CCS: Installing CCSv8 from command line in Linux
I need to install CCSv8 in linux in a automated way without user interaction. I guess if I provide some options to the installer, e.g. ccs_setup_linux64_8.1.0.00011.bin, this can be done? What should be the right options?
Jianzhong
  • If you want to install all of CCS, you can do the following:
    ccs_setup_linux64_8.1.0.00011.bin --mode unattended --prefix <installdir>
    Make sure <installdir> is a directory you can write to.
    Also note, those are 2 dashes in front of mode and prefix.
    If you want to install part of it, you have to generate a response file but that requires you to run the installer in GUI mode. Let me know if you need to do so, and I'll update this post.
    Danish
  • I meant to say " but that requires you to run the installer in GUI mode, at least once"
  • Log started 08/02/2018 at 20:08:38
    Preferred installation mode : unattended
    Trying to init installer in mode unattended
    Mode unattended successfully initialized
    [20:08:39] Found mode unattended
    [20:08:39] Ubuntu 14.04.5 LTS
    [20:08:39] installer_command_line_arguments : --mode unattended --prefix /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0
    [20:08:39] Product Name Code Composer Studio 8.1.0
    [20:08:39] Product Version 8.1.0.00011
    [20:08:39] --mode unattended --prefix /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0
    Preparing to Install
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    [20:08:39] admin = 0
    [20:08:39] installertype = setup
    [20:08:39] ccsinstaller_name ccs_setup_linux64_8.1.0.00011.bin
    [20:08:39] Installer: /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccs_setup_linux64_8.1.0.00011.bin
    Executing chmod -R 777 "/tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/tcl"
    Script exit code: 0
    Script output:
    Script stderr:
    Executing chmod -R 777 "/tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/util"
    Script exit code: 0
    Script output:
    Script stderr:
    Executing chmod -R 777 "/tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/dependency-checker"
    Script exit code: 0
    Script output:
    Script stderr:
    [20:08:41]
    [20:08:41] running /tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/tcl/bin/tclsh.sh  "/tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/installer_tcl/main_frontend/main.tcl" --installersrc "/home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0" --installertmp "/tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87" --mode unattended --prefix /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0 --buildid 8.1.0.00011 --installer "/home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccs_setup_linux64_8.1.0.00011.bin" --bitness 64-bit --os linux-x64 --osname "Ubuntu 14.04.5 LTS" --spversion "" --timestamp 20180802200839 --AVon false --tl false
    Executing /tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/tcl/bin/tclsh.sh "/tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/installer_tcl/main_frontend/main.tcl" --installersrc "/home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0" --installertmp "/tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87" --mode unattended --prefix /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0 --buildid 8.1.0.00011 --installer "/home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccs_setup_linux64_8.1.0.00011.bin" --bitness 64-bit --os linux-x64 --osname "Ubuntu 14.04.5 LTS" --spversion "" --timestamp 20180802200839 --AVon false --tl false
    Script exit code: 0
    Script output:
     Ignoring Warning: Path of /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0 exceeds the suggested limit of 40 characters; this may cause installation failure should you decide to install MSP430ware.
    Buildfile: /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccsv8/eclipse/downloads/ccs_p2_mirror.xml
    create-mirror:
    Eclipse:
    An error has occurred. See the log file
    /tmp/ccs_c60d32c0-01af-468d-7a90-6cdd42442a87/workspace/.metadata/.log.
    Script stderr:
    BUILD FAILED
    /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccsv8/eclipse/downloads/ccs_p2_mirror.xml:3: java.lang.InternalError: java.io.FileNotFoundException: /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccsv8/eclipse/jre/lib/ext/dnsns.jar
    	at sun.misc.URLClassPath$JarLoader.getResource(URLClassPath.java:1003)
    	at sun.misc.URLClassPath.getResource(URLClassPath.java:212)
    	at java.net.URLClassLoader$1.run(URLClassLoader.java:365)
    	at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
    	at java.security.AccessController.doPrivileged(Native Method)
    	at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
    	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
    	at java.lang.ClassLoader.loadClass(ClassLoader.java:411)
    	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
    	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
    	at java.net.URL.getURLStreamHandler(URL.java:1179)
    	at java.net.URL.<init>(URL.java:599)
    	at java.net.URL.<init>(URL.java:490)
    	at java.net.URL.<init>(URL.java:439)
    	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.isURL(AbstractRepositoryManager.java:755)
    	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:710)
    	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:657)
    	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.doCreateRepository(AbstractRepositoryManager.java:274)
    	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.createRepository(MetadataRepositoryManager.java:41)
    	at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.createMemoryComposite(CompositeMetadataRepository.java:72)
    	at org.eclipse.equinox.p2.internal.repository.tools.AbstractApplication.getCompositeMetadataRepository(AbstractApplication.java:253)
    	at org.eclipse.equinox.p2.internal.repository.tools.tasks.AbstractRepositoryTask.prepareIUs(AbstractRepositoryTask.java:179)
    	at org.eclipse.equinox.p2.internal.repository.tools.tasks.MirrorTask.execute(MirrorTask.java:60)
    	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:293)
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    	at java.lang.reflect.Method.invoke(Method.java:498)
    	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
    	at org.apache.tools.ant.Task.perform(Task.java:348)
    	at org.apache.tools.ant.Target.execute(Target.java:435)
    	at org.apache.tools.ant.Target.performTasks(Target.java:456)
    	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1405)
    	at org.apache.tools.ant.Project.executeTarget(Project.java:1376)
    	at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
    	at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:36)
    	at org.apache.tools.ant.Project.executeTargets(Project.java:1260)
    	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:712)
    	at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:573)
    	at org.eclipse.ant.core.AntRunner.run(AntRunner.java:511)
    	at org.eclipse.ant.core.AntRunner.start(AntRunner.java:608)
    	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
    	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
    	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
    	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
    	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
    Caused by: java.io.FileNotFoundException: /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccsv8/eclipse/jre/lib/ext/dnsns.jar
    	at sun.misc.URLClassPath$JarLoader.getJarFile(URLClassPath.java:891)
    	at sun.misc.URLClassPath$JarLoader.access$700(URLClassPath.java:756)
    	at sun.misc.URLClassPath$JarLoader$1.run(URLClassPath.java:838)
    	at sun.misc.URLClassPath$JarLoader$1.run(URLClassPath.java:831)
    	at sun.misc.URLClassPath$JarLoader.ensureOpen(URLClassPath.java:830)
    	at sun.misc.URLClassPath$JarLoader.getResource(URLClassPath.java:1001)
    	... 57 more
    Total time: 36 seconds
    Eclipse: Cannot open display:
    [20:10:56] Ignoring Warning: Path of /home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0 exceeds the suggested limit of 40 characters; this may cause installation failure should you decide to install MSP430ware.
    create-mirror:
    Eclipse:
    [20:10:56]
    BUILD FAILED
    	... 57 more
    [20:10:56]
                                        launchCCS:0
                                        createDesktopShortcut:0
                                        createStartMenuShortcut:0
                                        eclipsedir:/home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0/ccsv8/eclipse
    Executing chmod -R 666 "/tmp/bitrock_installer_24279.log"
    Script exit code: 0
    Script output:
    Script stderr:
    Thanks for the information. I tried this command but got errors. I'm using Ubuntu 14.04.
    $ ./ccs_setup_linux64_8.1.0.00011.bin --mode unattended --prefix ccsv8
    There has been an error.
    ccsdir: There was a problem with the installation. Please look at the logs for more information.
    Attached is the log.
    Could you please also zip up the contents of the <installdir>/ccsv8/install_logs folder and post them here?
    I have a feeling your install path (/home/uda0869574local/yocto/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/ti-ccsv8-native/8.1.0.00011-r0) is way too long, could you try installing in a short path? Something like /home/uda0869574local/ti is what users usually use.
    Danish
  • Log started 08/02/2018 at 16:10:41
    [16:10:42] Found mode unattended
    [16:10:42] Ubuntu 14.04.5 LTS
    [16:10:42] installer_command_line_arguments : --mode unattended --prefix ccsv8
    [16:10:42] Product Name Code Composer Studio 8.1.0
    [16:10:42] Product Version 8.1.0.00011
    [16:10:42] --mode unattended --prefix ccsv8
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    Unpacking files
    [16:10:42] admin = 0
    [16:10:42] installertype = setup
    [16:10:42] ccsinstaller_name ccs_setup_linux64_8.1.0.00011.bin
    [16:10:43] Installer: /home/uda0869574local/Downloads/ccs_setup_linux64_8.1.0.00011.bin
    Executing chmod -R 777 "/tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d/tcl"
    Script exit code: 0
    Script output:
    Script stderr:
    Executing chmod -R 777 "/tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d/util"
    Script exit code: 0
    Script output:
    Script stderr:
    Executing chmod -R 777 "/tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d/dependency-checker"
    Script exit code: 0
    Script output:
    Script stderr:
    [16:10:44]
    [16:10:44] running /tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d/tcl/bin/tclsh.sh  "/tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d/installer_tcl/main_frontend/main.tcl" --installersrc "/home/uda0869574local/Downloads" --installertmp "/tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d" --mode unattended --prefix ccsv8 --buildid 8.1.0.00011 --installer "/home/uda0869574local/Downloads/ccs_setup_linux64_8.1.0.00011.bin" --bitness 64-bit --os linux-x64 --osname "Ubuntu 14.04.5 LTS" --spversion "" --timestamp 20180802161042 --AVon false --tl false
    Executing /tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d/tcl/bin/tclsh.sh "/tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d/installer_tcl/main_frontend/main.tcl" --installersrc "/home/uda0869574local/Downloads" --installertmp "/tmp/ccs_bb0e89a5-f0ce-4dec-774f-3ac998cb113d" --mode unattended --prefix ccsv8 --buildid 8.1.0.00011 --installer "/home/uda0869574local/Downloads/ccs_setup_linux64_8.1.0.00011.bin" --bitness 64-bit --os linux-x64 --osname "Ubuntu 14.04.5 LTS" --spversion "" --timestamp 20180802161042 --AVon false --tl false
    Script exit code: 0
    Script output:
    Script stderr:
    [16:14:29]
    [16:14:29]
    [16:14:29]
                                        launchCCS:0
                                        eclipsedir:ccsv8/ccsv8/eclipse
    Executing chmod -R 666 "/tmp/bitrock_installer_25668.log"
    Script exit code: 0
    Script output:
    Script stderr:
    Sorry, I attached wrong file. Here is it:
  • Could you zip up the contents of the install_logs folder and post here?
    Danish
  • I don't see the install_logs folder.
  • Please pass a full path to the installer with the --prefix parameter.
    e.g.:
    ./ccs_setup_linux64_8.1.0.00011.bin --mode unattended --prefix $HOME/ccs8
  • ccsv8_install_log.zipOkay. Here is the install_logs folder.
  • HI,
    I found out the problem. I was using the "Online Installer". After switching to "Offline Installer", it worked fine.
    http://software-dl.ti.com/ccs/esd/CCSv8/CCS_8_1_0/exports/CCS8.1.0.00011_linux-x64.tar.gz
