CCS/TMS320C6678: code composer building error
Part Number: TMS320C6678
Product 'com.ti.sdo.edma3' v2.11.5 is not currently installed and no compatible version is available.
i am getting following error while building project. I have already installed MCSDK 02_01_02_06 latest version.
please help why this error is occuring?
    It looks like CCS did not find the EDMA3 package. Assuming that the EDMA3 package was installed on your machine, check the list of discovered products and see if you see an entry like the below:
    If not, please use the 'Rediscover' button to have CCS search for new products to install.
    ki
  • thanks for help.
    But while building FMC667WebUART in code composer studion i am getting so many errors of
    redefinition of variables as well as memory range already been specified.
    about 103 errors
    i am not able to find out where is the mistake.
    It sounds like errors due to multiple linker command files defining the same memory range. Is FMC667WebUART an example from the SDK or is this your own project?
    ki
  • it is an example from SDK not my project. as far as i know only one linker command file is there named linker.cmd, earlier there were 2 but i removed one but still i get lot of errors
    i am tryin to communicate with TMS320C6678 dsp
    here is a snap of build log
    **** Build of configuration Debug for project FMC667WebUART ****
    "C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
    'Building target: FMC667WebUART.out'
    'Invoking: C6000 Linker'
    "C:/ti/ccsv6/tools/compiler/c6000_7.4.18/bin/cl6x" -mv6600 --abi=eabi -g --diag_warning=225 --display_error_number -z -m"FMC667WebUART.map" -i"C:/ti/ccsv6/tools/compiler/c6000_7.4.18/lib" -i"C:/ti/ccsv6/tools/compiler/c6000_7.4.18/include" --reread_libs --warn_sections --xml_link_info="FMC667WebUART_linkInfo.xml" --rom_model -o "FMC667WebUART.out" "./client.obj" "./platform_osal.obj" "./resourcemgr.obj" "./webpage.obj" "./fmc667/Debug/configPkg/package/cfg/client_pe66.obj" "./fmc667/Debug/configPkg/package/package_configPkg.obj" "../linker.cmd" -l"configPkg/linker.cmd" -llibc.a -l"C:/dev/ws/ccs/FMC667WebUART/platform_library/4dsp.platform.fmc667.ae66"
    <Linking>
    "configPkg/linker.cmd", line 44: error #10263: MSMCSRAM memory range has
    "configPkg/linker.cmd", line 44: error #10264: MSMCSRAM memory range overlaps
    existing memory range MSMCSRAM
    "configPkg/linker.cmd", line 45: error #10263: L1DSRAM memory range has already
    been specified
    "configPkg/linker.cmd", line 45: error #10264: L1DSRAM memory range overlaps
    existing memory range L1DSRAM
    "configPkg/linker.cmd", line 46: error #10263: L1PSRAM memory range has already
    been specified
    "configPkg/linker.cmd", line 46: error #10264: L1PSRAM memory range overlaps
    existing memory range L1PSRAM
    "configPkg/linker.cmd", line 47: error #10263: L2SRAM memory range has already
    been specified
    "configPkg/linker.cmd", line 47: error #10264: L2SRAM memory range overlaps
    existing memory range L2SRAM
    "configPkg/linker.cmd", line 48: error #10263: DDR3 memory range has already
    been specified
    "configPkg/linker.cmd", line 48: error #10264: DDR3 memory range overlaps
    existing memory range DDR3
    "configPkg/linker.cmd", line 49: error #10263: DDR3CFG memory range has already
    been specified
    "configPkg/linker.cmd", line 49: error #10264: DDR3CFG memory range overlaps
    existing memory range DDR3CFG
    "configPkg/linker.cmd", line 50: error #10264: BOOT memory range overlaps
    "configPkg/linker.cmd", line 155: warning #10190-D: absolute symbol
    "xdc_runtime_Startup__EXECFXN__C" being redefined
    "configPkg/linker.cmd", line 156: warning #10190-D: absolute symbol
    "xdc_runtime_Startup__RESETFXN__C" being redefined
    "configPkg/linker.cmd", line 157: warning #10190-D: absolute symbol "TSK_idle"
    being redefined
    "configPkg/linker.cmd", line 179: warning #10190-D: absolute symbol "_argsize"
    being redefined
    error #10056: symbol "ti_sysbios_knl_Task_numPriorities__C" redefined: first
    defined in "./fmc667/Debug/configPkg/package/cfg/client_pe66.obj"; redefined
    in
    "C:\dev\ws\ccs\FMC667WebUART\Debug\configPkg\package\cfg\client_pe66.oe66"
    error #10056: symbol "xdc_runtime_LoggerBuf_level3Mask__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_timers_timer64_Timer_Object__PARAMS__C"
    redefined: first defined in
    "./fmc667/Debug/configPkg/package/cfg/client_pe66.obj"; redefined in
    error #10056: symbol "xdc_runtime_Startup_Module__loggerFxn4__C" redefined:
    first defined in "./fmc667/Debug/configPkg/package/cfg/client_pe66.obj";
    redefined in
    error #10056: symbol "ti_sysbios_BIOS_cpuFreq__C" redefined: first defined in
    error #10056: symbol "xdc_runtime_LoggerBuf_TimestampProxy_get64__E" redefined:
    redefined in
    error #10056: symbol "xdc_runtime_Defaults_Module__gatePrms__C" redefined:
    redefined in
    error #10056: symbol "xdc_runtime_SysStd_Module__gatePrms__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_hal_Timer_Module__gateObj__C" redefined: first
    in
    error #10056: symbol "xdc_runtime_LoggerBuf_write2__E" redefined: first defined
    in "./fmc667/Debug/configPkg/package/cfg/client_pe66.obj"; redefined in
    error #10056: symbol "ti_sysbios_hal_Hwi_HwiProxy_Proxy__abstract__S"
    error #10056: symbol "xdc_runtime_Error_policy__C" redefined: first defined in
    error #10056: symbol "xdc_runtime_Core_Module__loggerObj__C" redefined: first
    in
    error #10056: symbol "xdc_runtime_IModule_Interface__BASE__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_BIOS_Object__table__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_family_c66_tci66xx_CpIntc_numSysInts__C"
    error #10056: symbol "xdc_runtime_LoggerBuf_level4Mask__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi8" redefined: first defined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi9" redefined: first defined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi6" redefined: first defined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi7" redefined: first defined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi4" redefined: first defined in
    error #10056: symbol "xdc_runtime_Memory_Module__startupDoneFxn__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi5" redefined: first defined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi2" redefined: first defined in
    error #10056: symbol "xdc_runtime_Startup_lastFxns__A" redefined: first defined
    error #10056: symbol "ti_sysbios_family_c64p_Hwi3" redefined: first defined in
    error #10056: symbol "xdc_runtime_Startup_lastFxns__C" redefined: first defined
    error #10056: symbol "ti_sysbios_family_c64p_Hwi0" redefined: first defined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi1" redefined: first defined in
    error #10056: symbol "ti_sysbios_heaps_HeapBuf_Module__startupDone__F"
    error #10056: symbol "ti_sysbios_BIOS_RtsGateProxy_query__E" redefined: first
    in
    error #10056: symbol "ti_sysbios_family_c66_Cache_atomicBlockSize__C"
    error #10056: symbol "ti_sysbios_family_c64p_Hwi_Module__loggerFxn4__C"
    error #10056: symbol "xdc_runtime_Memory_Module__loggerFxn2__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_knl_Clock_Module__state__V" redefined: first
    in
    error #10056: symbol "ti_sysbios_knl_Semaphore_Module__startupDoneFxn__C"
    error #10056: symbol "ti_sysbios_heaps_HeapBuf_Module__startupDone__S"
    error #10056: symbol "ti_sysbios_timers_timer64_Timer_Module__id__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_knl_Swi_taskRestore__C" redefined: first
    in
    error #10056: symbol "xdc_runtime_System_putch__E" redefined: first defined in
    error #10056: symbol "ti_sysbios_knl_Queue_Module__diagsEnabled__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_gates_GateHwi_Module__startupDoneFxn__C"
    error #10056: symbol "xdc_runtime_Core_Module__loggerDefined__C" redefined:
    redefined in
    error #10056: symbol "xdc_runtime_Error_Object__sizeof__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_heaps_HeapMem_Module__loggerDefined__C"
    error #10056: symbol "ti_sysbios_family_c66_Cache_Object__table__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_timers_timer64_Timer_Object__delete__S"
    error #10056: symbol "xdc_runtime_LoggerBuf_Object__create__S" redefined: first
    in
    error #10056: symbol "ti_sysbios_gates_GateMutex_Object__DESC__C" redefined:
    redefined in
    error #10056: symbol "xdc_runtime_Assert_Module__loggerDefined__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi_Module__diagsEnabled__C"
    error #10056: symbol "ti_sysbios_knl_Clock_Object__create__S" redefined: first
    in
    error #10056: symbol "ti_sysbios_heaps_HeapBuf_Module__loggerDefined__C"
    error #10056: symbol "xdc_runtime_Memory_HeapProxy_Object__delete__S"
    error #10056: symbol "ti_sysbios_knl_Semaphore_Module__startupDone__S"
    "ti_sysbios_family_c64p_EventCombiner_Module__loggerFxn1__C" redefined:
    redefined in
    "ti_sysbios_family_c66_tci66xx_CpIntc_Module__loggerFxn1__C" redefined:
    redefined in
    error #10056: symbol "xdc_runtime_Error_getSite__E" redefined: first defined in
    error #10056: symbol "ti_sysbios_knl_Semaphore_Object__get__S" redefined: first
    in
    error #10056: symbol "xdc_runtime_Startup_execImpl__C" redefined: first defined
    error #10056: symbol "ti_sysbios_hal_Timer_TimerProxy_startup__E" redefined:
    redefined in
    error #10056: symbol "xdc_runtime_Registry_getModuleName__E" redefined: first
    in
    error #10056: symbol "ti_sysbios_timers_timer64_Timer_Module__diagsMask__C"
    error #10056: symbol "ti_sysbios_gates_GateMutex_Instance_State_sem__O"
    error #10056: symbol "ti_sysbios_knl_Semaphore_Module__loggerFxn1__C"
    error #10056: symbol "ti_sysbios_gates_GateMutex_Object__destruct__S"
    error #10056: symbol "ti_sysbios_hal_Timer_TimerProxy_getExpiredCounts__E"
    error #10056: symbol "xdc_runtime_Assert_Module__loggerFxn8__C" redefined:
    redefined in
    error #10056: symbol "xdc_runtime_Text_Module__gateObj__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_knl_Idle_Module__loggerDefined__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_hal_Hwi_HwiProxy_clearInterrupt__E" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_knl_Swi_Module__diagsEnabled__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_timers_timer64_Timer_startupNeeded__C"
    error #10056: symbol "ti_sysbios_knl_Swi_Object__count__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_knl_Idle_funcList__C" redefined: first defined
    error #10056: symbol "ti_sysbios_hal_Cache_CacheProxy_Module__startupDone__S"
    error #10056: symbol "ti_sysbios_knl_Queue_Module__loggerFxn4__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_knl_Idle_funcList__A" redefined: first defined
    error #10056: symbol "ti_sysbios_heaps_HeapBuf_Module__diagsMask__C" redefined:
    redefined in
    error #10056: symbol "ti_sysbios_family_c64p_Exception_Module__loggerObj__C"
    error #10056: symbol "ti_sysbios_family_c64p_Hwi14" redefined: first defined in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi15" redefined: first defined in
    >> Compilation failure
    makefile:156: recipe for target 'FMC667WebUART.out' failed
    error #10056: symbol "ti_sysbios_knl_Task_Module__root__V" redefined: first
    in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi10" redefined: first defined in
    error #10056: symbol "ti_csl_Settings_Object__count__C" redefined: first
    in
    error #10056: symbol "ti_sysbios_family_c64p_Hwi11" redefined: first defined in
    error #10056: symbol "ti_sysbios_heaps_HeapBuf_Module__id__C" redefined: first
    in
    fatal error #99900: error limit reached; 100 errors detected
    gmake: *** [FMC667WebUART.out] Error 1
    gmake: Target 'all' not remade because of errors.
    **** Build Finished ****
    I have the MCSDK installed but I can't seem to find the example. Can you point me to the exact location this example?
    ki
  • Thanks Ki i have solved the issue thanks for your kind help.
