Part Number: MSP432P401R
What did I do wrong?
I downloaded the FreeRTOS latest download
, and then imported the CCS project into code composer studio V8, and attempted to build it.
I got a warning (but not an error?) :
This project was created using a version of compiler that is not currently installed - 5.2.1 [MSP432]. Another version of the compiler will be used during build - 18.1.4.LTS. See 'Help > Install New Software' and select 'Code Generation Tools Updates' to check if this compiler is available through a CCS update. Visit CCS App Center to get the latest compiler support. Or download and install the compiler, then register it with CCS through 'Preferences > CCS > Build > Compilers'.
And also I got a whole list ((qty 100) of errors -- which indicates what? Is this is TI compiler project, or a GCC compiler project? Somewhere I have read the enclosing __asm function refers to inline assembly (reproduced below).
Many like:
"../Full_Demo/RegTest.c", line 304: error #10: "#" not expected here
cmp r1, #7
^"../Full_Demo/RegTest.c", line 307: error #10: "#" not expected here
cmp r0, #8
^"../Full_Demo/RegTest.c", line 309: error #10: "#" not expected here
cmp r1, #9
The original file has '#" in many lines of assembly code.
cmp r1, #7
bne reg2_error_loopf
vmov r0, r1, d10
cmp r0, #8
cmp r1, #9
any help would be appreciated. There actually three versions of RegTest ... RegTest.asm, RegTest.c and RegTest.s --- I am not understanding what I need to do here to get it to compile under the CCS V8 framework?
* FreeRTOS Kernel V10.1.1
* Copyright (C) 2018 Amazon.com, Inc. or its affiliates. All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy of
* this software and associated documentation files (the "Software"), to deal in
* the Software without restriction, including without limitation the rights to
* use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
* the Software, and to permit persons to whom the Software is furnished to do so,
* subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* http://www.FreeRTOS.org
* http://aws.amazon.com/freertos
* 1 tab == 4 spaces!
__asm void vRegTest1Implementation(void)
PRESERVE8
IMPORT ulRegTest1LoopCounter
/* Fill the core registers with known values. */
mov r0, #100
mov r1, #101
mov r2, #102
mov r3, #103
mov r4, #104
mov r5, #105
mov r6, #106
mov r7, #107
mov r8, #108
mov r9, #109
mov r10, #110
mov r11, #111
mov r12, #112
/* Fill the VFP registers with known values. */
vmov d0, r0, r1
vmov d1, r2, r3
vmov d2, r4, r5
vmov d3, r6, r7
vmov d4, r8, r9
vmov d5, r10, r11
vmov d6, r0, r1
vmov d7, r2, r3
vmov d8, r4, r5
vmov d9, r6, r7
vmov d10, r8, r9
vmov d11, r10, r11
vmov d12, r0, r1
vmov d13, r2, r3
vmov d14, r4, r5
vmov d15, r6, r7
reg1_loop
/* Check all the VFP registers still contain the values set above.
First save registers that are clobbered by the test. */
push { r0-r1 }
vmov r0, r1, d0
cmp r0, #100
bne reg1_error_loopf
cmp r1, #101
vmov r0, r1, d1
cmp r0, #102
cmp r1, #103
vmov r0, r1, d2
cmp r0, #104
cmp r1, #105
vmov r0, r1, d3
cmp r0, #106
cmp r1, #107
vmov r0, r1, d4
cmp r0, #108
cmp r1, #109
vmov r0, r1, d5
cmp r0, #110
cmp r1, #111
vmov r0, r1, d6
cmp r0, #100
cmp r1, #101
vmov r0, r1, d7
cmp r0, #102
cmp r1, #103
vmov r0, r1, d8
cmp r0, #104
cmp r1, #105
vmov r0, r1, d9
cmp r0, #106
cmp r1, #107
vmov r0, r1, d10
cmp r0, #108
cmp r1, #109
vmov r0, r1, d11
cmp r0, #110
cmp r1, #111
vmov r0, r1, d12
cmp r0, #100
cmp r1, #101
vmov r0, r1, d13
cmp r0, #102
cmp r1, #103
vmov r0, r1, d14
cmp r0, #104
cmp r1, #105
vmov r0, r1, d15
cmp r0, #106
cmp r1, #107
/* Restore the registers that were clobbered by the test. */
pop {r0-r1}
/* VFP register test passed. Jump to the core register test. */
b reg1_loopf_pass
reg1_error_loopf
/* If this line is hit then a VFP register value was found to be
incorrect. */
b reg1_error_loopf
reg1_loopf_pass
cmp r0, #100
bne reg1_error_loop
cmp r1, #101
bne reg1_error_loop
cmp r2, #102
bne reg1_error_loop
cmp r3, #103
bne reg1_error_loop
cmp r4, #104
bne reg1_error_loop
cmp r5, #105
bne reg1_error_loop
cmp r6, #106
bne reg1_error_loop
cmp r7, #107
bne reg1_error_loop
cmp r8, #108
bne reg1_error_loop
cmp r9, #109
bne reg1_error_loop
cmp r10, #110
bne reg1_error_loop
cmp r11, #111
bne reg1_error_loop
cmp r12, #112
bne reg1_error_loop
/* Everything passed, increment the loop counter. */
push { r0-r1 }
ldr r0, =ulRegTest1LoopCounter
ldr r1, [r0]
adds r1, r1, #1
str r1, [r0]
pop { r0-r1 }
/* Start again. */
b reg1_loop
reg1_error_loop
/* If this line is hit then there was an error in a core register value.
The loop ensures the loop counter stops incrementing. */
b reg1_error_loop
nop
__asm void vRegTest2Implementation( void )
PRESERVE8
IMPORT ulRegTest2LoopCounter
/* Set all the core registers to known values. */
mov r0, #-1
mov r1, #1
mov r2, #2
mov r3, #3
mov r4, #4
mov r5, #5
mov r6, #6
mov r7, #7
mov r8, #8
mov r9, #9
mov r10, #10
mov r11, #11
mov r12, #12
/* Set all the VFP to known values. */
vmov d0, r0, r1
vmov d1, r2, r3
vmov d2, r4, r5
vmov d3, r6, r7
vmov d4, r8, r9
vmov d5, r10, r11
vmov d6, r0, r1
vmov d7, r2, r3
vmov d8, r4, r5
vmov d9, r6, r7
vmov d10, r8, r9
vmov d11, r10, r11
vmov d12, r0, r1
vmov d13, r2, r3
vmov d14, r4, r5
vmov d15, r6, r7
reg2_loop
push { r0-r1 }
vmov r0, r1, d0
cmp r0, #-1
cmp r1, #1
vmov r0, r1, d1
cmp r0, #2
cmp r1, #3
vmov r0, r1, d2
cmp r0, #4
cmp r1, #5
vmov r0, r1, d3
cmp r0, #6
cmp r1, #7
vmov r0, r1, d4
cmp r0, #8
cmp r1, #9
vmov r0, r1, d5
cmp r0, #10
cmp r1, #11
vmov r0, r1, d6
cmp r0, #-1
cmp r1, #1
vmov r0, r1, d7
cmp r0, #2
cmp r1, #3
vmov r0, r1, d8
cmp r0, #4
cmp r1, #5
vmov r0, r1, d9
cmp r0, #6
cmp r1, #7
vmov r0, r1, d10
cmp r0, #8
cmp r1, #9
vmov r0, r1, d11
cmp r0, #10
cmp r1, #11
vmov r0, r1, d12
cmp r0, #-1
cmp r1, #1
vmov r0, r1, d13
cmp r0, #2
cmp r1, #3
vmov r0, r1, d14
cmp r0, #4
cmp r1, #5
vmov r0, r1, d15
cmp r0, #6
cmp r1, #7
pop {r0-r1}
b reg2_loopf_pass
reg2_error_loopf
incorrect. */
b reg2_error_loopf
reg2_loopf_pass
cmp r0, #-1
bne reg2_error_loop
cmp r1, #1
bne reg2_error_loop
cmp r2, #2
bne reg2_error_loop
cmp r3, #3
bne reg2_error_loop
cmp r4, #4
bne reg2_error_loop
cmp r5, #5
bne reg2_error_loop
cmp r6, #6
bne reg2_error_loop
cmp r7, #7
bne reg2_error_loop
cmp r8, #8
bne reg2_error_loop
cmp r9, #9
bne reg2_error_loop
cmp r10, #10
bne reg2_error_loop
cmp r11, #11
bne reg2_error_loop
cmp r12, #12
bne reg2_error_loop
/* Increment the loop counter to indicate this test is still functioning
correctly. */
push { r0-r1 }
ldr r0, =ulRegTest2LoopCounter
ldr r1, [r0]
adds r1, r1, #1
str r1, [r0]
/* Yield to increase test coverage. */
movs r0, #0x01
ldr r1, =0xe000ed04 /*NVIC_INT_CTRL */
lsl r0, r0, #28 /* Shift to PendSV bit */
str r0, [r1]
dsb
pop { r0-r1 }
/* Start again. */
b reg2_loop
reg2_error_loop
This loop ensures the loop counter variable stops incrementing. */
b reg2_error_loop
__asm void vRegTestClearFlopRegistersToParameterValue( unsigned long ulValue )
PRESERVE8
/* Clobber the auto saved registers. */
vmov d0, r0, r0
vmov d1, r0, r0
vmov d2, r0, r0
vmov d3, r0, r0
vmov d4, r0, r0
vmov d5, r0, r0
vmov d6, r0, r0
vmov d7, r0, r0
bx lr
__asm void ulRegTestCheckFlopRegistersContainParameterValue( unsigned long ulValue )
PRESERVE8
vmov r1, s0
cmp r0, r1
bne return_error
vmov r1, s1
cmp r0, r1
bne return_error
vmov r1, s2
cmp r0, r1
bne return_error
vmov r1, s3
cmp r0, r1
bne return_error
vmov r1, s4
cmp r0, r1
bne return_error
vmov r1, s5
cmp r0, r1
bne return_error
vmov r1, s6
cmp r0, r1
bne return_error
vmov r1, s7
cmp r0, r1
bne return_error
vmov r1, s8
cmp r0, r1
bne return_error
vmov r1, s9
cmp r0, r1
bne return_error
vmov r1, s10
cmp r0, r1
bne return_error
vmov r1, s11
cmp r0, r1
bne return_error
vmov r1, s12
cmp r0, r1
bne return_error
vmov r1, s13
cmp r0, r1
bne return_error
vmov r1, s14
cmp r0, r1
bne return_error
vmov r1, s15
cmp r0, r1
bne return_error
return_pass
mov r0, #1
bx lr
return_error
mov r0, #0
bx lr
PRESERVE8
mov r0, #100
mov r1, #101
mov r2, #102
mov r3, #103
mov r4, #104
mov r5, #105
mov r6, #106
mov r7, #107
mov r8, #108
mov r9, #109
mov r10, #110
mov r11, #111
mov r12, #112
vmov d0, r0, r1
vmov d1, r2, r3
vmov d2, r4, r5
vmov d3, r6, r7
vmov d4, r8, r9
vmov d5, r10, r11
vmov d6, r0, r1
vmov d7, r2, r3
vmov d8, r4, r5
vmov d9, r6, r7
vmov d10, r8, r9
vmov d11, r10, r11
vmov d12, r0, r1
vmov d13, r2, r3
vmov d14, r4, r5
vmov d15, r6, r7
reg1_loop
push { r0-r1 }
vmov r0, r1, d0
cmp r0, #100
cmp r1, #101
vmov r0, r1, d1
cmp r0, #102
cmp r1, #103
vmov r0, r1, d2
cmp r0, #104
cmp r1, #105
vmov r0, r1, d3
cmp r0, #106
cmp r1, #107
vmov r0, r1, d4
cmp r0, #108
cmp r1, #109
vmov r0, r1, d5
cmp r0, #110
cmp r1, #111
vmov r0, r1, d6
cmp r0, #100
cmp r1, #101
vmov r0, r1, d7
cmp r0, #102
cmp r1, #103
vmov r0, r1, d8
cmp r0, #104
cmp r1, #105
vmov r0, r1, d9
cmp r0, #106
cmp r1, #107
vmov r0, r1, d10
cmp r0, #108
cmp r1, #109
vmov r0, r1, d11
cmp r0, #110
cmp r1, #111
vmov r0, r1, d12
cmp r0, #100
cmp r1, #101
vmov r0, r1, d13
cmp r0, #102
cmp r1, #103
vmov r0, r1, d14
cmp r0, #104
cmp r1, #105
vmov r0, r1, d15
cmp r0, #106
cmp r1, #107
pop {r0-r1}
b reg1_loopf_pass
reg1_error_loopf
incorrect. */
b reg1_error_loopf
reg1_loopf_pass
cmp r0, #100
bne reg1_error_loop
cmp r1, #101
bne reg1_error_loop
cmp r2, #102
bne reg1_error_loop
cmp r3, #103
bne reg1_error_loop
cmp r4, #104
bne reg1_error_loop
cmp r5, #105
bne reg1_error_loop
cmp r6, #106
bne reg1_error_loop
cmp r7, #107
bne reg1_error_loop
cmp r8, #108
bne reg1_error_loop
cmp r9, #109
bne reg1_error_loop
cmp r10, #110
bne reg1_error_loop
cmp r11, #111
bne reg1_error_loop
cmp r12, #112
bne reg1_error_loop
push { r0-r1 }
ldr r1, [r0]
adds r1, r1, #1
str r1, [r0]
pop { r0-r1 }
/* Start again. */
b reg1_loop
reg1_error_loop
b reg1_error_loop
nop
PRESERVE8
mov r0, #-1
mov r1, #1
mov r2, #2
mov r3, #3
mov r4, #4
mov r5, #5
mov r6, #6
mov r7, #7
mov r8, #8
mov r9, #9
mov r10, #10
mov r11, #11
mov r12, #12
vmov d0, r0, r1
vmov d1, r2, r3
vmov d2, r4, r5
vmov d3, r6, r7
vmov d4, r8, r9
vmov d5, r10, r11
vmov d6, r0, r1
vmov d7, r2, r3
vmov d8, r4, r5
vmov d9, r6, r7
vmov d10, r8, r9
vmov d11, r10, r11
vmov d12, r0, r1
vmov d13, r2, r3
vmov d14, r4, r5
vmov d15, r6, r7
reg2_loop
push { r0-r1 }
vmov r0, r1, d0
cmp r0, #-1
cmp r1, #1
vmov r0, r1, d1
cmp r0, #2
cmp r1, #3
vmov r0, r1, d2
cmp r0, #4
cmp r1, #5
vmov r0, r1, d3
cmp r0, #6
cmp r1, #7
vmov r0, r1, d4
cmp r0, #8
cmp r1, #9
vmov r0, r1, d5
cmp r0, #10
cmp r1, #11
vmov r0, r1, d6
cmp r0, #-1
cmp r1, #1
vmov r0, r1, d7
cmp r0, #2
cmp r1, #3
vmov r0, r1, d8
cmp r0, #4
cmp r1, #5
vmov r0, r1, d9
cmp r0, #6
cmp r1, #7
vmov r0, r1, d10
cmp r0, #8
cmp r1, #9
vmov r0, r1, d11
cmp r0, #10
cmp r1, #11
vmov r0, r1, d12
cmp r0, #-1
cmp r1, #1
vmov r0, r1, d13
cmp r0, #2
cmp r1, #3
vmov r0, r1, d14
cmp r0, #4
cmp r1, #5
vmov r0, r1, d15
cmp r0, #6
cmp r1, #7
pop {r0-r1}
b reg2_loopf_pass
reg2_error_loopf
incorrect. */
b reg2_error_loopf
reg2_loopf_pass
cmp r0, #-1
bne reg2_error_loop
cmp r1, #1
bne reg2_error_loop
cmp r2, #2
bne reg2_error_loop
cmp r3, #3
bne reg2_error_loop
cmp r4, #4
bne reg2_error_loop
cmp r5, #5
bne reg2_error_loop
cmp r6, #6
bne reg2_error_loop
cmp r7, #7
bne reg2_error_loop
cmp r8, #8
bne reg2_error_loop
cmp r9, #9
bne reg2_error_loop
cmp r10, #10
bne reg2_error_loop
cmp r11, #11
bne reg2_error_loop
cmp r12, #12
bne reg2_error_loop
correctly. */
push { r0-r1 }
ldr r1, [r0]
adds r1, r1, #1
str r1, [r0]
movs r0, #0x01
str r0, [r1]
dsb
pop { r0-r1 }
/* Start again. */
b reg2_loop
reg2_error_loop
b reg2_error_loop
PRESERVE8
vmov d0, r0, r0
vmov d1, r0, r0
vmov d2, r0, r0
vmov d3, r0, r0
vmov d4, r0, r0
vmov d5, r0, r0
vmov d6, r0, r0
vmov d7, r0, r0
bx lr
PRESERVE8
vmov r1, s0
cmp r0, r1
bne return_error
vmov r1, s1
cmp r0, r1
bne return_error
vmov r1, s2
cmp r0, r1
bne return_error
vmov r1, s3
cmp r0, r1
bne return_error
vmov r1, s4
cmp r0, r1
bne return_error
vmov r1, s5
cmp r0, r1
bne return_error
vmov r1, s6
cmp r0, r1
bne return_error
vmov r1, s7
cmp r0, r1
bne return_error
vmov r1, s8
cmp r0, r1
bne return_error
vmov r1, s9
cmp r0, r1
bne return_error
vmov r1, s10
cmp r0, r1
bne return_error
vmov r1, s11
cmp r0, r1
bne return_error
vmov r1, s12
cmp r0, r1
bne return_error
vmov r1, s13
cmp r0, r1
bne return_error
vmov r1, s14
cmp r0, r1
bne return_error
vmov r1, s15
cmp r0, r1
bne return_error
return_pass
mov r0, #1
bx lr
return_error
mov r0, #0
bx lr
