Is there a way to pipe the output in the console to a file.
I am using printf() to print to the console screen, but I would like to pipe that to a file using CCS. Can you suggest a way to do this?
sal
sal
Hi Sal,
Please check this thread: https://e2e.ti.com/support/tools/ccs/f/81/t/611485
Hope this helps!
Hi Sal,
Are you still using CCS to load and debug the .out file, even if not using a CCS project to build? If so, you can access that property from the menu Run->Debug Configurations, as it is tied to a debug configuration rather than a project. Unless I am misunderstanding your use-case.
