CCS: CCS7 Installation Failure
One of my customers had a CCS7 installation failure twice now. I've attached the log file that was generated. Can you help determine what is wrong from this?
Thank you!
Log started 02/15/2018 at 10:57:35
Preferred installation mode : unattended
Trying to init installer in mode unattended
Mode unattended successfully initialized
[10:57:35] Found mode
Executing C:\Users\skhan\Downloads\ccs_setup_7.4.0.00015.exe --mode win32 &
Script exit code: 0
Script output:
Script stderr:
Cannot delete file C:/Users/skhan/AppData/Local/Temp/bitrock_installer_13172.log
Cannot delete file C:/Users/skhan/AppData/Local/Temp/bitrock_installer_21448.log
[10:57:41] Windows 10 0
[10:57:41] installer_command_line_arguments :
[10:57:42] installer_command_line_arguments :
[10:57:42] Product Name Code Composer Studio 7.4.0
[10:57:42] Product Version 7.4.0.00015
[10:57:42]
Preparing to Install
Unpacking files
Unpacking files
Unpacking files
Unpacking files
Unpacking files
Unpacking files
Unpacking files
[10:57:55] admin = 1
[10:57:55] installertype = setup
[10:57:55]
[10:57:55] running C:\Users\skhan\AppData\Local\Temp/ccs_cea59477-ff9d-417c-4c98-fac40eaf42c2\tcl\bin\tclsh "C:/Users/skhan/AppData/Local/Temp/ccs_cea59477-ff9d-417c-4c98-fac40eaf42c2/installer_tcl/main_frontend/main.tcl" --installersrc "C:/Users/skhan/Downloads" --installertmp "C:/Users/skhan/AppData/Local/Temp/ccs_cea59477-ff9d-417c-4c98-fac40eaf42c2"  --buildid 7.4.0.00015 --installer "C:/Users/skhan/Downloads/ccs_setup_7.4.0.00015.exe" --bitness 64-bit --os windows --osname "Windows 10" --spversion "0" --timestamp 20180215105741 --AVon true
Executing C:\Users\skhan\AppData\Local\Temp/ccs_cea59477-ff9d-417c-4c98-fac40eaf42c2\tcl\bin\tclsh "C:/Users/skhan/AppData/Local/Temp/ccs_cea59477-ff9d-417c-4c98-fac40eaf42c2/installer_tcl/main_frontend/main.tcl" --installersrc "C:/Users/skhan/Downloads" --installertmp "C:/Users/skhan/AppData/Local/Temp/ccs_cea59477-ff9d-417c-4c98-fac40eaf42c2"  --buildid 7.4.0.00015 --installer "C:/Users/skhan/Downloads/ccs_setup_7.4.0.00015.exe"  --bitness 64-bit --os windows --osname "Windows 10" --spversion "0" --timestamp 20180215105741 --AVon true
Script exit code: 0
Script output:
 Buildfile: c:/ti/ccsv7/eclipse/downloads/ccs_p2_mirror.xml
create-mirror:
BUILD SUCCESSFUL
BUILD SUCCESSFUL
Total time: 1 minute 2 seconds
Script stderr:
 Error from thread tid00003A20
target thread died
    while executing
"thread::send $m_threadId [subst { $m_display reportError {$msg} } ]"
    (object "::threadedProgressUpdate0" method "::ThreadedProgressUpdate::reportError" body line 3)
    invoked from within
"$progress reportError $msg"
    (procedure "RunInstall" line 10)
    invoked from within
"RunInstall c:/ti/ccsv7/eclipse/ccs_config.xml 2 0 0 0 c:/ti/ccsv7/install_logs/20180215105741/ccs_setup_7.4.0.00015_install.log ::progressPane0 tid000..."
called Tcl_FindHashEntry on deleted table
[11:11:57] Buildfile: c:/ti/ccsv7/eclipse/downloads/ccs_p2_mirror.xml
create-mirror:
BUILD SUCCESSFUL
BUILD SUCCESSFUL
[11:11:57] Error from thread tid00003A20
target thread died
    while executing
    invoked from within
    invoked from within
[11:11:57]
                                    launchCCS:0
                                    createDesktopShortcut:0
                                    createStartMenuShortcut:0
                                    eclipsedir:c:/ti/ccsv7/eclipse
