Other Parts Discussed in Thread: AM3352
English is not my mother tongue, and I already read those articles.
3. http://processors.wiki.ti.com/index.php/Tips_for_using_printf#What_is_C_I.2FO.3F
(I don't know how to make above links into linkable string, please help me out.)
Status description:
1. No errors and warnings
2. The code puts("Hello, world!"); works well(showed up on the console)
3. Under Project -> Properties -> Build -> Linker -> Basic Options ->
Set C system stack size(--stack_size, -stack) is 0x800;
Heap size for C/C++ dynamic memory allocation(--heap_size, -heap) is 0x800
4. heap size is 127M(AM335x.cmd)
AM335x.cmd:
Compiler Test Case:
* DNM_Manager.c
* Created on: 2019�~1��8��
* Author: no95
* DNM_Manager.h
* Author: no95
* typecast.h
* Created on: 2018�~12��27��
* Author: no95
typedef struct
unsigned int Addr;
unsigned int SerialNo;
unsigned int SubnetMask;
unsigned char Name[40];
}DNM;
void DNMManager_ctor(DNM* this, unsigned char* name, unsigned int ip, unsigned int sn, unsigned int subMask);
DNM* DNMManager_new();
/* STDIO.H v15.4.0I15142 */
/* Copyright (c) 1993-2015 Texas Instruments Incorporated */
/* http://www.ti.com/ */
/* Redistribution and use in source and binary forms, with or without */
/* modification, are permitted provided that the following conditions */
/* are met: */
/* Redistributions of source code must retain the above copyright */
/* notice, this list of conditions and the following disclaimer. */
/* Redistributions in binary form must reproduce the above copyright */
/* notice, this list of conditions and the following disclaimer in */
/* the documentation and/or other materials provided with the */
/* distribution. */
/* Neither the name of Texas Instruments Incorporated nor the names */
/* of its contributors may be used to endorse or promote products */
/* derived from this software without specific prior written */
/* permission. */
/* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS */
/* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT */
/* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR */
/* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT */
/* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, */
/* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, */
/* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY */
/* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT */
/* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE */
/* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
/* linkage.h v15.4.0I15142 */
/* Copyright (c) 1998-2015 Texas Instruments Incorporated */
/* are met: */
/* distribution. */
/* permission. */
#pragma diag_push
#pragma CHECK_MISRA("-19.4") /* macros required for implementation */
/* No modifiers are needed to access code or data */
/* Define _IDECL ==> how inline functions are declared */
#pragma diag_pop
/* stdarg.h v15.4.0I15142 */
/* Copyright (c) 1996-2015 Texas Instruments Incorporated */
/* are met: */
/* distribution. */
/* permission. */
#pragma diag_push
#pragma CHECK_MISRA("-20.2") /* standard headers must define standard names */
#pragma CHECK_MISRA("-19.10") /* need types as macro arguments */
typedef struct __va_list {
void * __ap;
} va_list;
#pragma diag_pop
#pragma diag_push
/* using declarations must occur outside header guard to support including both
C and C++-wrapped version of header; see _CPP_STYLE_HEADER check */
/* this code is for C++ mode only and thus also not relevant for MISRA */
#pragma CHECK_MISRA("-19.15")
#pragma diag_pop
/* Attributes are only available in relaxed ANSI mode. */
/* A header file conforming to ARM CLIB ABI (GENC-003539), should */
/* define _AEABI_PORTABLE when _AEABI_PORTABILITY_LEVEL is defined. */
/* The macro definition that guards CLIB ABI (GENC-003539) requirements. */
/* TYPES THAT ANSI REQUIRES TO BE DEFINED */
typedef unsigned size_t;
typedef struct {
int fd; /* File descriptor */
unsigned char* buf; /* Pointer to start of buffer */
unsigned char* pos; /* Position in buffer */
unsigned char* bufend; /* Pointer to end of buffer */
unsigned char* buff_stop; /* Pointer to last read char in buffer */
unsigned int flags; /* File status flags (see below) */
} FILE;
typedef long fpos_t;
/* DEVICE AND STREAM RELATED MACROS */
/* MACROS THAT DEFINE AND USE FILE STATUS FLAGS */
/* MACROS THAT ANSI REQUIRES TO BE DEFINED */
/******** END OF ANSI MACROS ************************************************/
/* DEVICE AND STREAM RELATED DATA STRUCTURES AND MACROS */
extern FILE _ftable[10];
extern char __TI_tmpnams[10][16];
/* FUNCTION DEFINITIONS - ANSI */
/* OPERATIONS ON FILES */
extern int remove(const char *_file);
extern int rename(const char *_old, const char *_new);
extern FILE *tmpfile(void);
extern char *tmpnam(char *_s);
/* FILE ACCESS FUNCTIONS */
extern int fclose(FILE *_fp);
extern FILE *fopen(const char *_fname, const char *_mode);
extern FILE *freopen(const char *_fname, const char *_mode,
register FILE *_fp);
extern void setbuf(register FILE *_fp, char *_buf);
extern int setvbuf(register FILE *_fp, register char *_buf,
register int _type, register size_t _size);
extern int fflush(register FILE *_fp);
/* FORMATTED INPUT/OUTPUT FUNCTIONS */
extern int fprintf(FILE *_fp, const char *_format, ...)
__attribute__((__format__ (__printf__, 2, 3)));
extern int fscanf(FILE *_fp, const char *_fmt, ...)
__attribute__((__format__ (__scanf__, 2, 3)));
extern int printf(const char *_format, ...)
__attribute__((__format__ (__printf__, 1, 2)));
extern int scanf(const char *_fmt, ...)
__attribute__((__format__ (__scanf__, 1, 2)));
extern int sprintf(char *_string, const char *_format, ...)
extern int snprintf(char *_string, size_t _n,
__attribute__((__format__ (__printf__, 3, 4)));
extern int sscanf(const char *_str, const char *_fmt, ...)
extern int vfprintf(FILE *_fp, const char *_format, va_list _ap)
__attribute__((__format__ (__printf__, 2, 0)));
extern int vfscanf(FILE *_fp, const char *_fmt, va_list _ap)
__attribute__((__format__ (__scanf__, 2, 0)));
extern int vprintf(const char *_format, va_list _ap)
__attribute__((__format__ (__printf__, 1, 0)));
extern int vscanf(const char *_format, va_list _ap)
__attribute__((__format__ (__scanf__, 1, 0)));
extern int vsprintf(char *_string, const char *_format,
va_list _ap)
extern int vsnprintf(char *_string, size_t _n,
__attribute__((__format__ (__printf__, 3, 0)));
extern int vsscanf(const char *_str, const char *_fmt, va_list _ap)
/* CHARACTER INPUT/OUTPUT FUNCTIONS */
extern int fgetc(register FILE *_fp);
extern char *fgets(char *_ptr, register int _size,
extern int fputc(int _c, register FILE *_fp);
extern int fputs(const char *_ptr, register FILE *_fp);
extern int getc(FILE *_p);
extern int getchar(void);
extern char *gets(char *_ptr);
extern int putc(int _x, FILE *_fp);
extern int putchar(int _x);
extern int puts(const char *_ptr);
extern int ungetc(int _c, register FILE *_fp);
/* DIRECT INPUT/OUTPUT FUNCTIONS */
extern size_t fread(void *_ptr, size_t _size, size_t _count,
FILE *_fp);
extern size_t fwrite(const void *_ptr, size_t _size,
size_t _count, register FILE *_fp);
/* FILE POSITIONING FUNCTIONS */
extern int fgetpos(FILE *_fp, fpos_t *_pos);
extern int fseek(register FILE *_fp, long _offset,
int _ptrname);
extern int fsetpos(FILE *_fp, const fpos_t *_pos);
extern long ftell(FILE *_fp);
extern void rewind(register FILE *_fp);
/* ERROR-HANDLING FUNCTIONS */
extern void clearerr(FILE *_fp);
extern int feof(FILE *_fp);
extern int ferror(FILE *_fp);
extern void perror(const char *_s);
/* stdlib.h v15.4.0I15142 */
/* are met: */
/* distribution. */
/* permission. */
#pragma diag_push
#pragma CHECK_MISRA("-6.3") /* standard types required for standard headers */
#pragma CHECK_MISRA("-8.5") /* need to define inline function */
#pragma CHECK_MISRA("-19.1") /* #includes required for implementation */
#pragma diag_push
#pragma CHECK_MISRA("-5.7") /* keep names intact */
typedef struct { int quot, rem; } div_t;
typedef struct { int quot, rem; } ldiv_t;
typedef struct { long long quot, rem; } lldiv_t;
#pragma diag_pop
typedef unsigned short wchar_t;
/* NOTE - Normally, abs, labs, and fabs are expanded inline, so */
/* no formal definition is really required. However, ANSI */
/* requires that they exist as separate functions, so */
/* they are supplied in the library. The prototype is */
/* here mainly for documentation. */
#pragma diag_push
#pragma CHECK_MISRA("-16.4") /* false positives due to builtin declarations */
int abs(int _val);
long labs(long _val);
long long llabs(long long _val);
#pragma diag_pop
int atoi(const char *_st);
long atol(const char *_st);
long long atoll(const char *_st);
int ltoa(long val, char *buffer);
extern double atof(const char *_st);
long strtol(const char *_st, char **_endptr, int _base);
unsigned long strtoul(const char *_st, char **_endptr,
int _base);
long long strtoll(const char *_st, char **_endptr, int _base);
unsigned long long strtoull(const char *_st, char **_endptr,
int _base);
float strtof(const char *_st, char **_endptr);
double strtod(const char *_st, char **_endptr);
long double strtold(const char *_st, char **_endptr);
int rand(void);
void srand(unsigned _seed);
void *calloc(size_t _num, size_t _size)
__attribute__((malloc));
void *malloc(size_t _size)
void *realloc(void *_ptr, size_t _size)
void free(void *_ptr);
void *memalign(size_t _aln, size_t _size)
void abort(void);
typedef void (*__TI_atexit_fn)(void);
int atexit(__TI_atexit_fn _func);
typedef int (*__TI_compar_fn)(const void *_a,const void *_b);
void *bsearch(const void *_key, const void *_base,
size_t _nmemb, size_t _size,
__TI_compar_fn compar);
void qsort(void *_base, size_t _nmemb, size_t _size,
void exit(int _status);
div_t div(int _numer, int _denom);
ldiv_t ldiv(long _numer, long _denom);
lldiv_t lldiv(long long _numer, long long _denom);
char *getenv(const char *_string);
int system(const char *_name);
int mblen(const char *_s, size_t _n);
size_t mbstowcs(wchar_t *_dest, const char *_src, size_t _n);
int mbtowc(wchar_t *_dest, const char *_src, size_t _n);
size_t wcstombs(char *_dest, const wchar_t *_src, size_t _n);
int wctomb(char *_s, wchar_t _wc);
#pragma diag_pop
#pragma diag_push
#pragma diag_pop
#pragma diag_push
/* C2000-specific additions to header implemented with #include */
#pragma diag_pop
DNM DNMSet_a[32];
unsigned char i = 0;
while(i <= 32)
printf("%d",2);
printf("%d", DNMSet_a[i].Addr);
if (DNMSet_a[i++].Addr != 0)
return (&DNMSet_a[i]);
return 0;
memcpy(&this->Name, name, 40);
this->Addr = ip;
this->SerialNo = sn;
this->SubnetMask = subMask;
"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_5.2.5/bin/armcl" -mv7A8 --code_state=32 --float_support=VFPv3 --abi=eabi -me --include_path="C:/ti/ccsv8/tools/compiler/ti-cgt-arm_5.2.5/include" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/uCOS Include" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/NandFlash Include" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/lwip Include" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/FatSystem" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/MP3" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/OSIP" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/RTP" --include_path="C:/ti/ccsv8/ATEIS AM335X/Include/mmcsdlib" --include_path="C:/ti/ccsv8/ATEIS AM335X/Source Code/Include" --include_path="C:/ti/ccsv8/ATEIS AM335X/Source Code/Include/hw" --include_path="C:/ti/ccsv8/ATEIS AM335X/Source Code/Include/armv7a" --include_path="C:/ti/ccsv8/ATEIS AM335X/Source Code/Include/armv7a/am335x" --include_path="C:/ti/ccsv8/ATEIS AM335X/NANDFlash_Programmer/BurnIN_NAND/Web/httpserver_raw" -g --preproc_with_comment --preproc_with_compile --define=am3352 --define=AM335X --define=_FUNCTION_PERFORMANCE_xx --diag_warning=225 --diag_wrap=off --display_error_number --neon --enum_type=int --wchar_t=16 -k --src_interlist --obj_directory="MCU" "../MCU/DNM_Manager.c"
Finished building: "../MCU/DNM_Manager.c"
Compiler: ti v5.2.5
