CCS/CC3220SF-LAUNCHXL: launchcc3220modasf
Part Number: CC3220SF-LAUNCHXL
Hello
<Flash using Uniflash ImageCreator The application should be run in standalone mode by loading the application to the serial flash as shown in section 3.4 of the SimpleLink Wi-Fi CC3220 Getting Started Guide. When loading the MCU image to the SimpleLink CC3220, use the binary that was generated when you built the project in your CCS workspace.>
I can't do this step. The link you provide us it's not working.
How i can run the application in standlone mode (CCS/Uniflash)? Please dont give me a not working link.
You need to update all your tutorial.All your tutorial is not accurate. I have find so many mistakes because you update your hardwere and softawere but not your tutorial.
please understand that if your products are not easy to work then this is a bad image for your company
Alexandros
  • Hi Alexandros,
    Can you please share the link to the document that you're following?
    Standalone mode means that you have flashed the application to the device and the LaunchPad can be reset while retaining the image. The alternative is to use the CCS debugger.
    Please see the UniFlash ImageCreator Basics SimpleLink Academy for details on how to use UniFlash with the CC3220: dev.ti.com/.../
    Sarah
