Part Number: TMS570LC4357
Other Parts Discussed in Thread: HALCOGEN
I'm developing a target file to support code generation workflow with MATLAB Embedded Coder as it's described in https://www.mathworks.com/help/releases/R2017a/supportpkg/armcortexr/develop-a-target.html. I created *.hcg, *.dil and *.ccxml files for my hardware in HalCoGen and CCSv9 respectively. Then, in MATLAB functions which run just after C-code generation for my Simulink model I call HALCOGEN to generate hardware-specific source code and armcl utility to compile and link it all into an executable *.out. Finally, I call the loadti utility to load the executable on hardware.
Unfortunately, during the load process, I get the following problem
=== Build (null) ===
### Starting build procedure for model: test
### Generating code into build folder: C:\Users\Witch\MATLAB\test_ert_rtw
### Generated code for 'test' is up to date because no structural, parameter or code replacement library changes were found.
### Evaluating PostCodeGenCommand specified in the model
### Using toolchain: TI ARM Code Generation Tools v5.2.x | gmake (64-bit Windows)
### 'C:\Users\Witch\MATLAB\test_ert_rtw\test.mk' is up to date
### Building 'test': "C:\PROGRA~1\MATLAB\R2017a\bin\win64\gmake" -f test.mk all
C:\Users\Witch\MATLAB\test_ert_rtw>cd .
C:\Users\Witch\MATLAB\test_ert_rtw>if "" == "" ("C:\PROGRA~1\MATLAB\R2017a\bin\win64\gmake" -f test.mk all ) else ("C:\PROGRA~1\MATLAB\R2017a\bin\win64\gmake" -f test.mk )
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_can.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_can.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_can.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_epc.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_epc.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_epc.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_errata.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_errata.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_errata.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_errata_SSWF021_45.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_errata_SSWF021_45.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_errata_SSWF021_45.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_esm.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_esm.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_esm.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_gio.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_gio.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_gio.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_nmpu.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_nmpu.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_nmpu.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_notification.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_notification.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_notification.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_pinmux.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_pinmux.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_pinmux.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_sci.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_sci.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sci.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_sys_dma.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_sys_dma.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_dma.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_sys_pcr.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_sys_pcr.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_pcr.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_sys_phantom.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_sys_phantom.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_phantom.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_sys_pmm.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_sys_pmm.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_pmm.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_sys_startup.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_sys_startup.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_startup.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_sys_vim.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_sys_vim.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_vim.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --compile_only -i"C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/include" --preproc_with_compile --preproc_dependency="HL_system.pp" --obj_directory="./" -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DRT -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=test -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -IC:/Users/Witch/MATLAB -IC:/PROGRA~1/MATLAB/R2017a/simulink/include/sf_runtime -IC:/Users/Witch/MATLAB/test_ert_rtw -IC:/PROGRA~1/MATLAB/R2017a/extern/include -IC:/PROGRA~1/MATLAB/R2017a/simulink/include -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2017a/rtw/c/ert -IC:/Users/Witch/MATLAB/test_ert_rtw/include --output_file=HL_system.obj C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_system.c
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl -s -ml -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_core.asm
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl -s -ml -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_intvecs.asm
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl -s -ml -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_mpu.asm
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl -s -ml -mv7R5 --code_state=32 --float_support=VFPv3D16 --abi=eabi --enum_type=packed --diag_wrap=off --display_error_number --diag_warning=225 C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_pmu.asm
"### Creating standalone executable "../test.out" ..."
C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/bin/armcl --run_linker --rom_model --search_path=C:/ti/ccs901/ccs/tools/compiler/TI-CGT~3.LTS/lib -mv7R5 -m"test.map" --warn_sections --reread_libs --diag_wrap=off --display_error_number --diag_warning=225 --xml_link_info="test_linkInfo.xml" --rom_model --heap_size=0x800 --stack_size=0x800 --output_file=../test.out test.obj test_data.obj HL_can.obj HL_epc.obj HL_errata.obj HL_errata_SSWF021_45.obj HL_esm.obj HL_gio.obj HL_nmpu.obj HL_notification.obj HL_pinmux.obj HL_sci.obj HL_sys_dma.obj HL_sys_pcr.obj HL_sys_phantom.obj HL_sys_pmm.obj HL_sys_startup.obj HL_sys_vim.obj HL_system.obj HL_sys_core.obj HL_sys_intvecs.obj HL_sys_mpu.obj HL_sys_pmu.obj ert_main.obj C:/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/lib/rtsv7R4_T_be_v3D16_eabi.lib C:/Users/Witch/MATLAB/test_ert_rtw/source/HL_sys_link.cmd
<Linking>
"### Created: ../test.out"
"### Successfully generated all binary outputs."
C:\Users\Witch\MATLAB\test_ert_rtw>exit /B 0
Erasing necessary sections of flash before loading.
Launcher command string: "C:\ProgramData\MATLAB\SupportPackages\R2017a\toolbox\target\shared\ti_arm_toolchain\loader\loadti"
Launcher command arguments: C:\ti\ccs901\ccs\ccs_base\DebugServer "C:\ProgramData\MATLAB\SupportPackages\R2017a\toolbox\target\shared\ti_arm_toolchain\loader" -r -a -v -c "C:\Users\Witch\MATLAB\titms570lc43target\src\TMS570LC43xx.ccxml" -x "test_loadti_log.xml" "C:\Users\Witch\MATLAB\test.out"
***** DSS Generic Loader *****
START: 22:42:58 GMT+0300 (MSK)
Configuring Debug Server for specified target...
getServer: ENTRY sServerName: DebugServer.1
getServer: Getting definition for: DebugServer.1
getServer: Constructing server
getServer: RETURN com.ti.debug.engine.scripting.DebugServer@136432db
setConfig: ENTRY sConfigurationFile: C:\Users\Witch\MATLAB\titms570lc43target\src\TMS570LC43xx.ccxml
setConfig: RETURN
Done
debuggerOpen: ENTRY sBoardName: * sCPUName: *
start: ENTRY
start: Firing: onServerStarting()
start: Connecting to XPCOM DebugServer
start: Initializing DebugServer using specified configuration: "C:\Users\Witch\MATLAB\titms570lc43target\src\TMS570LC43xx.ccxml"
waitUntil: ENTRY com.ti.ccstudio.scripting.environment.ScriptingEnvironment@7a79be86 timeout: infinite
<init>: CPU Name: CortexR5
<init>: PartNum: TMS570LC43xx
<init>: Family: 470
<init>: SubFamily/MajorISA: d
<init>: Revision/MinorISA: 0
<init>: Platform: EMULATOR
<init>: Processor ID: 1971336192
<init>: DBName: ArmAdvancedFeatures
<init>: CPU Name: IcePick
<init>: Family: 240
<init>: SubFamily/MajorISA: 2
<init>: Platform: NONE
<init>: Processor ID: 1006635013
<init>: CPU Name: Dap
<init>: Family: 224
<init>: SubFamily/MajorISA: 1
<init>: Processor ID: 939525125
waitUntil: RETURN com.ti.ccstudio.scripting.environment.ScriptingEnvironment@7a79be86
start: Firing: onServerStarted()
start: Searching for devices
listDevices: ENTRY
listDevices: Found debuggable device: Texas Instruments XDS110 USB Debug Probe/CortexR5
listDevices: Found non-debuggable device: Texas Instruments XDS110 USB Debug Probe/IcePick
listDevices: Found non-debuggable device: Texas Instruments XDS110 USB Debug Probe/Dap
listDevices: RETURN
start: RETURN
debuggerOpen: RETURN Texas Instruments XDS110 USB Debug Probe/CortexR5
setString: ENTRY ID: FileIODefaultDirectory Value: undefined
setString: RETURN
TARGET: Texas Instruments XDS110 USB Debug Probe
Connecting to target...
connect: ENTRY
isConnected: ENTRY
isConnected: Target is not connected
isConnected: RETURN false
connect: Requesting target connect
waitUntil: ENTRY timeout: infinite
CortexR5: GEL Output: Memory Map Setup for Flash @ Address 0x0
log: Target is now connected
waitUntil: RETURN
isConnected: ENTRY
isConnected: Target is connected
isConnected: RETURN true
connect: RETURN
Resetting target...
reset: ENTRY
reset: Requesting target reset
waitUntil: RETURN
reset: Target reset
getBoolean: ENTRY ID: AutoRunToLabelOnReset
getBoolean: RETURN false
reset: RETURN
testEnv.outFiles: C:\Users\Witch\MATLAB\test.out
Loading C:\Users\Witch\MATLAB\test.out
setString: ENTRY ID: FlashEraseSelection Value: Necessary Sectors Only (for Program Load)
setString: RETURN
loadProgram: ENTRY sFileName: C:\Users\Witch\MATLAB\test.out
load: Requesting program load
CortexR5: GEL Output: Memory Map Setup for Flash @ Address 0x0 due to System Reset
waitUntil: RETURN
load: Program load successful
getBoolean: ENTRY ID: AutoRunToLabelOnRestart
getBoolean: RETURN true
waitForHaltIfPropertySet: Waiting for halt
So it's clear that the program itself is successfully loaded on target however it cannot reach the entry-point function – main.
Please help me to resolve this issue.
