Compiler: 28035
Is there any material required for external crystal vibration of c2000 series? Currently using 28035, crystal vibration always input waveform is wrong, resulting in DSP crash, help!
  • Are you saying whenever there is an external vibration, it distorts the waveform of the crystal oscillator output to an extent where the MCU crashes? By "material required", are you referring to any material around the crystal to absorb such vibrations? If the answers to the questions are "yes", this has nothing to do with the MCU. You need to take this up with the crystal manufacturer or look into another crystal that is not as susceptible to mechanical vibrations.
    On a different note, your subject line says "Compiler", but the question has nothing to do with compiler. Please use correct/meaningful information in the subject line. This would help us to provide a faster response to your questions.
