Hello, i tried to install CCS V8 on windows 10 but the following message appears (attach a picture) and the program is not installed. I have installed CCS V7.4.
What could the issue?
Thanks for your help.
Hello friend, i answer thw question in blue:
Does any install logs at all get generated? The logs would be in the a sub directory (.\ccsv8\install_logs) inside the folder you chose to install CCS in. There is no log file. Not even the installer created the installation folder as you suggest (\ ccsv8 \).
The only message when i try to install the program, is the sended in the first message, then the message dialogue box disappears.
Is there anything else i can try?
Thanks.
Could you please try the installer without the --mode win32 parameter. Initial logs are generated in the %TEMP% folder. Look for the latest bitrock*.log file there and post it here, please.
Danish
Hello, issue resolved. The problem was related with failed update on CCS 7.4 installed on my PC.
Javier
