CCS: CCS8.2: error deleting... permission denied
I can not install CCS8.2 because it can not delete a temp directory.
I use the offline installer. network(online) on or off makes no difference...
also starting the installer as admin and all windows firewalls and antivirus turned off -> no succes .
also deleting C:\ti and this folder in AppDate\temp by hand does not the job.
  • Hi Christian,
    Unfortunately, you're hitting a problem with a space in the user name. Could you please try the following:
    Temporarily reset TEMP/TMP environment variable to a directory that you can write to, with no spaces in the path, e.g. c:\temp.
    Run the installer as admin.
    This has been fixed in the next release and we're working on making the user experience with the installer better.
    Sorry for the inconvenience.
    Danish
  • Exactly the case with the username. This workaround works well ..tested under Win10 home !
