Other Parts Discussed in Thread: OMAP-L138
Hi all
If you run the ARM hex utility hex470 from the command line, you see a reference point to a '--entrypoint' parameter:
> hex470 --help
TMS470 Hex Converter v4.6.3
Tools Copyright (c) 1996-2010 Texas Instruments Incorporated
General Options:
--byte,-byte Output as bytes rather than target addressing
--entrypoint,-e=addr Specify entrypoint address or symbol name
--exclude,-exclude=section Exclude section from hex conversion
--fill,-fill=val Specify fill value
--help,-options,-h Display help
--image,-image Select image mode
--linkerfill,-linkerfill Include linker fill sections in images
--map,-map=file Specify map file name
--memwidth,-memwidth=width Specify memory width
--olength,-olength=num Number of data items per line of hex output
--outfile,-o=file Specify output file names
--quiet,-quiet,-q Quiet Operation
--romwidth,-romwidth=width Specify rom width
--zero,-zero,-z Zero based addressing
Is this parameter actually supported?. We possible have a use for this useful-sounding feature, but trying to have a '-e' entry in our command file doesn't seem to have any effect.
Jon Nicoll
