclipse.osgi 4 0 2018-02-03 20:08:55.107
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2018-02-03 20:08:55.109
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 20:08:55.117
!MESSAGE
!STACK 0
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-02-03 20:08:55.121
!STACK 0
  • Hi Peter,
    Thanks for the log. It was analyzed by the engineering team and there various issues with creating views. Perhaps your workspace is corrupted. Could you try specifying a clean new workspace folder when launching CCS?
    ki
    I haven’t heard back from you, I’m assuming you were able to resolve your issue. If not, please post a reply with an update below (or create a new thread).
    thanks,
    ki
