CCS: CCS V8
Genius 3095 points
Dear team:
I'm attempting to install code composer studio v8 with the offline installer. When I run the installer (as an administrator) the installer hangs up at the stage where it is installing the TI emulation drivers. If I look at the task manager, the Tclsh Application is spawning new instances of the Driver Package Installer over and over, until it eats up all available memory.  I've tried several times with the same results.
I have successfully installed CCS v6.1 on the same computer with no issues. Computer has Windows 10 Pro installed.
I'm wondering if this is a known issue and what the workaround is to get the installer to run successfully. Thanks!
Best regards
