Part Number: TMS320F28027
Other Parts Discussed in Thread: CONTROLSUITE, C2000WARE
Hello! I have the following problem, I initialize the ADC to turn on the built-in temperature sensor, but when I get into the AdcOffsetSelfCal () function, I have problems. When I get to the Uint16 AdcConversion (void) function, I reach the while loop (index <SampleSize), it runs once, then the loop starts again, but the program stops on the while condition (AdcRegs.ADCINTFLG.bit.ADCINT1 == 0 ) and no it can not go further.
void AdcOffsetSelfCal()
Uint16 AdcConvMean;
EALLOW;
AdcRegs.ADCCTL1.bit.ADCREFSEL = 0; //Select internal reference mode
AdcRegs.ADCCTL1.bit.VREFLOCONV = 1; //Select VREFLO internal connection on B5
AdcChanSelect(13); //Select channel B5 for all SOC
AdcRegs.ADCOFFTRIM.bit.OFFTRIM = 80; //Apply artificial offset (+80) to account for a negative offset that may reside in the ADC core
AdcConvMean = AdcConversion(); //Capture ADC conversion on VREFLO
AdcRegs.ADCOFFTRIM.bit.OFFTRIM = 80 - AdcConvMean; //Set offtrim register with new value (i.e remove artical offset (+80) and create a two's compliment of the offset error)
AdcRegs.ADCCTL1.bit.VREFLOCONV = 0; //Select external ADCIN5 input pin on B5
EDIS;
/* AdcChanSelect-
This function selects the ADC channel to convert by setting all SOC channel selects to a single channel.
* IMPORTANT * This function will overwrite previous SOC channel select settings. Recommend saving
the previous settings.
void AdcChanSelect(Uint16 ch_no)
AdcRegs.ADCSOC0CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC1CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC2CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC3CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC4CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC5CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC6CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC7CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC8CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC9CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC10CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC11CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC12CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC13CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC14CTL.bit.CHSEL= ch_no;
AdcRegs.ADCSOC15CTL.bit.CHSEL= ch_no;
} //end AdcChanSelect
/* AdcConversion -
This function initiates several ADC conversions and returns the average. It uses ADCINT1 and ADCINT2
to "ping-pong" between SOC0-7 and SOC8-15 and is referred to as "ping-pong" sampling.
* IMPORTANT * This function will overwrite previous ADC settings. Recommend saving previous settings.
Uint16 AdcConversion(void)
Uint16 index, SampleSize, Mean, ACQPS_Value;
Uint32 Sum;
index = 0; //initialize index to 0
SampleSize = 256; //set sample size to 256 (**NOTE: Sample size must be multiples of 2^x where is an integer >= 4)
Sum = 0; //set sum to 0
Mean = 999; //initialize mean to known value
//Set the ADC sample window to the desired value (Sample window = ACQPS + 1)
ACQPS_Value = 6;
AdcRegs.ADCSOC0CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC1CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC2CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC3CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC4CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC5CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC6CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC7CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC8CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC9CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC10CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC11CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC12CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC13CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC14CTL.bit.ACQPS = ACQPS_Value;
AdcRegs.ADCSOC15CTL.bit.ACQPS = ACQPS_Value;
//Enable ping-pong sampling
// Enabled ADCINT1 and ADCINT2
AdcRegs.INTSEL1N2.bit.INT1E = 1;
AdcRegs.INTSEL1N2.bit.INT2E = 1;
// Disable continuous sampling for ADCINT1 and ADCINT2
AdcRegs.INTSEL1N2.bit.INT1CONT = 0;
AdcRegs.INTSEL1N2.bit.INT2CONT = 0;
AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //ADCINTs trigger at end of conversion
// Setup ADCINT1 and ADCINT2 trigger source
AdcRegs.INTSEL1N2.bit.INT1SEL = 6; //EOC6 triggers ADCINT1
AdcRegs.INTSEL1N2.bit.INT2SEL = 14; //EOC14 triggers ADCINT2
// Setup each SOC's ADCINT trigger source
AdcRegs.ADCINTSOCSEL1.bit.SOC0 = 2; //ADCINT2 starts SOC0-7
AdcRegs.ADCINTSOCSEL1.bit.SOC1 = 2;
AdcRegs.ADCINTSOCSEL1.bit.SOC2 = 2;
AdcRegs.ADCINTSOCSEL1.bit.SOC3 = 2;
AdcRegs.ADCINTSOCSEL1.bit.SOC4 = 2;
AdcRegs.ADCINTSOCSEL1.bit.SOC5 = 2;
AdcRegs.ADCINTSOCSEL1.bit.SOC6 = 2;
AdcRegs.ADCINTSOCSEL1.bit.SOC7 = 2;
AdcRegs.ADCINTSOCSEL2.bit.SOC8 = 1; //ADCINT1 starts SOC8-15
AdcRegs.ADCINTSOCSEL2.bit.SOC9 = 1;
AdcRegs.ADCINTSOCSEL2.bit.SOC10 = 1;
AdcRegs.ADCINTSOCSEL2.bit.SOC11 = 1;
AdcRegs.ADCINTSOCSEL2.bit.SOC12 = 1;
AdcRegs.ADCINTSOCSEL2.bit.SOC13 = 1;
AdcRegs.ADCINTSOCSEL2.bit.SOC14 = 1;
AdcRegs.ADCINTSOCSEL2.bit.SOC15 = 1;
DELAY_US(ADC_usDELAY); // Delay before converting ADC channels
//ADC Conversion
AdcRegs.ADCSOCFRC1.all = 0x00FF; // Force Start SOC0-7 to begin ping-pong sampling
while( index < SampleSize ){
//Wait for ADCINT1 to trigger, then add ADCRESULT0-7 registers to sum
while (AdcRegs.ADCINTFLG.bit.ADCINT1 == 0){} the program stops here
AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //Must clear ADCINT1 flag since INT1CONT = 0
Sum += AdcResult.ADCRESULT0;
Sum += AdcResult.ADCRESULT1;
Sum += AdcResult.ADCRESULT2;
Sum += AdcResult.ADCRESULT3;
Sum += AdcResult.ADCRESULT4;
Sum += AdcResult.ADCRESULT5;
Sum += AdcResult.ADCRESULT6;
// Wait for SOC9 conversion to start, which gives time for SOC7 conversion result
while( AdcRegs.ADCSOCFLG1.bit.SOC9 == 1 ){}
Sum += AdcResult.ADCRESULT7;
//Wait for ADCINT2 to trigger, then add ADCRESULT8-15 registers to sum
while (AdcRegs.ADCINTFLG.bit.ADCINT2 == 0){}
AdcRegs.ADCINTFLGCLR.bit.ADCINT2 = 1; //Must clear ADCINT2 flag since INT2CONT = 0
Sum += AdcResult.ADCRESULT8;
Sum += AdcResult.ADCRESULT9;
Sum += AdcResult.ADCRESULT10;
Sum += AdcResult.ADCRESULT11;
Sum += AdcResult.ADCRESULT12;
Sum += AdcResult.ADCRESULT13;
Sum += AdcResult.ADCRESULT14;
// Wait for SOC1 conversion to start, which gives time for SOC15 conversion result
while( AdcRegs.ADCSOCFLG1.bit.SOC1 == 1 ){}
Sum += AdcResult.ADCRESULT15;
index+=16;
} // end data collection
//Disable ADCINT1 and ADCINT2 to STOP the ping-pong sampling
AdcRegs.INTSEL1N2.bit.INT1E = 0;
AdcRegs.INTSEL1N2.bit.INT2E = 0;
while(AdcRegs.ADCSOCFLG1.all != 0){} // Wait for any pending SOCs to complete
// Clear any pending interrupts
AdcRegs.ADCINTOVFCLR.bit.ADCINT1 = 1;
AdcRegs.ADCINTOVFCLR.bit.ADCINT2 = 1;
//reset RR pointer to 32, so that next SOC is SOC0
AdcRegs.SOCPRICTL.bit.SOCPRIORITY = 1;
while( AdcRegs.SOCPRICTL.bit.SOCPRIORITY != 1 );
AdcRegs.SOCPRICTL.bit.SOCPRIORITY = 0;
while( AdcRegs.SOCPRICTL.bit.SOCPRIORITY != 0 );
Mean = Sum / SampleSize; //Calculate average ADC sample value
return Mean; //return the average
}//end AdcConversion
