CCS/CC2650STK: Project Zero not compiling from Simplink Academy v1.11
Part Number: CC2650STK
Other Parts Discussed in Thread: CC2650, BLE-STACK
I have been following this documentation and trying to learn writing my own GATT services for CC2650 SensorTag device, but I am getting these errors while building the project. Attached is the log file.
**** Build of configuration Debug for project project_zero_stack_cc2650 ****
"C:\\ti\\ccsv8\\utils\\bin\\gmake" -j -k -j 4 all -O
"c:/ti/simplelink/ble_sdk_2_02_01_18/tools/lib_search/lib_search.exe" C:/Users/Red Rose/Documents/cs_wrk-space/project_zero_stack_cc2650/TOOLS/build_config.opt "c:/ti/simplelink/ble_sdk_2_02_01_18/tools/lib_search/params_split_cc2640.xml" c:/ti/simplelink/ble_sdk_2_02_01_18/blelib "C:/Users/Red Rose/Documents/cs_wrk-space/project_zero_stack_cc2650/TOOLS/lib_linker.cmd"
makefile:214: recipe for target 'pre-build' failed
<<< ERROR >>>
Cannot find input file "C:/Users/Red"
<<< /ERROR >>>
gmake[1]: [pre-build] Error 1 (ignored)
Building target: "project_zero_stack_cc2650.out"
Invoking: ARM Linker
"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.4.LTS/bin/armcl" --cmd_file="c:/ti/simplelink/ble_sdk_2_02_01_18/src/config/build_components.opt" --cmd_file="C:/Users/Red Rose/Documents/cs_wrk-space/project_zero_stack_cc2650/TOOLS/build_config.opt"  -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --define=USE_ICALL --define=OSAL_SNV=1 --define=FLASH_ROM_BUILD --define=POWER_SAVING --define=GATT_NO_CLIENT --define=INCLUDE_AES_DECRYPT --define=xPM_DISABLE_PWRDOWN --define=xTESTMODES --define=xTEST_BLEBOARD --define=OSAL_CBTIMER_NUM_TASKS=1 --define=xDEBUG --define=EXT_HAL_ASSERT --define=xDEBUG_GPIO --define=xDEBUG_ENC --define=xDEBUG_SW_TRACE --define=NEAR_FUNC= --define=DATA= --define=CC26XXWARE --define=CC26XX -g --c99 --gcc --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi -z -m"project_zero_stack_cc2650.map" --heap_size=0 --stack_size=256 -i"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.4.LTS/lib" -i"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.4.LTS/include" --reread_libs --diag_suppress=16002-D --diag_suppress=10247-D --diag_suppress=10325-D --diag_suppress=10229-D --diag_suppress=16004-D --diag_wrap=off --display_error_number --warn_sections --xml_link_info="project_zero_stack_cc2650_linkInfo.xml" --entry_point=startup_entry --rom_model -o "project_zero_stack_cc2650.out" "./HAL/Common/hal_assert.obj" "./HAL/Target/CC2650/Drivers/hal_flash_wrapper.obj" "./HAL/Target/CC2650/Drivers/hal_rtc_wrapper.obj" "./HAL/Target/CC2650/Drivers/hal_trng_wrapper.obj" "./HAL/Target/CC2650/_common/mb_patch.obj" "./ICallBLE/ble_dispatch.obj" "./NPI/npi.obj" "./OSAL/osal.obj" "./OSAL/osal_bufmgr.obj" "./OSAL/osal_cbtimer.obj" "./OSAL/osal_clock.obj" "./OSAL/osal_memory_icall.obj" "./OSAL/osal_pwrmgr.obj" "./OSAL/osal_snv_wrapper.obj" "./OSAL/osal_timers.obj" "./PROFILES/gap.obj" "./PROFILES/gapbondmgr.obj" "./PROFILES/gattservapp_util.obj" "./Startup/ble_user_config.obj" "./Startup/common_rom_init.obj" "./Startup/icall_startup.obj" "./Startup/osal_icall_ble.obj" "./Startup/rom_init.obj" "./TOOLS/onboard.obj"  -l"C:/Users/Red Rose/Documents/cs_wrk-space/project_zero_stack_cc2650/TOOLS/lib_linker.cmd" -l"c:/ti/simplelink/ble_sdk_2_02_01_18/src/rom/enc_lib/cc26xx_ecc_rom_api.a" -l"c:/ti/simplelink/ble_sdk_2_02_01_18/src/rom/ble_rom_releases/04242014/ble_rom_patch.symbols" -l"c:/ti/tirtos_cc13xx_cc26xx_2_20_01_08/products/cc26xxware_2_24_02_17393/driverlib/bin/ccs/driverlib.lib" -l"C:/Users/Red Rose/Documents/cs_wrk-space/project_zero_stack_cc2650/TOOLS/ccs_linker_defines.cmd" -l"c:/ti/simplelink/ble_sdk_2_02_01_18/src/common/cc26xx/ccs/cc26xx_stack.cmd" -llibc.a
<Linking>
error #10008-D: cannot find file "C:/Users/Red Rose/Documents/cs_wrk-space/project_zero_stack_cc2650/TOOLS/lib_linker.cmd"
 undefined                              first referenced
  symbol                                    in file
 ATT_ErrorRsp                           <whole-program>
 ATT_ExecuteWriteRsp                    <whole-program>
 ATT_ReadBlobRsp                        <whole-program>
 ATT_ReadRsp                            <whole-program>
 ATT_WriteRsp                           <whole-program>
 GAP_Authenticate                       <whole-program>
 GAP_Bond                               <whole-program>
 GAP_ConfigDeviceAddr                   <whole-program>
 GAP_EndDiscoverable                    <whole-program>
 GAP_GetParamValue                      <whole-program>
 GAP_Init                               <whole-program>
 GAP_MakeDiscoverable                   <whole-program>
 GAP_NumActiveConnections               <whole-program>
 GAP_ParamsInit                         <whole-program>
 GAP_PasscodeUpdate                     <whole-program>
 GAP_PasskeyUpdate                      <whole-program>
 GAP_PeriConnRegister                   <whole-program>
 GAP_PeriDevMgrInit                     <whole-program>
 GAP_PrivacyInit                        <whole-program>
 GAP_ProcessEvent                       <whole-program>
 GAP_RegisterBondMgrCBs                 <whole-program>
 GAP_RegisterForMsgs                    <whole-program>
 GAP_RemoveAdvToken                     <whole-program>
 GAP_ResolvePrivateAddr                 <whole-program>
 GAP_SecParamsInit                      <whole-program>
 GAP_SendSlaveSecurityRequest           <whole-program>
 GAP_SetAdvToken                        <whole-program>
 GAP_SetParamValue                      <whole-program>
 GAP_Signable                           <whole-program>
 GAP_TerminateAuth                      <whole-program>
 GAP_TerminateLinkReq                   <whole-program>
 GAP_UpdateAdvTokens                    <whole-program>
 GAP_UpdateAdvertisingData              <whole-program>
 GAP_UpdateLinkParamReq                 <whole-program>
 GAP_UpdateLinkParamReqReply            <whole-program>
 GATTServApp_AddService                 <whole-program>
 GATTServApp_DeregisterService          <whole-program>
 GATTServApp_GetParameter               <whole-program>
 GATTServApp_Init                       <whole-program>
 GATTServApp_ProcessEvent               <whole-program>
 GATTServApp_ReadAttr                   <whole-program>
 GATTServApp_RegisterForMsg             <whole-program>
 GATTServApp_RegisterService            <whole-program>
 GATTServApp_SendCCCUpdatedEvent        <whole-program>
 GATTServApp_SetParameter               <whole-program>
 GATTServApp_UpdateCharCfg              <whole-program>
 GATT_AppCompletedMsg                   <whole-program>
 GATT_FindHandleUUID                    <whole-program>
 GATT_FindNextAttr                      <whole-program>
 GATT_GetNextHandle                     <whole-program>
 GATT_Indication                        <whole-program>
 GATT_Init                              <whole-program>
 GATT_Notification                      <whole-program>
 GATT_ProcessEvent                      <whole-program>
 GATT_RegisterForMsgs                   <whole-program>
 GATT_SendRsp                           <whole-program>
 GATT_SetHostToAppFlowCtrl              <whole-program>
 GATT_bm_alloc                          <whole-program>
 GATT_bm_free                           <whole-program>
 GGS_AddService                         <whole-program>
 GGS_GetParameter                       <whole-program>
 GGS_RegisterAppCBs                     <whole-program>
 GGS_SetParameter                       <whole-program>
 HCI_EXT_ConnEventNoticeCmd             <whole-program>
 HCI_EXT_DelaySleepCmd                  <whole-program>
 HCI_EXT_GetConnInfoCmd                 <whole-program>
 HCI_EXT_ResetSystemCmd                 <whole-program>
 HCI_Init                               <whole-program>
 HCI_LE_ConnUpdateCmd                   <whole-program>
 HCI_LE_ReadBufSizeCmd                  <whole-program>
 HCI_LE_ReadRemoteUsedFeaturesCmd       <whole-program>
 HCI_LE_ReceiverTestCmd                 <whole-program>
 HCI_LE_SetEventMaskCmd                 <whole-program>
 HCI_LE_TransmitterTestCmd              <whole-program>
 HCI_NumOfCompletedPacketsEvent         <whole-program>
 HCI_ProcessEvent                       <whole-program>
 HCI_ReadLocalSupportedCommandsCmd      <whole-program>
 HCI_ReadLocalVersionInfoCmd            <whole-program>
 HCI_ReadRssiCmd                        <whole-program>
 HCI_ResetCmd                           <whole-program>
 HCI_SetEventMaskPage2Cmd               <whole-program>
 HCI_ValidConnTimeParams                <whole-program>
 HCI_VendorSpecifcCommandCompleteEvent  <whole-program>
 L2CAP_ConnParamUpdateReq               <whole-program>
 L2CAP_Init                             <whole-program>
 L2CAP_ProcessEvent                     <whole-program>
 L2CAP_SetUserConfig                    <whole-program>
 L2CAP_bm_alloc                         <whole-program>
 LL_DirectTestEnd                       <whole-program>
 LL_DirectTestRxTest                    <whole-program>
 LL_DirectTestTxTest                    <whole-program>
 LL_ENC_Decrypt                         <whole-program>
 LL_ENC_Encrypt                         <whole-program>
 LL_EXT_BuildRevision                   <whole-program>
 LL_EXT_ConnEventNotice                 <whole-program>
 LL_EXT_EndModemTest                    <whole-program>
 LL_EXT_ModemHopTestTx                  <whole-program>
 LL_EXT_ModemTestRx                     <whole-program>
 LL_EXT_ModemTestTx                     <whole-program>
 LL_EXT_NumComplPktsLimit               <whole-program>
 LL_EXT_SetLocalSupportedFeatures       <whole-program>
 LL_EXT_SetMaxDtmTxPower                <whole-program>
 LL_EXT_SetTxPower                      <whole-program>
 LL_EncLtkNegReply                      <whole-program>
 LL_EncLtkReply                         <whole-program>
 LL_Init                                <whole-program>
 LL_PM_Enter_AES                        <whole-program>
 LL_PM_Exit_AES                         <whole-program>
 LL_PM_GetRfCoreState                   <whole-program>
 LL_PM_PowerOffRfCore                   <whole-program>
 LL_ProcessEvent                        <whole-program>
 LL_ReadRemoteUsedFeatures              <whole-program>
 LL_ReadRemoteUsedFeaturesCompleteCback <whole-program>
 LL_ReadSupportedStates                 <whole-program>
 LL_ReadTxPowerLevel                    <whole-program>
 LL_Reset                               <whole-program>
 LL_RxDataCompleteCback                 <whole-program>
 LL_SetAdvControl                       <whole-program>
 LL_SetAdvParam                         <whole-program>
 LL_TxData                              <whole-program>
 RFHAL_AddTxDataEntry                   <whole-program>
 RFHAL_InitRfHal                        <whole-program>
 SM_Init                                <whole-program>
 SM_ProcessEvent                        <whole-program>
 SM_ResponderInit                       <whole-program>
 SysBootMsg                             <whole-program>
 WL_Clear                               <whole-program>
 WL_ClearIgnoreList                     <whole-program>
 WL_FindEntry                           <whole-program>
 WL_GetNumFreeEntries                   <whole-program>
 WL_SetWlIgnore                         <whole-program>
 clientCharCfgUUID                      <whole-program>
 hciGapTaskID                           <whole-program>
 hciL2capTaskID                         <whole-program>
 hciSmpTaskID                           <whole-program>
 hciTaskID                              <whole-program>
 hciTestTaskID                          <whole-program>
 linkDB_Find                            <whole-program>
 linkDB_GetInfo                         <whole-program>
 linkDB_NumActive                       <whole-program>
 linkDB_NumConns                        <whole-program>
 linkDB_State                           <whole-program>
 llActiveTask                           <whole-program>
 llAdv_TaskConnect                      <whole-program>
 llAdv_TaskEnd                          <whole-program>
 llAllocConnId                          <whole-program>
 llAllocTask                            <whole-program>
 llCheckWhiteListUsage                  <whole-program>
 llConfigTable                          <whole-program>
 llConnCleanup                          <whole-program>
 llDequeueCtrlPkt                       <whole-program>
 llDirAdv_TaskEnd                       <whole-program>
 llGetCurrentTime                       <whole-program>
 llGetMinCI                             <whole-program>
 llGetNextConn                          <whole-program>
 llGetNextDataChan                      <whole-program>
 llGetTask                              <whole-program>
 llGetTaskState                         <whole-program>
 llGetTxPower                           <whole-program>
 llHaltRadio                            <whole-program>
 llHardwareError                        <whole-program>
 llInitFeatureSet                       <whole-program>
 llInitRAT                              <whole-program>
 llProcessChanMap                       <whole-program>
 llProcessSlaveControlPacket            <whole-program>
 llProcessSlaveControlProcedures        <whole-program>
 llProcessTxData                        <whole-program>
 llRatChanCBack_A                       <whole-program>
 llReplaceCtrlPkt                       <whole-program>
 llRfInit                               <whole-program>
 llRfStartFS                            <whole-program>
 llScheduleTask                         <whole-program>
 llSchedulerInit                        <whole-program>
 llSetNextDataChan                      <whole-program>
 llSetTxPower                           <whole-program>
 llSetupConnRxDataEntryQueue            <whole-program>
 llSetupFeatureSetRsp                   <whole-program>
 llSetupNextSlaveEvent                  <whole-program>
 llSetupRATChanCompare                  <whole-program>
 llSetupStartEncReq                     <whole-program>
 llSetupTermInd                         <whole-program>
 llSlave_TaskEnd                        <whole-program>
 llUserConfig                           <whole-program>
 llWriteTxData                          <whole-program>
 ll_buildRevision                       <whole-program>
 trngDrvTblPtr                          <whole-program>
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "project_zero_stack_cc2650.out" not built
>> Compilation failure
makefile:190: recipe for target 'project_zero_stack_cc2650.out' failed
gmake[2]: *** [project_zero_stack_cc2650.out] Error 1
gmake[1]: *** [main-build] Error 2
gmake: *** [all] Error 2
makefile:186: recipe for target 'main-build' failed
makefile:181: recipe for target 'all' failed
**** Build Finished ****
Thanks in advance.
