CCS/TMS320F28069: TMS320F28069
Part Number: TMS320F28069
Other Parts Discussed in Thread: CONTROLSUITE, C2000WARE
I tried running a given example by Control Suite in CCS v8.2.
I tried to build the given example project I imported.
The following errors were the given result. How to overcome these errors?
1. --cdebug_asm_data is no longer supported --cdebug_asm_data is no longer supported
2. gmake: *** [Example_2806xGpioSetup.obj] Error \
  • C2000Ware replaces controlSUITE.
    Open Resource Explorer in CCS
    Under Software you will see C2000Ware.
    You can expand it to see the GPIO Setup example for F28069
    It will then let you download and install the C2000Ware package and then you will be able to import the example.  The example will build fine in CCSv8.2
    John
