Part Number: CC3200
I'm trying to build the mqtt library project in CCS because I want to build the MQTT Client example in my CC3200 launch Pad. However, I get the following error message below. Thank you for your help in advanced.
**** Build of configuration client__TI for project mqtt ****
"C:\\Users\\David\\Documents\\ti\\ccsv8\\utils\\bin\\gmake" -k -j 4 all -O
Building file: "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/client/mqtt_client.c"
Invoking: ARM Compiler
"C:/Users/David/Documents/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.3.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O2 --include_path="C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/ccs" --include_path="C:/Users/David/Documents/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.3.LTS/include" --define=cc3200 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="mqtt_client.d_raw" "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/client/mqtt_client.c"
>> Compilation failure
subdir_rules.mk:23: recipe for target 'mqtt_client.obj' failed
gmake: *** No rule to make target 'C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/platform/cc31xx_sl_net.c', needed by 'cc31xx_sl_net.obj'.
gmake: *** No rule to make target 'C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/platform/cc3200_platform.c', needed by 'cc3200_platform.obj'.
"C:\Users\David\Documents\ti\CC3200SDK_1.3.0\cc3200-sdk\netapps\mqtt\client\mqtt_client.h", line 76: fatal error #1965: cannot open source file "mqtt_common.h"
1 catastrophic error detected in the compilation of "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/client/mqtt_client.c".
Compilation terminated.
gmake: *** [mqtt_client.obj] Error 1
Building file: "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/sl/sl_mqtt_client.c"
"C:/Users/David/Documents/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.3.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O2 --include_path="C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/ccs" --include_path="C:/Users/David/Documents/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.3.LTS/include" --define=cc3200 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="sl_mqtt_client.d_raw" "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/sl/sl_mqtt_client.c"
>> Compilation failure
subdir_rules.mk:37: recipe for target 'sl_mqtt_client.obj' failed
"C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/sl/sl_mqtt_client.c", line 16: fatal error #1965: cannot open source file "sl_mqtt_client.h"
1 catastrophic error detected in the compilation of "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/sl/sl_mqtt_client.c".
gmake: *** [sl_mqtt_client.obj] Error 1
Building file: "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/common/mqtt_common.c"
"C:/Users/David/Documents/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.3.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O2 --include_path="C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/ccs" --include_path="C:/Users/David/Documents/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.3.LTS/include" --define=cc3200 --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="mqtt_common.d_raw" "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/common/mqtt_common.c"
>> Compilation failure
subdir_rules.mk:30: recipe for target 'mqtt_common.obj' failed
"C:\Users\David\Documents\ti\CC3200SDK_1.3.0\cc3200-sdk\netapps\mqtt\common\mqtt_common.h", line 47: fatal error #1965: cannot open source file "platform.h"
1 catastrophic error detected in the compilation of "C:/Users/David/Documents/ti/CC3200SDK_1.3.0/cc3200-sdk/netapps/mqtt/common/mqtt_common.c".
gmake: *** [mqtt_common.obj] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
