CCS/TMS320F2811: Program crashes when calling Flash28
Part Number: TMS320F2811
Issue: Problem with flash program after converting project from Code Composer Version 6 to Code Composer Version 8.
           Program crashes.
           Program crashes when trying to access “Flash28_Prog.c”
Processor Map file CC v6 - Good:
Flash28_API
*         0   003e4000   0000020e     RUN ADDR = 00008d45
                                 003e4000   000000a4     Flash2811_API_V210.lib : Flash28_Prog.obj (.text)
                                003e40a4   0000008d                           : Flash28_Internals.obj (.text)
                                003e4131   0000007f                           : Flash28_Prog_Pulse.obj (.text)
                                003e41b0   00000047                           : Flash28_Init.obj (.text)
                                003e41f7   0000000d                           : Flash28_Delay.obj (.text)
                                003e4204   00000007                           : Flash28_DisInt.obj (.text)
                                003e420b   00000003                           : Flash28_Version_Hex.obj (.text)
Processor Map File CC V8 – Bad:
SECTION ALLOCATION MAP
               output                                 attributes/
section   page   origin     length       input sections
Flash28_API
*          0   00008000   00000000     UNINITIALIZED
Could be that in the conversion I changed something else that could affect this but running a difference on the files nothing is obvious.
