Part Number: CCSTUDIO
<<<<<<< HEAD
<tool id="com.ti.ccstudio.buildDefinitions.C2000_18.1.exe.linkerDebug.1668533935" name="C2000 Linker" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.exe.linkerDebug">
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.STACK_SIZE.911069221" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.STACK_SIZE" value="0x300" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.MAP_FILE.530824030" name="Link information (map) listed into <file> (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.MAP_FILE" value=""${ProjName}.map"" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.OUTPUT_FILE.1806167340" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.OUTPUT_FILE" value="${ProjName}.out" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.HEAP_SIZE.1215036372" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.HEAP_SIZE" value="0x1000" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.LIBRARY.1438709028" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.LIBRARY" valueType="libs">
<tool id="com.ti.ccstudio.buildDefinitions.C2000_18.1.exe.linkerDebug.1590935836" name="C2000 Linker" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.exe.linkerDebug">
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.STACK_SIZE.320286391" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.STACK_SIZE" value="0x300" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.MAP_FILE.1133785637" name="Link information (map) listed into <file> (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.MAP_FILE" value=""${ProjName}.map"" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.OUTPUT_FILE.1058549657" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.OUTPUT_FILE" value="${ProjName}.out" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.HEAP_SIZE.1848926761" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.HEAP_SIZE" value="0x040" valueType="string"/>
<option id="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.LIBRARY.1215328020" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.C2000_18.1.linkerID.LIBRARY" valueType="libs">
>>>>>>> develop
The .cproject is often unmergeable and we end up just manually reapplying one set of changes on another. Above is a case where we actually made the same change in two branches and the merge resulted in conflicts primarily because of the numbers at the end of the option id field. Why do these exist? Why are the different each time?
Cheers,
-kyle
