CCS: CCS from command line in macOS
Other Parts Discussed in Thread: CCSTUDIO
Hi folks,
has anyone used CCS from the command line in macOS?
As far as I can see here, it only supports a command line interface under Windows and Linux.
Any input will be greatly appreciated.
Thanks in advance.
Manuel
  • Manuel,
    I would expect it to work. You would need to use the linux version of the commands shown at the link. I will give this a try on Monday.
    John
  • Hi John,
    thanks a lot for your reply!
    Following your advice of trying the Linux commands, I have managed to get the builds up and running under macOS.
    For that, I've had to navigate to the directory /Applications/ti/Code Composer Studio 8.0.0/Contents/MacOS where the ccstudio executable lives. From there, I've run this command:
    ./ccstudio -noSplash -data "/Users/manuelpeirone/Documents/CCS8_macOS/" -application com.ti.ccstudio.apps.projectBuild -ccs.projects newProject -ccs.configuration Debug
    which successfully builds the Debug configuration.
    Again, thanks a lot!
    Manuel
  • Great.
    I will update the page with the info.
    John
