Part Number: TMS320F28335
I have the Uniflash-UI properly loading my 28335 out-file, but when I built the standalone-command-line, it fails the final verifying-program step (reports Failed: File: user_files/images/Unified.out: a data verification error occurred, file load failed); see the attached cmd-line output. Any advice or suggestions here
would be appreciated.
Jim
C:\Users\JJollota.ESIMOTION\Downloads\unified_xds110>dslite
Executing default command:
> dslite --mode flash -c user_files/configs/f28335.ccxml -l user_files/settings/
generated.ufsettings -e -f -v user_files/images/Unified.out
DSLite version 8.0.0.1191
Configuring Debugger (may take a few minutes on first launch)...
Parsing connections/TIXDS110_Connection.xml
Parsing drivers/tixds510c28x.xml
Parsing devices/f28335.xml
Parsing ../cpus/c28xx.xml
Parsing ..\Modules\C28xNotVisible.xml
Parsing ../Modules/C2000/C2000_FPU32_Registers.xml
Parsing ../Modules/C2000/C2000_ADC_Type2_Registers.xml
Parsing ../Modules/C2000/C2000_ADC_Type2_Mirror_Registers.xml
Parsing ../Modules/C2000/28x3x_System_Control_Registers.xml
Parsing ../Modules/C2000/C2000_Code_Security_Module_Registers.xml
Parsing ../Modules/C2000/C2000_PWL_Registers.xml
Parsing ../Modules/C2000/C2000_CPU_Timer_Registers.xml
Parsing ../Modules/C2000/28x3x_Device_Emulation_Registers.xml
Parsing ../Modules/C2000/C2000_DMA_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_eCAN_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_eCAN_Type0_Local_Acceptance_Masks.xml
Parsing ../Modules/C2000/C2000_eCAN_Type0_Message_Object_Time_Stamps.xml
Parsing ../Modules/C2000/C2000_eCAN_Type0_Message_Object_TimeOut.xml
Parsing ../Modules/C2000/C2000_eCAN_Type0_Mailbox_Registers.xml
Parsing ../Modules/C2000/C2000_eCAP_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_ePWM_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_ePWM_Mirror_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_eQEP_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_Flash_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_External_Interface_Type1_Registers.xml
Parsing ../Modules/C2000/28x3x_External_Interrupt_Registers.xml
Parsing ../Modules/C2000/28x3x_GPIO_Registers.xml
Parsing ../Modules/C2000/C2000_McBSP_Type1_Registers.xml
Parsing ../Modules/C2000/C2000_I2C_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_PIE_Registers.xml
Parsing ../Modules/C2000/C2000_SCI_Type0_Registers.xml
Parsing ../Modules/C2000/C2000_SPI_Type0_Registers.xml
Initializing Register Database...
Parsing C:\Users\JJOLLO~1.ESI\AppData\Local\TEXASI~1\CCS\DOWNLO~1\1\0\36
4183034.cache
Initializing: C28xx
Mapping registers: C28xx - Core Registers
Mapping registers: C28xx - FPU
Mapping registers: C28xx - ADC
Mapping registers: C28xx - ADCMIRROR
Mapping registers: C28xx - SYSCTRL
Mapping registers: C28xx - CSM
Mapping registers: C28xx - PWL
Mapping registers: C28xx - CPUTIMER
Mapping registers: C28xx - DEVEMU
Mapping registers: C28xx - DMA
Mapping registers: C28xx - eCANA
Mapping registers: C28xx - eCANA_LAM
Mapping registers: C28xx - eCANA_MOTS
Mapping registers: C28xx - eCANA_MOTO
Mapping registers: C28xx - eCANA_MBX_CONTENT
Mapping registers: C28xx - eCANB
Mapping registers: C28xx - eCANB_LAM
Mapping registers: C28xx - eCANB_MOTS
Mapping registers: C28xx - eCANB_MOTO
Mapping registers: C28xx - eCANB_MBX_CONTENT
Mapping registers: C28xx - eCAP1
Mapping registers: C28xx - eCAP2
Mapping registers: C28xx - eCAP3
Mapping registers: C28xx - eCAP4
Mapping registers: C28xx - eCAP5
Mapping registers: C28xx - eCAP6
Mapping registers: C28xx - ePWM1
Mapping registers: C28xx - ePWM2
Mapping registers: C28xx - ePWM3
Mapping registers: C28xx - ePWM4
Mapping registers: C28xx - ePWM5
Mapping registers: C28xx - ePWM6
Mapping registers: C28xx - ePWM1_Mirror
Mapping registers: C28xx - ePWM2_Mirror
Mapping registers: C28xx - ePWM3_Mirror
Mapping registers: C28xx - ePWM4_Mirror
Mapping registers: C28xx - ePWM5_Mirror
Mapping registers: C28xx - ePWM6_Mirror
Mapping registers: C28xx - eQEP1
Mapping registers: C28xx - eQEP2
Mapping registers: C28xx - FLASH
Mapping registers: C28xx - XINTF
Mapping registers: C28xx - GPIO
Mapping registers: C28xx - McBSPA
Mapping registers: C28xx - McBSPB
Mapping registers: C28xx - I2CA
Mapping registers: C28xx - PIE
Mapping registers: C28xx - SCIA
Mapping registers: C28xx - SCIB
Mapping registers: C28xx - SCIC
Mapping registers: C28xx - SPIA
Mapping registers: C28xx - Hidden
Building search data: C28xx
Applying virtual groups: C28xx - DMA
Applying virtual groups: C28xx - eCANA_MBX_CONTENT
Applying virtual groups: C28xx - eCANB_MBX_CONTENT
Executing Startup Scripts: C28xx
Connecting...
Loading Program: user_files/images/Unified.out
Preparing ...
.cinit: 0 of 6032 at 0x31f8ea
Erasing Flash Sectors.
Erasing Sector A
Erasing Sector B: 12%
Erasing Sector C: 25%
Erasing Sector D: 37%
Erasing Sector E: 50%
Erasing Sector F: 62%
Erasing Sector G: 75%
Erasing Sector H: 87%
.text: 0 of 27602 at 0x313242: 3%
codestart: 0 of 4 at 0x33fff6: 17%
bootfuncs: 0 of 1652 at 0x300000: 17%
appEntry: 0 of 66 at 0x308000: 18%
ramfuncs: 0 of 20316 at 0x308040: 18%
.stack: 0 of 3424 at 0x50: 28%
.econst: 0 of 70788 at 0x30a800: 30%
.econst: 32752 of 70788 at 0x30a800: 47%
.econst: 65504 of 70788 at 0x30a800: 64%
boot_const: 0 of 512 at 0x307000: 67%
SlowProgram: 0 of 61908 at 0x318000: 67%
SlowProgram: 32752 of 61908 at 0x318000: 84%
Finished: 84%
Setting PC to entry point.: 84%
Verifying Program: user_files/images/Unified.out
Preparing ...
error: C28xx: File Loader: Verification failed: Values at address 0x00000050@Dat
a do not match Please verify target memory and memory map.
Finished: 28%
file load failed.
