How to create an Array in the xdc/cfg file (ccs4/bios6x)
Hi folks,
I make my first experiences with the CCS4 and Bios6x. I studied the manuals and found out that the language for the xdc/cfg-file is like JavaScript.
Now I want to create 4 egal threads and I want to store the handles in one array. My idea is to use the following lines:
for( var i = 0; i < 4; i++ ) {
  TaskParams.arg0 = i;
  Program.global.TaskHandle[ i ] = Task.create( '&MyTask', TaskParams );
Does anyone have an idea how this could be realised? I tried different things but I got always an error during the generation.
Thanks alot, Jürgen
  • Hello TI,
    I am looking for an answer for my previous posting.
    Is there anybody how is able to handle questions regarding xdc/cfg-files? Or does anybody know the differences between xdc/cfg-files and JavaScript?
    Regards, Juergen
  • Hi Juergen,
    I would recommend asking in both the BIOS and RTSC forums. There is a lot more expertise on XDC and JavaScript in there:
    BIOS: http://e2e.ti.com/support/embedded/f/355.aspx
    RTSC: http://www.eclipse.org/forums/index.php?t=thread&frm_id=8
    ki
  • Hi Juergen,
    Sorry we missed your earlier post. The best place to get your questions on RTSC and SYS/BIOS answered is the BIOS forum - http://e2e.ti.com/support/embedded/f/355.aspx
    Answers to your previous queries are given below.
    You can do the following to statically create tasks in your config script:
    for (var i = 0;i < 4;i++) {
    Program.global["task"+i] = Task.create('&MyTask', tskParams);
    This will create global symbols "task0", "task1","task2","task3" - which are the task handles that you can access in your application 'C' code.
    The config script  (*.cfg) is essentially Javascript with some built in global objects that are used by our tools. Take a look at the following for more details:
    http://rtsc.eclipse.org/docs-tip/Glossary#Configuration_Script
    http://rtsc.eclipse.org/docs-tip/Glossary#XDCscript
    Amit
  • Hi Ki, hi Amit,
    thank you very much for the answers. The logic behind the forums is not easy to recognise and the topics are often not really helpful to identify the origin-direction of the thread. E.g. I wrote my original post in an other thread and the admin shifted it to this forum.
    Your tip, Amit, was very helpful. It fullfills my needs. I can convert the global symbols to an array in my 'C' code.
    Juergen
