Other Parts Discussed in Thread: TM4C129XNCZAD, CC2564
I am using Tm4c129xnczad controller interfacing with CC2564 Bluetooth program here the problem is i don't have any warnings and errors but while building i need to get
Finished building target: SPPDemo.out'
'Convert TI .out file to .bin'
"C:/ti/ccsv6/utils/tiobj2bin/tiobj2bin.bat" "SPPDemo.out" "SPPDemo.bin" "C:/ti/ccsv6/tools/compiler/arm_5.2.8/bin/armofd.exe" "C:/ti/ccsv6/tools/compiler/arm_5.2.8/bin/armhex.exe" "C:/ti/ccsv6/utils/tiobj2bin/mkhex4bin.exe"
' ' like this instead i am getting like this
**** Build of configuration Debug - DK-TM4C129X for project SPPDemo **** "C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all C:/ti/CC256BT PROG/v1.1/Cortex_M4/Sample/SPPDemo/NoOS/CCSv5/../../../../BuildScripts/SetTivaWarePath.bat C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>if NOT ! == ! GOTO TIVAWARE_PATH_DEFINED C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>set TIVAWARE_PATH=C:\ti\TivaWare_C_Series-2.1.3.156 C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>set HOME_PATH=. C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>IF ! == ! GOTO :CHECK_PATH C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>set SCRIPT_PATH=.\..\..\..\..\ C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>IF EXIST .\..\..\..\..\\BuildScripts GOTO :SCRIPT_PATH_EXISTS C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>set SCRIPT_PATH=.\..\..\..\..\.. C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>IF EXIST .\..\..\..\..\..\BuildScripts GOTO :SCRIPT_PATH_EXISTS C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\third_party 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\examples\board\dk-tm4c123g 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.3.156\driverlib\rvmdk 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_LD_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.3.156\grlib\rvmdk 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_LD_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\third_party 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\examples\boards\dk-tm4c129x 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.3.156\driverlib\rvmdk 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_LD_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.3.156\grlib\rvmdk 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_LD_RVMDK.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\third_party 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\examples\board\dk-tm4c123g 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --search C:\ti\TivaWare_C_Series-2.1.3.156\driverlib\ewarm\exe 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_LD_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --search C:\ti\TivaWare_C_Series-2.1.3.156\grlib\ewarm\exe 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_LD_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\third_party 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156\examples\boards\dk-tm4c129x 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --search C:\ti\TivaWare_C_Series-2.1.3.156\driverlib\ewarm\exe 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_LD_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo --search C:\ti\TivaWare_C_Series-2.1.3.156\grlib\ewarm\exe 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_LD_EWARM.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156/third_party 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156/examples/boards/dk-tm4c123g 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -iC:\ti\TivaWare_C_Series-2.1.3.156\driverlib\ccs\Debug 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -iC:\ti\TivaWare_C_Series-2.1.3.156\grlib\ccs\Debug 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156 1>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156/third_party 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -IC:\ti\TivaWare_C_Series-2.1.3.156/examples/boards/dk-tm4c129x 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -iC:\ti\TivaWare_C_Series-2.1.3.156\driverlib\ccs\Debug 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt C:\ti\CC256BT PROG\v1.1\Cortex_M4\Sample\SPPDemo\NoOS\CCSv5\Debug - DK-TM4C129X>echo -iC:\ti\TivaWare_C_Series-2.1.3.156\grlib\ccs\Debug 1>>.\..\..\..\..\..\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt ' ' gmake[1]: Nothing to be done for 'main-build'. **** Build Finished ****
