CCS/TMS320C6455: load problem
Part Number: TMS320C6455
Hi
My tools:
OS: win XP
CCS: 3.3
DSP: C6455
When I want to load my program a message appeared that contained below sentence:
"Data verification loader 0x990400. Please verify target memory and memory map
Then, the program didn't load. I didn't understand what was the problem.
Please, guide me.
BR
    You encountered a data verification error. It is a pretty common error with many potential root causes. Please carefully read the below article. Note that while the article has screenshots for newer CCS versions, all the concepts and information apply to CCSv3.x.
    software-dl.ti.com/.../troubleshooting-data_verification_errors.html
    ki
  • Hi
    I read your answer and I'm investigating the article.
    I didn't use a linker commander file but I declared a section "IRAM"(fit to L2 SRAM) in RTOS(DSP/BIOS), The RTOS is responsible for setting all necessary memory segments in the IRAM section.
    When data verification error happened to me, it means that my code is too big and make a linker commander doesn't help me. I must decrease the memory usage
    for code or global variables by modifying the code.
    Am I thinking right?
    BR
    That's right, for BIOS applications, you would specify it in the BIOS config file
    I really can't say with any certainty since the error message is a bit vague. But all the things to check should be mentioned in that article.
