Part Number: TM4C129XNCZAD
Hi
I am interfacing tm4c129xnczad with cc256bt blueooth module.
i am getting warnings so pls help me to resolve the issue
Description Resource Path Location Type
#10008-D cannot find file "Bluetopia_FP.lib" SPPDemo C/C++ Problem
#10008-D cannot find file "driverlib.lib" SPPDemo C/C++ Problem
#10010 errors encountered during linking; "SPPDemo.out" not built SPPDemo C/C++ Problem
#10056 symbol "g_pfnVectors" redefined: first defined in "./tm4c129xnczad_startup_ccs.obj"; redefined in "./dk-tm4c123g/startup_ccs.obj" SPPDemo C/C++ Problem
#10056 symbol "ResetISR" redefined: first defined in "./tm4c129xnczad_startup_ccs.obj"; redefined in "./dk-tm4c123g/startup_ccs.obj" SPPDemo C/C++ Problem
#10234-D unresolved symbols remain SPPDemo C/C++ Problem
#10263 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 47 C/C++ Problem
#10263 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 49 C/C++ Problem
#10264 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 47 C/C++ Problem
#10264 linker_ccs.cmd /SPPDemo/dk-tm4c123g line 49 C/C++ Problem
gmake: *** [all] Error 2 SPPDemo C/C++ Problem
gmake[1]: *** [SPPDemo.out] Error 1 SPPDemo C/C++ Problem
gmake[1]: Target 'main-build' not remade because of errors. SPPDemo C/C++ Problem
unresolved symbol __error__, first referenced in ./TivaWareLib.obj SPPDemo C/C++ Problem
unresolved symbol ADCHardwareOversampleConfigure, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol ADCIntClear, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCIntStatus, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCProcessorTrigger, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceConfigure, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceDataGet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol ADCSequenceStepConfigure, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol BSC_Initialize, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol BSC_Shutdown, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Authentication_Response, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_End_Bonding, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Initiate_Bonding, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Perform_Inquiry, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Class_Of_Device, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Connection_Handle, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Local_BD_ADDR, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Local_Device_Name, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Query_Remote_Device_Name, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Register_Remote_Authentication, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Class_Of_Device, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Connectability_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Discoverability_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Local_Device_Name, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GAP_Set_Pairability_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinConfigure, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinRead, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeADC, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeGPIOInput, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeGPIOOutput, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeI2C, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeI2CSCL, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeSSI, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinTypeUART, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol GPIOPinWrite, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol HAL_ConfigureHardware, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol HAL_ConsoleWrite, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol HAL_GetTickCount, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Command_Supported, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Delete_Stored_Link_Key, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Enable_Device_Under_Test_Mode, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Exit_Sniff_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Reconfigure_Driver, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Register_Event_Callback, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Send_Raw_Command, first referenced in ./BTPSVEND.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Set_Event_Filter, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Sniff_Mode, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Write_Default_Link_Policy_Settings, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Write_Scan_Enable, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol HCI_Write_Voice_Setting, first referenced in ./BTVS.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterBusy, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterControl, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterDataGet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterDataPut, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterInitExpClk, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol I2CMasterSlaveAddrSet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol IntEnable, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol L2CA_Set_Link_Connection_Configuration, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SDP_Delete_Service_Record, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Close_Server_Port, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Data_Read, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Data_Write, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Get_Configuration_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Get_Queuing_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Open_Server_Port, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Register_Raw_SDP_Record, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Respond_Port_Information, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Set_Configuration_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SPP_Set_Queuing_Parameters, first referenced in ./SPPDemo.obj SPPDemo C/C++ Problem
unresolved symbol SSIBusy, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIConfigSetExpClk, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol SSIDataGet, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIDataGetNonBlocking, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIDataPut, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SSIEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlDelay, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlPeripheralEnable, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlPeripheralReady, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlReset, first referenced in ./IBP.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlResetCauseClear, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol SysCtlResetCauseGet, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol UARTCharGetNonBlocking, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTCharPutNonBlocking, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTCharsAvail, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTConfigSetExpClk, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol UARTIntClear, first referenced in ./RJC.obj SPPDemo C/C++ Problem
unresolved symbol UARTIntEnable, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol UARTIntStatus, first referenced in ./HCITRANS.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogIntClear, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogIntStatus, first referenced in ./Battery_board.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogReloadSet, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogResetEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
unresolved symbol WatchdogStallEnable, first referenced in ./Main.obj SPPDemo C/C++ Problem
#10190-D absolute symbol "__STACK_TOP" being redefined linker_ccs.cmd /SPPDemo/dk-tm4c123g line 71 C/C++ Problem
