Part Number: CCSTUDIO-C2000
Other Parts Discussed in Thread: CONTROLSUITE
I am attempting to fill unused Flash with a jump to self instruction 0x6F00. In the c28377D.cmd file, I have modified the FLASHA_N line as follows:
FLASHA_N : origin = 0x080002, length = 0x03FFFE /* on-chip Flash */
To:
FLASHA_N : origin = 0x080002, length = 0x03FFFE, FILL = 0x6F00 /* on-chip Flash */
When attempting to link, the following error is produced:
<Linking>
INTERNAL ERROR: C:\PROGRA~3\MATLAB\SUPPOR~1\R2017b\3P778C~1.INS\TIC200~1.INS\ti-cgt-c2000_16.9.2.LTS\bin\lnk2000.exe experienced an unhandled exception
This is caused by a defect in the compiler itself. TI Customer
Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue". Include this ENTIRE error message and a
copy of the .pp file created when option --preproc_with_comment
(-ppc) is used.
>> Compilation failure
makefile:156: recipe for target 'bill.out' failed
gmake: *** [bill.out] Error 1
Although I have the --preproc_with_compile option enabled, I am unable to locate the ".pp file" mentioned in the error message.
The entire output from the build process is shown below:
**** Clean-only build of configuration Debug for project bill ****
"C:\\ti\\ccsv8\\utils\\bin\\gmake" -k clean
DEL /F "bill.out"
DEL /F "F2837xD_Adc.obj" "F2837xD_CodeStartBranch.obj" "F2837xD_CpuTimers.obj" "F2837xD_DefaultISR.obj" "F2837xD_Dma.obj" "F2837xD_GlobalVariableDefs.obj" "F2837xD_Gpio.obj" "F2837xD_Ipc_Driver_Lite.obj" "F2837xD_PieCtrl.obj" "F2837xD_PieVect.obj" "F2837xD_SysCtrl.obj" "F2837xD_usDelay.obj" "MW_c28xx_board.obj" "MW_c28xx_csl.obj" "bill.obj" "bill_data.obj" "c2837xDBoard_Realtime_Support.obj" "c2837xDSchedulerTimer0.obj" "ert_main.obj" "pgcu_global_constants.obj" "profiler_Support.obj"
DEL /F "F2837xD_Adc.d" "F2837xD_CpuTimers.d" "F2837xD_DefaultISR.d" "F2837xD_Dma.d" "F2837xD_GlobalVariableDefs.d" "F2837xD_Gpio.d" "F2837xD_Ipc_Driver_Lite.d" "F2837xD_PieCtrl.d" "F2837xD_PieVect.d" "F2837xD_SysCtrl.d" "MW_c28xx_board.d" "MW_c28xx_csl.d" "bill.d" "bill_data.d" "c2837xDBoard_Realtime_Support.d" "c2837xDSchedulerTimer0.d" "ert_main.d" "pgcu_global_constants.d" "profiler_Support.d"
DEL /F "F2837xD_CodeStartBranch.d" "F2837xD_usDelay.d"
Could Not Find C:\Builds\Test\Version\bill_ert_rtw\CCS_Project\Debug\F2837xD_CodeStartBranch.d
Finished clean
**** Build Finished ****
**** Build of configuration Debug for project bill ****
"C:\\ti\\ccsv8\\utils\\bin\\gmake" -k all
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Adc.c"
Invoking: C2000 Compiler
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_Adc.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Adc.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Adc.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CodeStartBranch.asm"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_CodeStartBranch.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CodeStartBranch.asm"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CodeStartBranch.asm"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CpuTimers.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_CpuTimers.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CpuTimers.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CpuTimers.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_DefaultISR.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_DefaultISR.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_DefaultISR.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_DefaultISR.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Dma.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_Dma.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Dma.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Dma.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/source/F2837xD_GlobalVariableDefs.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_GlobalVariableDefs.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/source/F2837xD_GlobalVariableDefs.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/source/F2837xD_GlobalVariableDefs.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Gpio.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_Gpio.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Gpio.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Gpio.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Ipc_Driver_Lite.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_Ipc_Driver_Lite.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Ipc_Driver_Lite.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Ipc_Driver_Lite.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieCtrl.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_PieCtrl.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieCtrl.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieCtrl.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieVect.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_PieVect.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieVect.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieVect.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_SysCtrl.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_SysCtrl.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_SysCtrl.c"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_SysCtrl.c"
Building file: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_usDelay.asm"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="F2837xD_usDelay.d_raw" "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_usDelay.asm"
Finished building: "C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_usDelay.asm"
Building file: "C:/Builds/Test/Version/bill_ert_rtw/MW_c28xx_board.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="MW_c28xx_board.d_raw" "C:/Builds/Test/Version/bill_ert_rtw/MW_c28xx_board.c"
Finished building: "C:/Builds/Test/Version/bill_ert_rtw/MW_c28xx_board.c"
Building file: "C:/Builds/Test/Version/bill_ert_rtw/MW_c28xx_csl.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="MW_c28xx_csl.d_raw" "C:/Builds/Test/Version/bill_ert_rtw/MW_c28xx_csl.c"
Finished building: "C:/Builds/Test/Version/bill_ert_rtw/MW_c28xx_csl.c"
Building file: "C:/Builds/Test/Version/bill_ert_rtw/bill.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="bill.d_raw" "C:/Builds/Test/Version/bill_ert_rtw/bill.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include/stdbool.h", line 36: warning: incompatible redefinition of macro "false" (declared at line 22 of "C:\Builds\Test\Version\bill_ert_rtw\rtwtypes.h")
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include/stdbool.h", line 37: warning: incompatible redefinition of macro "true" (declared at line 26 of "C:\Builds\Test\Version\bill_ert_rtw\rtwtypes.h")
Finished building: "C:/Builds/Test/Version/bill_ert_rtw/bill.c"
Building file: "C:/Builds/Test/Version/bill_ert_rtw/bill_data.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="bill_data.d_raw" "C:/Builds/Test/Version/bill_ert_rtw/bill_data.c"
Finished building: "C:/Builds/Test/Version/bill_ert_rtw/bill_data.c"
Building file: "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDBoard_Realtime_Support.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="c2837xDBoard_Realtime_Support.d_raw" "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDBoard_Realtime_Support.c"
Finished building: "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDBoard_Realtime_Support.c"
Building file: "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDSchedulerTimer0.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="c2837xDSchedulerTimer0.d_raw" "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDSchedulerTimer0.c"
"C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDSchedulerTimer0.c", line 135: warning: variable "pulMsgRam" was set but never used
Finished building: "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDSchedulerTimer0.c"
Building file: "C:/Builds/Test/Version/bill_ert_rtw/ert_main.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="ert_main.d_raw" "C:/Builds/Test/Version/bill_ert_rtw/ert_main.c"
Finished building: "C:/Builds/Test/Version/bill_ert_rtw/ert_main.c"
Building file: "C:/Builds/Test/Version/pgcu_global_constants.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="pgcu_global_constants.d_raw" "C:/Builds/Test/Version/pgcu_global_constants.c"
Finished building: "C:/Builds/Test/Version/pgcu_global_constants.c"
Building file: "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/profiler_Support.c"
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --include_path="C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --include_path="C:/Builds/Test/Version" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include/sf_runtime" --include_path="C:/Builds/Test/Version/bill_ert_rtw" --include_path="C:/Program Files/MATLAB/R2017b/extern/include" --include_path="C:/Program Files/MATLAB/R2017b/simulink/include" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/src/ext_mode/common" --include_path="C:/Program Files/MATLAB/R2017b/rtw/c/ert" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/inc" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/shared/can/src/scanutil" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/include" --include_path="C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common" --include_path="C:/Program Files/MATLAB/R2017b/toolbox/rtw/targets/common/can/blocks/tlc_c" --include_path="C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/shared/externalmode_daemon/include" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 --preproc_with_compile --preproc_dependency="profiler_Support.d_raw" "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/profiler_Support.c"
Finished building: "C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/profiler_Support.c"
Building target: "bill.out"
Invoking: C2000 Linker
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/bin/cl2000" --define=MODEL=bill --define=NUMST=1 --define=NCSTATES=0 --define=HAVESTDIO --define=TERMFCN=1 --define=ONESTEPFCN=1 --define=MAT_FILE=0 --define=MULTI_INSTANCE_CODE=0 --define=INTEGER_CODE=0 --define=MT=0 --define=CLASSIC_INTERFACE=0 --define=ALLOCATIONFCN=0 --define=TID01EQ=0 --define=DAEMON_MODE=1 --define=MW_PIL_SCIFIFOLEN=16 --define=F2837X_REG_FORMAT --define=MW_F2837XD --define=STACK_SIZE=512 --define=__MW_TARGET_USE_HARDWARE_RESOURCES_H__ --define=RT -s -v28 -ml --large_memory_model --silicon_version=28 --define=LARGE_MODEL -v28 --float_support=fpu32 -ml -DCPU1 -z --warn_sections -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/lib" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2017b/3P778C~1.INS/TIC200~1.INS/ti-cgt-c2000_16.9.2.LTS/include" --reread_libs --define=CPU1 --define=BOOT_FROM_FLASH=1 --define=BOOT_USING_BL=0 --rom_model -z --stack_size=512 --warn_sections --heap_size=1024 --reread_libs --rom_model -mbill.map -o "bill.out" "./F2837xD_Adc.obj" "./F2837xD_CodeStartBranch.obj" "./F2837xD_CpuTimers.obj" "./F2837xD_DefaultISR.obj" "./F2837xD_Dma.obj" "./F2837xD_GlobalVariableDefs.obj" "./F2837xD_Gpio.obj" "./F2837xD_Ipc_Driver_Lite.obj" "./F2837xD_PieCtrl.obj" "./F2837xD_PieVect.obj" "./F2837xD_SysCtrl.obj" "./F2837xD_usDelay.obj" "./MW_c28xx_board.obj" "./MW_c28xx_csl.obj" "./bill.obj" "./bill_data.obj" "./c2837xDBoard_Realtime_Support.obj" "./c2837xDSchedulerTimer0.obj" "./ert_main.obj" "./pgcu_global_constants.obj" "./profiler_Support.obj" -l"C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/rtlib/IQmath_fpu32.lib" -l"C:/ProgramData/MATLAB/SupportPackages/R2017b/toolbox/target/supportpackages/tic2000/src/c2837xDPeripherals.cmd" -l"C:/Builds/Test/Version/c28377D.cmd" -lrts2800_fpu32.lib
<Linking>
(-ppc) is used.
>> Compilation failure
gmake: Target 'all' not remade because of errors.
