As title, this color is too dark to see instruction.
Andy,
There are 2 settings. One for highlighting the current line. i.e. where your cursor is placed. This one impacts the editor and the disassembly view. That option is here (at the bottom):
That one impacts the line with the { in the editor and the printf line in the disassembly view in this capture.
For the line with the program counter in the disassembly window that option will change when I switch "Themes" in CCS but I don't see a way to change it directly. This is a bug filed with Eclipse tracking this but there is no resolution:
Using the Linux dark theme looks a little better on my machine but not much:
I installed the Color Theme plugin from the Eclipse market place. Using that I was able to apply some other settings that make it a lot better. That may be worth trying:
You can install this by going to Help. Select Eclipse Marketplace. Then search for theme and it will be the first result.
John
