CCS: C2000_LaunchPad XL- F28027
Other Parts Discussed in Thread: CONTROLSUITE
hi,
C28xx: GEL: Encountered a problem loading file: C:\ti\controlSUITE\development_kits\C2000_LaunchPad\f2802x_examples\cpu_timer\RAM\Example_F2802xCpuTimer.out Could not open file
unable to run normal blinking led code also as  same error persists.
even the library is unable to get located although the search path is saved for that directory.
please help me with it.
thank you,
tejaswi.
  • This error almost always indicates that the project failed to build, hence the executable (*.out) was not generated. As a result the debugger is unable to find the file to load. Check the CCS build console and the Problems view for build errors and make sure to correct them first.
