Part Number: TM4C129XNCZAD
I am interfacing Tm4c129xnczad interfacing with cc256x Bluetooth module. I am getting errors and warnigs can you pls help me to resolve the issue.
Description Resource Path Location Type
#10247-D creating output section ".constdata" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section ".patch" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Accept_Connection_Request" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Authentication_Requested" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Change_Local_Name" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Create_Connection_Cancel" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Create_Connection" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Delete_Stored_Link_Key" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Disconnect" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Enable_Device_Under_Test_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Exit_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Flush" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Host_Number_Of_Completed_Packets" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Inquiry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_IO_Capability_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_IO_Capability_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_LE_Read_Buffer_Size" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_LE_Read_White_List_Size" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Link_Key_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Link_Key_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Periodic_Inquiry_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_PIN_Code_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_PIN_Code_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_BD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Buffer_Size" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Class_of_Device" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_LE_Host_Supported" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Local_Name" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Local_Supported_Commands" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Local_Supported_Features" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Local_Version_Information" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Remote_Extended_Features" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Scan_Enable" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Read_Simple_Pairing_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Reject_Connection_Request" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Remote_Name_Request" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Remote_OOB_Data_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Remote_OOB_Data_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_SCO_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Send_Keypress_Notification" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Set_Connection_Encryption" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Set_Event_Filter" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Set_Event_Mask" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_User_Confirmation_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_User_Confirmation_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_User_Passkey_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_User_Passkey_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Automatic_Flush_Timeout" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Class_of_Device" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Current_IAC_LAP" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Default_Link_Policy_Settings" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Encryption_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_LE_Host_Supported" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Link_Supervision_Timeout" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Scan_Enable" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_SCO_Flow_Control_Enable" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Simple_Pairing_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._HCI_Write_Voice_Setting" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Config_Request" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Config_Response" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Connect_Response" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Disconnect_Request" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Disconnect_Response" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Enhanced_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Flush_Channel_Data" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._L2CA_Register_PSM" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Get_Data_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Line_Status_Change" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Modem_Status" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Open_Response" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Parameter_Negotiation_Response" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Register_Server_Channel" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Release_Request" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Remote_Port_Negotiation_Response" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Send_Credits" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Send_Data_With_Credits" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Send_Data" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Set_Data_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Set_System_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i._RFCOMM_Un_Register_Server_Channel" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcknowledgeTimerExpired" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireBluetoothStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireGAPLEContext" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireGAPStackACLInfo" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireGAPStackInfo" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireGAPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireL2CAPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireRFCOMMStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireSDPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireSPPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AcquireSPPStackPortInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddCallbackEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddL2CAPConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddPacketQueueEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.VerifySharedBufferPointer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.UpdateTimerModule" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.UpdateHCICallbackThread" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.UpdateAndExpireTimers" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SynchronousHCICommandCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SetEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendDataPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchBTStackEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ReleaseBluetoothStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RegisterCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.QuerySharedBuffer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseInquiryResultRSSI" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.MailboxDeleteDataCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.InitializeBSCModule" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCISendPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCIRemoteNameEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCIInquiryEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Write_Voice_Setting" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Write_SCO_Flow_Control_Enable" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Write_Scan_Enable" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Write_Default_Link_Policy_Settings" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Version_Supported" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Set_Event_Filter" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Send_Raw_Command" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Send_ACL_Data" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Schedule_Asynchronous_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Reset" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Register_SCO_Data_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Register_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Register_ACL_Data_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Reconfigure_Driver" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Query_LE_Controller_Support" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Exit_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Enable_Device_Under_Test_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Delete_Stored_Link_Key" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Command_Supported" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Change_SCO_Configuration" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Change_SCO_Configuration_Handles" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Build_ACL_Packet_Type_Mask" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextTimerID" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeCallbackList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeBSCTimerEntryList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DetermineLEControllerSupport" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteCallbackEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteBTStackEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CreditDataPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CompareNULLBluetoothAddress" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CompareListEntryKeys" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CompareBluetoothAddress" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CalculateBufferOffset" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventWord" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventHeader" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventByteWordWord" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventByteWordByte" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CheckQueuedDataWrite" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CleanupChannel" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CreateNewChannel" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CreateNewIdentifierEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DelayedAuthenticationProcess" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteACLPacketEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteIdentifierInfoEntryByIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DispatchFixedChannelConnectDisconnect" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.EnhancedFragmentPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventCIDOnly" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventConfigConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventConnectConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventDisconnectConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventDisconnectIndication" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventEchoConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventInformationConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatEventMemberStatus" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FragmentPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeACLDataList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeChannelInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeConnectionInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeFixedChannelInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeIdentifierInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeL2CAPContextInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeRegistryInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextDataIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextGroupInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextIDNumber" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_ACL_Data_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HandleChannelDisconnection" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HandleReadDataError" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConfigRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConfigRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConfigResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConnectRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConnectRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConnectResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConnectionParameterUpdateRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConnectionParameterUpdateResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ConnectionTimeout" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_DataWrite" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_DisconnectRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_DisconnectRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_DisconnectResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_EchoRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_EchoResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_InformationRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_InformationResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ProcessACLQueue" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_ReceiveTimeout" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_RejectCommand" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_RequestTimeout" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CAP_StateTimeout" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CA_Get_Link_Connection_State" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CA_Register_Fixed_Channel" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CA_Set_Link_Connection_Configuration" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.LP_ConnectCfm" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.LP_ConnectCfmNeg" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.LP_ConnectIndication" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.LP_DisconnectCfm" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.LP_DisconnectReq" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseAPIOptions" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseOptionsToAPI" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessL2CAPDataPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessSendQueueData" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.QueueACLPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchACLPacketEntryByConnectionHandle" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchACLPacketEntryByIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchChannelInfoEntryByConnectionHandle" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchConnectionInfoEntryByBD_ADDRType" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchConnectionInfoEntryByConnectionHandle" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchFixedChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchIdentifierInfoEntryByIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchRegistryByValue" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.VerifyACLHeader" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventByteBD_ADDRByte" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventByte" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventBD_ADDRVariableData" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildEventBD_ADDRDWord" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildCommandHeader" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandWordByte" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandWord" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandThreeWords" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandNoData" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandByteVariable" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandByte" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandBD_ADDRByteVariable" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildAndSubmitCommandBD_ADDRByte" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BTPS_StopTimer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CleanUpInquiry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteACLLinkEntryConnection_Handle" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.Discoverability_Timeout_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchAuthenticationEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchAuthenticationStatusEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchEncryptionChangeEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchInquiryEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeACLLinkList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeInquiryResultList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAPBondingEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAPInquiryEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAPRemoteNameEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Authenticate_Remote_Device" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Authentication_Response" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Cancel_Bonding" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_End_Bonding" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Initiate_Bonding" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Perform_Inquiry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Query_Class_Of_Device" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Query_Connection_Handle" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Query_Local_BD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Query_Local_Device_Name" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Query_Remote_Device_Name" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Register_Remote_Authentication" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Set_Class_Of_Device" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Set_Connectability_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Set_Discoverability_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Set_Encryption_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Set_Local_Device_Name" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_Set_Pairability_Mode" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.IssueBondingCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.IssueRemoteNameCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ReleaseGAPLEContext" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchACLLinkEntryBD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchACLLinkEntryConnection_Handle" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchCallbackEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BTPS_StartTimer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteCallbackInfoByType" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeCallbackInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeLELinkEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeLELinkList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeSecurityManagerResources" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_LE_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GAP_LE_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BTPS_ProcessAsynchronousTimers" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BTPS_InitializeTimerModule" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BTPS_CleanupTimerModule" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BTPS_ChangeTimer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_UnRegisterEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_Shutdown" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CalculateAttributeRequestParameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CalculateDataTypeLength" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CleanupSDPConnection" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CompareServiceRecordWithServiceList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteConnectionInfoEntryCID" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DispatchSDPConnectionEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatResponsePDUHeaderAndSend" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeL2CAPConnectionInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeServiceAttributeList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeServiceRecordList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextServiceAttribute" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.L2CA_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.NormalizeUUID" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseAPIUUIDs" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseAttributeIDList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseRecordAttributes" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseServiceSearchPattern" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessConnectionError" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessSDPConnectionRequest" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessServiceAttributeRequest" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessServiceSearchAttributeRequest" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessServiceSearchRequest" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ReadDataElementSequenceLength" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SDP_Add_Raw_Attribute" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SDP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SDP_Create_Service_Record" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SDP_Delete_Service_Record" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SDP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchServiceRecordEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendConnectionResponse" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ServiceAttributeListValid" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.UpdateServiceRecordStateAttribute" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.WriteAttributeRequestContinuationInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.WriteDataElementSequenceHeader" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_SearchGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_ReleaseListLock" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_RegisterEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_QueryActiveFeatures" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CalculateFCS" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.Disconnect" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DisconnectChannel" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchEventTEIDLCIByte" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchFlowEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchOpenConfirmationEvent" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeRFCOMMChannelInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextRFCOMMChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextRFCOMMServerInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessRFCOMMControlMessage" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessRFCOMMDataMessage" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMMCleanupHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMMServerPNMessageHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMMServerSABMMessageHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_Control" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_Control_Message" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_SignalTimeout" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_Start_Link_Negotiation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RemoveL2CAPConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RemoveRFCOMMChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RemoveRFCOMMMessageInfoEntryByTEIAndMessage" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchL2CAPConnectionInfoEntryByBD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchL2CAPConnectionInfoEntryByCID" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchRFCOMMChannelInfoEntryByTEIAndDLCI" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchRFCOMMMessageInfoEntryByMessageTEIAndDLCI" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchRFCOMMMessageInfoEntryByTEIAndDLCI" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchRFCOMMServerInfoEntryByTEI" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendFormattedControlMessage" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_GetNextGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_FreeGenericListEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_FreeGenericListEntryList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_DeleteGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_AuthenticateDevice" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_AddGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_AddGenericListEntry_Actual" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BSC_AcquireListLock" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AsynchronousSCODataCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AsynchronousHCIEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AsynchronousACLDataCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AdjustSharedBuffer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddUnsignedInteger4Bytes" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddServiceRecordEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddServiceAttributeEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildPortInformationStructure" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.BuildRemotePortNegotiationStructure" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CalculateCreditThreshold" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CleanupPortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeletePortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchEventBD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchEventPortInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FormatAndDispatchEventUnsignedInteger" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreePortInformationEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreePortInformationList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextSerialPortID" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RFCOMM_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPPServerHandler" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Close_Server_Port" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Data_Read" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Get_Configuration_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Get_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Line_Status" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Open_Server_Port" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Port_Status" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Register_Raw_SDP_Record" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Respond_Port_Information" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Send_Break" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Set_Configuration_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SPP_Set_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchPortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendQueuedData" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddRFCOMMMessageInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SCO_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SCO_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddRFCOMMChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreePortInfoEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreePortInfoList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GOEP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GOEP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.OTP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.OTP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CleanupCertificateModule" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetAccess" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetCertCurrentDate" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetCertLength" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetCertPtr" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.InitializeCertificateModule" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddRegistryInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CleanupHCIDriver" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeletePacketQueueEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DispatchDebugPacketCallbacks" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeDriverStructureResources" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.GetNextCallbackPacketID" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_CancelPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_ChangeSCOConfiguration" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_ChangeSCOConfigurationHandles" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_CloseDriver" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_DriverCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_OpenDriver" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_ProcessHCIDriverInformation" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_ReconfigureDriver" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_RegisterACLDataCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_RegisterEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_RegisterSCODataCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_SendPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCI_UnRegisterCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchDriverEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendHCIPacketToLowerDriver" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ChangeCommSCOConfiguration" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CleanupCOMMList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CloseComm" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.DeleteCOMEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeCOMStructureResources" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCITR_COMDataCallback_UART" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.InitializeCOMMList" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.InitializeProtocol" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.OpenComm" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessComm" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProtocolEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProtocolTimerCallback" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ReconfigureComm" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SearchCOMEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendCommPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeTransmitBufferListHead" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCILL_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCILL_ReceiveBytes" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCILL_Reconfigure" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCILL_Resynchronize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCILL_Shutdown" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.HCILL_TransmitBytes" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendQueuedPackets" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendSleepIndication" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.TransmitData" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.AddPortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CalculateCRC" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.CheckIdle" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.EncodeAndSend" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.FreeBufferListHead" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.IdleTimerExpired" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ParseConfigurationField" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessReceivedPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.ProcessTWUARTMessage" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RestartPacketizer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.RetransmitTimerExpired" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendNullPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendReliablePacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendSLIPPacket" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SendTWUARTMessage" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SetTWUARTState" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SetTWUARTTimer" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.SetTransportConfiguration" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.TWUART_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.TWUART_ReceiveBytes" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.TWUART_Reconfigure" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.TWUART_Resynchronize" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.TWUART_Shutdown" without a SECTIONS specification SPPDemo C/C++ Problem
#10247-D creating output section "i.TWUART_TransmitBytes" without a SECTIONS specification SPPDemo C/C++ Problem
This project contains unresolved buildable linked resources. It might not build as expected. SPPDemo project Problems
#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 169 C/C++ Problem
#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 426 C/C++ Problem
#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 640 C/C++ Problem
#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 726 C/C++ Problem
#169-D argument of type "int (*)(void *)" is incompatible with parameter of type "BTPS_SchedulerFunction_t" Main.c /SPPDemo line 232 C/C++ Problem
#169-D argument of type "int (*)()" is incompatible with parameter of type "BTPS_SchedulerFunction_t" Main.c /SPPDemo line 818 C/C++ Problem
#169-D argument of type "int (*)()" is incompatible with parameter of type "BTPS_SchedulerFunction_t" Main.c /SPPDemo line 228 C/C++ Problem
#169-D argument of type "int (*)()" is incompatible with parameter of type "BTPS_SchedulerFunction_t" SPPDemo.c /SPPDemo line 2951 C/C++ Problem
#179-D function "UserInterface_Selection" was declared but never referenced SPPDemo.c /SPPDemo line 506 C/C++ Problem
#179-D function "CommandLineInterpreter" was declared but never referenced SPPDemo.c /SPPDemo line 522 C/C++ Problem
errors
Description Resource Path Location Type
#10008-D cannot find file "Bluetopia_FP.lib" SPPDemo C/C++ Problem
#10008-D cannot find file "driverlib.lib" SPPDemo C/C++ Problem
#10010 errors encountered during linking; "SPPDemo.out" not built SPPDemo C/C++ Problem
#10056 symbol "g_pfnVectors" redefined: first defined in "./tm4c129xnczad_startup_ccs.obj"; redefined in "./dk-tm4c123g/startup_ccs.obj" SPPDemo C/C++ Problem
#10056 symbol "ResetISR" redefined: first defined in "./tm4c129xnczad_startup_ccs.obj"; redefined in "./dk-tm4c123g/startup_ccs.obj" SPPDemo C/C++ Problem
#10234-D unresolved symbols remain SPPDemo C/C++ Problem
#10263 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 47 C/C++ Problem
#10263 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 49 C/C++ Problem
#10264 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 47 C/C++ Problem
#10264 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 49 C/C++ Problem
gmake: *** [all] Error 2 SPPDemo C/C++ Problem
gmake[1]: *** [SPPDemo.out] Error 1 SPPDemo C/C++ Problem
gmake[1]: Target 'main-build' not remade because of errors. SPPDemo C/C++ Problem
unresolved symbol __error__, first referenced in ./TivaWareLib.obj SPPDemo C/C++ Problem
unresolved symbol ADCHardwareOversampleConfigure, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol ADCIntClear, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCIntStatus, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCProcessorTrigger, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceConfigure, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceDataGet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceStepConfigure, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol BSC_Initialize, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol BSC_Shutdown, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Authentication_Response, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_End_Bonding, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Initiate_Bonding, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Perform_Inquiry, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Class_Of_Device, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Connection_Handle, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Local_BD_ADDR, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Local_Device_Name, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Remote_Device_Name, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Register_Remote_Authentication, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Class_Of_Device, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Connectability_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Discoverability_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Local_Device_Name, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Pairability_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinConfigure, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinRead, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeADC, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeGPIOInput, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeGPIOOutput, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeI2C, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeI2CSCL, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeSSI, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeUART, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinWrite, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol HAL_ConfigureHardware, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol HAL_ConsoleWrite, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol HAL_GetTickCount, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Command_Supported, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Delete_Stored_Link_Key, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Enable_Device_Under_Test_Mode, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Exit_Sniff_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Reconfigure_Driver, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Register_Event_Callback, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Send_Raw_Command, first referenced in ./BTPSVEND.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Set_Event_Filter, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Sniff_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Write_Default_Link_Policy_Settings, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Write_Scan_Enable, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Write_Voice_Setting, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterBusy, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterControl, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterDataGet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterDataPut, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterInitExpClk, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterSlaveAddrSet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol IntEnable, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol L2CA_Set_Link_Connection_Configuration, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SDP_Delete_Service_Record, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Close_Server_Port, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Data_Read, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Data_Write, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Get_Configuration_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Get_Queuing_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Open_Server_Port, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Register_Raw_SDP_Record, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Respond_Port_Information, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Set_Configuration_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Set_Queuing_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SSIBusy, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIConfigSetExpClk, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol SSIDataGet, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIDataGetNonBlocking, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIDataPut, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlDelay, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlPeripheralEnable, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlPeripheralReady, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlReset, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlResetCauseClear, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlResetCauseGet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol UARTCharGetNonBlocking, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTCharPutNonBlocking, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTCharsAvail, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTConfigSetExpClk, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol UARTIntClear, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTIntEnable, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol UARTIntStatus, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogIntClear, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogIntStatus, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogReloadSet, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogResetEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogStallEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
#10190-D absolute symbol "__STACK_TOP" being redefined linker_ccs.cmd /SPPDemo/dk-tm4c123g line 71 C/C++ Problem
Description Resource Path Location Type#10247-D creating output section ".constdata" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section ".patch" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Accept_Connection_Request" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Authentication_Requested" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Change_Local_Name" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Create_Connection_Cancel" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Create_Connection" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Delete_Stored_Link_Key" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Disconnect" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Enable_Device_Under_Test_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Exit_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Flush" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Host_Number_Of_Completed_Packets" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Inquiry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_IO_Capability_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_IO_Capability_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_LE_Read_Buffer_Size" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_LE_Read_White_List_Size" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Link_Key_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Link_Key_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Periodic_Inquiry_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_PIN_Code_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_PIN_Code_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_BD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Buffer_Size" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Class_of_Device" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_LE_Host_Supported" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Local_Name" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Local_Supported_Commands" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Local_Supported_Features" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Local_Version_Information" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Remote_Extended_Features" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Scan_Enable" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Read_Simple_Pairing_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Reject_Connection_Request" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Remote_Name_Request" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Remote_OOB_Data_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Remote_OOB_Data_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_SCO_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Send_Keypress_Notification" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Set_Connection_Encryption" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Set_Event_Filter" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Set_Event_Mask" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_User_Confirmation_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_User_Confirmation_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_User_Passkey_Request_Negative_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_User_Passkey_Request_Reply" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Automatic_Flush_Timeout" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Class_of_Device" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Current_IAC_LAP" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Default_Link_Policy_Settings" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Encryption_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_LE_Host_Supported" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Link_Supervision_Timeout" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Scan_Enable" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_SCO_Flow_Control_Enable" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Simple_Pairing_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._HCI_Write_Voice_Setting" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Config_Request" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Config_Response" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Connect_Response" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Disconnect_Request" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Disconnect_Response" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Enhanced_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Flush_Channel_Data" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._L2CA_Register_PSM" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Get_Data_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Line_Status_Change" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Modem_Status" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Open_Response" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Parameter_Negotiation_Response" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Register_Server_Channel" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Release_Request" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Remote_Port_Negotiation_Response" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Send_Credits" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Send_Data_With_Credits" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Send_Data" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Set_Data_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Set_System_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i._RFCOMM_Un_Register_Server_Channel" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcknowledgeTimerExpired" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireBluetoothStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireGAPLEContext" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireGAPStackACLInfo" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireGAPStackInfo" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireGAPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireL2CAPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireRFCOMMStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireSDPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireSPPStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AcquireSPPStackPortInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddCallbackEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddL2CAPConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddPacketQueueEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.VerifySharedBufferPointer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.UpdateTimerModule" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.UpdateHCICallbackThread" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.UpdateAndExpireTimers" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SynchronousHCICommandCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SetEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendDataPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchBTStackEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ReleaseBluetoothStackInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RegisterCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.QuerySharedBuffer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseInquiryResultRSSI" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.MailboxDeleteDataCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.InitializeBSCModule" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCISendPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCIRemoteNameEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCIInquiryEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Write_Voice_Setting" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Write_SCO_Flow_Control_Enable" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Write_Scan_Enable" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Write_Default_Link_Policy_Settings" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Version_Supported" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Set_Event_Filter" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Send_Raw_Command" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Send_ACL_Data" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Schedule_Asynchronous_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Reset" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Register_SCO_Data_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Register_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Register_ACL_Data_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Reconfigure_Driver" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Query_LE_Controller_Support" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Exit_Sniff_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Enable_Device_Under_Test_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Delete_Stored_Link_Key" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Command_Supported" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Change_SCO_Configuration" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Change_SCO_Configuration_Handles" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Build_ACL_Packet_Type_Mask" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextTimerID" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeCallbackList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeBSCTimerEntryList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DetermineLEControllerSupport" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteCallbackEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteBTStackEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CreditDataPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CompareNULLBluetoothAddress" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CompareListEntryKeys" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CompareBluetoothAddress" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CalculateBufferOffset" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventWord" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventHeader" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventByteWordWord" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventByteWordByte" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CheckQueuedDataWrite" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CleanupChannel" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CreateNewChannel" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CreateNewIdentifierEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DelayedAuthenticationProcess" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteACLPacketEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteIdentifierInfoEntryByIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DispatchFixedChannelConnectDisconnect" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.EnhancedFragmentPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventCIDOnly" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventConfigConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventConnectConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventDisconnectConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventDisconnectIndication" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventEchoConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventInformationConfirmation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatEventMemberStatus" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FragmentPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeACLDataList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeChannelInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeConnectionInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeFixedChannelInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeIdentifierInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeL2CAPContextInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeRegistryInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextDataIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextGroupInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextIDNumber" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_ACL_Data_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HandleChannelDisconnection" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HandleReadDataError" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConfigRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConfigRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConfigResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConnectRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConnectRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConnectResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConnectionParameterUpdateRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConnectionParameterUpdateResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ConnectionTimeout" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_DataWrite" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_DisconnectRequestEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_DisconnectRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_DisconnectResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_EchoRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_EchoResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_InformationRequestResponse" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_InformationResponseEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ProcessACLQueue" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_ReceiveTimeout" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_RejectCommand" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_RequestTimeout" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CAP_StateTimeout" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CA_Get_Link_Connection_State" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CA_Register_Fixed_Channel" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CA_Set_Link_Connection_Configuration" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.LP_ConnectCfm" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.LP_ConnectCfmNeg" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.LP_ConnectIndication" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.LP_DisconnectCfm" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.LP_DisconnectReq" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseAPIOptions" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseOptionsToAPI" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessL2CAPDataPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessSendQueueData" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.QueueACLPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchACLPacketEntryByConnectionHandle" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchACLPacketEntryByIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchChannelInfoEntryByConnectionHandle" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchConnectionInfoEntryByBD_ADDRType" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchConnectionInfoEntryByConnectionHandle" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchFixedChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchIdentifierInfoEntryByIdentifier" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchRegistryByValue" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.VerifyACLHeader" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventByteBD_ADDRByte" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventByte" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventBD_ADDRVariableData" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildEventBD_ADDRDWord" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildCommandHeader" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandWordByte" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandWord" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandThreeWords" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandNoData" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandByteVariable" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandByte" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandBD_ADDRByteVariable" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildAndSubmitCommandBD_ADDRByte" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BTPS_StopTimer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CleanUpInquiry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteACLLinkEntryConnection_Handle" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.Discoverability_Timeout_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchAuthenticationEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchAuthenticationStatusEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchEncryptionChangeEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchInquiryEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeACLLinkList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeInquiryResultList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAPBondingEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAPInquiryEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAPRemoteNameEventHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Authenticate_Remote_Device" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Authentication_Response" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Cancel_Bonding" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_End_Bonding" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Initiate_Bonding" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Perform_Inquiry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Query_Class_Of_Device" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Query_Connection_Handle" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Query_Local_BD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Query_Local_Device_Name" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Query_Remote_Device_Name" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Register_Remote_Authentication" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Set_Class_Of_Device" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Set_Connectability_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Set_Discoverability_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Set_Encryption_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Set_Local_Device_Name" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_Set_Pairability_Mode" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.IssueBondingCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.IssueRemoteNameCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ReleaseGAPLEContext" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchACLLinkEntryBD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchACLLinkEntryConnection_Handle" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchCallbackEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BTPS_StartTimer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteCallbackInfoByType" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeCallbackInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeLELinkEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeLELinkList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeSecurityManagerResources" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_LE_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GAP_LE_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BTPS_ProcessAsynchronousTimers" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BTPS_InitializeTimerModule" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BTPS_CleanupTimerModule" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BTPS_ChangeTimer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_UnRegisterEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_Shutdown" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CalculateAttributeRequestParameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CalculateDataTypeLength" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CleanupSDPConnection" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CompareServiceRecordWithServiceList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteConnectionInfoEntryCID" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DispatchSDPConnectionEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatResponsePDUHeaderAndSend" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeL2CAPConnectionInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeServiceAttributeList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeServiceRecordList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextServiceAttribute" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.L2CA_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.NormalizeUUID" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseAPIUUIDs" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseAttributeIDList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseRecordAttributes" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseServiceSearchPattern" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessConnectionError" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessSDPConnectionRequest" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessServiceAttributeRequest" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessServiceSearchAttributeRequest" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessServiceSearchRequest" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ReadDataElementSequenceLength" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SDP_Add_Raw_Attribute" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SDP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SDP_Create_Service_Record" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SDP_Delete_Service_Record" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SDP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchServiceRecordEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendConnectionResponse" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ServiceAttributeListValid" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.UpdateServiceRecordStateAttribute" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.WriteAttributeRequestContinuationInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.WriteDataElementSequenceHeader" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_SearchGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_ReleaseListLock" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_RegisterEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_QueryActiveFeatures" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CalculateFCS" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.Disconnect" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DisconnectChannel" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchEventTEIDLCIByte" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchFlowEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchOpenConfirmationEvent" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeRFCOMMChannelInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextRFCOMMChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextRFCOMMServerInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessRFCOMMControlMessage" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessRFCOMMDataMessage" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMMCleanupHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMMServerPNMessageHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMMServerSABMMessageHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_Control" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_Control_Message" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_SignalTimeout" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_Start_Link_Negotiation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RemoveL2CAPConnectionInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RemoveRFCOMMChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RemoveRFCOMMMessageInfoEntryByTEIAndMessage" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchL2CAPConnectionInfoEntryByBD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchL2CAPConnectionInfoEntryByCID" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchRFCOMMChannelInfoEntryByTEIAndDLCI" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchRFCOMMMessageInfoEntryByMessageTEIAndDLCI" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchRFCOMMMessageInfoEntryByTEIAndDLCI" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchRFCOMMServerInfoEntryByTEI" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendFormattedControlMessage" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_GetNextGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_FreeGenericListEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_FreeGenericListEntryList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_DeleteGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_AuthenticateDevice" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_AddGenericListEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_AddGenericListEntry_Actual" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BSC_AcquireListLock" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AsynchronousSCODataCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AsynchronousHCIEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AsynchronousACLDataCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AdjustSharedBuffer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddUnsignedInteger4Bytes" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddServiceRecordEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddServiceAttributeEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildPortInformationStructure" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.BuildRemotePortNegotiationStructure" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CalculateCreditThreshold" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CleanupPortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeletePortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchEventBD_ADDR" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchEventPortInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FormatAndDispatchEventUnsignedInteger" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreePortInformationEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreePortInformationList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextSerialPortID" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RFCOMM_Event_Callback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPPServerHandler" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Close_Server_Port" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Data_Read" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Data_Write" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Get_Configuration_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Get_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Line_Status" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Open_Server_Port" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Port_Status" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Register_Raw_SDP_Record" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Respond_Port_Information" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Send_Break" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Set_Configuration_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SPP_Set_Queuing_Parameters" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchPortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendQueuedData" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddRFCOMMMessageInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SCO_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SCO_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddRFCOMMChannelInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreePortInfoEntryMemory" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreePortInfoList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GOEP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GOEP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.OTP_Cleanup" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.OTP_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CleanupCertificateModule" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetAccess" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetCertCurrentDate" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetCertLength" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetCertPtr" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.InitializeCertificateModule" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddRegistryInfoEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CleanupHCIDriver" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeletePacketQueueEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DispatchDebugPacketCallbacks" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeDriverStructureResources" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.GetNextCallbackPacketID" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_CancelPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_ChangeSCOConfiguration" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_ChangeSCOConfigurationHandles" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_CloseDriver" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_DriverCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_OpenDriver" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_ProcessHCIDriverInformation" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_ReconfigureDriver" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_RegisterACLDataCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_RegisterEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_RegisterSCODataCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_SendPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCI_UnRegisterCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchDriverEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendHCIPacketToLowerDriver" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ChangeCommSCOConfiguration" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CleanupCOMMList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CloseComm" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.DeleteCOMEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeCOMStructureResources" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCITR_COMDataCallback_UART" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.InitializeCOMMList" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.InitializeProtocol" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.OpenComm" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessComm" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProtocolEventCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProtocolTimerCallback" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ReconfigureComm" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SearchCOMEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendCommPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeTransmitBufferListHead" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCILL_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCILL_ReceiveBytes" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCILL_Reconfigure" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCILL_Resynchronize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCILL_Shutdown" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.HCILL_TransmitBytes" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendQueuedPackets" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendSleepIndication" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.TransmitData" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.AddPortInformationEntry" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CalculateCRC" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.CheckIdle" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.EncodeAndSend" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.FreeBufferListHead" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.IdleTimerExpired" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ParseConfigurationField" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessReceivedPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.ProcessTWUARTMessage" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RestartPacketizer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.RetransmitTimerExpired" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendNullPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendReliablePacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendSLIPPacket" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SendTWUARTMessage" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SetTWUARTState" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SetTWUARTTimer" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.SetTransportConfiguration" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.TWUART_Initialize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.TWUART_ReceiveBytes" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.TWUART_Reconfigure" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.TWUART_Resynchronize" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.TWUART_Shutdown" without a SECTIONS specification SPPDemo C/C++ Problem#10247-D creating output section "i.TWUART_TransmitBytes" without a SECTIONS specification SPPDemo C/C++ ProblemThis project contains unresolved buildable linked resources. It might not build as expected. SPPDemo project Problems#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 169 C/C++ Problem#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 426 C/C++ Problem#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 640 C/C++ Problem#188-D pointless comparison of unsigned integer with zero BTVS.c /SPPDemo line 726 C/C++ Problem#169-D argument of type "int (*)(void *)" is incompatible with parameter of type "BTPS_SchedulerFunction_t" Main.c /SPPDemo line 232 C/C++ Problem#169-D argument of type "int (*)()" is incompatible with parameter of type "BTPS_SchedulerFunction_t" Main.c /SPPDemo line 818 C/C++ Problem#169-D argument of type "int (*)()" is incompatible with parameter of type "BTPS_SchedulerFunction_t" Main.c /SPPDemo line 228 C/C++ Problem#169-D argument of type "int (*)()" is incompatible with parameter of type "BTPS_SchedulerFunction_t" SPPDemo.c /SPPDemo line 2951 C/C++ Problem#179-D function "UserInterface_Selection" was declared but never referenced SPPDemo.c /SPPDemo line 506 C/C++ Problem#179-D function "CommandLineInterpreter" was declared but never referenced SPPDemo.c /SPPDemo line 522 C/C++ Problem
