I have code composer v7.4, and v8.0, and v9.01 and my code all run properly in v7.4. However, in v9, the same code will not update info memory. Ram memory works fine. Is there any difference between the two versions while writing to info A,B,C,D memory? It will read the memory correctly, but will not write to it. I tried various mclk and smclk settings, dco settings and to no avail.
Code composer v7 used to be able to break at breakpoint settings. Starting from the latest updates, it will not break any more. V8 gives me some weired break points.
