Part Number: LAUNCHXL-CC1350
Other Parts Discussed in Thread: CC1350,
@file csf.c
@brief Collector Specific Functions
Group: WCS LPC
Target Device: cc13x0
Copyright (c) 2016-2019, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Includes
#include <xdc/std.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/hal/Hwi.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/drivers/Power.h>
#include <ti/drivers/PIN.h>
#include <string.h>
#include <stdlib.h>
#include <inc/hw_ints.h>
#include <aon_event.h>
#include <ioc.h>
#include "Board.h"
#include "util_timer.h"
#include "mac_util.h"
#include "board_key.h"
#include "board_lcd.h"
#include "board_led.h"
#ifdef FEATURE_SECURE_COMMISSIONING
#include "sm_ti154.h"
#endif
#if defined(DeviceFamily_CC13X0) || defined(DeviceFamily_CC13X2)
#include "board_gpio.h"
#endif
#include "macconfig.h"
#ifdef ONE_PAGE_NV
#include "nvocop.h"
#else
#include "nvoctp.h"
#endif
#include "api_mac.h"
#include "collector.h"
#include "cllc.h"
#include "csf.h"
#include "config.h"
#if defined(MT_CSF)
#include "mt_csf.h"
#endif
#ifdef FEATURE_OAD
#include <Board.h>
#include <ti/drivers/UART.h>
#include <ti/drivers/uart/UARTCC26XX.h>
#include "uart_printf.h"
#include "oad_switch.h"
#endif
#ifdef OSAL_PORT2TIRTOS
#include "osal_port.h"
#else
#include "icall.h"
#endif
Constants and definitions
/* Initial timeout value for the tracking clock */
#define TRACKING_INIT_TIMEOUT_VALUE 100
/* NV Item ID - the device's network information */
#define CSF_NV_NETWORK_INFO_ID 0x0001
/* NV Item ID - the number of black list entries */
#define CSF_NV_BLACKLIST_ENTRIES_ID 0x0002
/* NV Item ID - the black list, use sub ID for each record in the list */
#define CSF_NV_BLACKLIST_ID 0x0003
/* NV Item ID - the number of device list entries */
#define CSF_NV_DEVICELIST_ENTRIES_ID 0x0004
/* NV Item ID - the device list, use sub ID for each record in the list */
#define CSF_NV_DEVICELIST_ID 0x0005
/* NV Item ID - this devices frame counter */
#define CSF_NV_FRAMECOUNTER_ID 0x0006
/* NV Item ID - reset reason */
#define CSF_NV_RESET_REASON_ID 0x0007
/* Maximum number of black list entries */
#define CSF_MAX_BLACKLIST_ENTRIES 10
/* Maximum number of device list entries */
#define CSF_MAX_DEVICELIST_ENTRIES CONFIG_MAX_DEVICES
Maximum sub ID for a blacklist item, this is failsafe. This is
not the maximum number of items in the list
#define CSF_MAX_BLACKLIST_IDS (2*CONFIG_MAX_DEVICES)
Maximum sub ID for a device list item, this is failsafe. This is
#define CSF_MAX_DEVICELIST_IDS (2*CONFIG_MAX_DEVICES)
/* timeout value for trickle timer initialization */
#define TRICKLE_TIMEOUT_VALUE 20
/* timeout value for join timer */
#define JOIN_TIMEOUT_VALUE 20
/* timeout value for config request delay */
#define CONFIG_TIMEOUT_VALUE 1000
The increment value needed to save a frame counter. Example, setting this
constant to 100, means that the frame counter will be saved when the new
frame counter is 100 more than the last saved frame counter. Also, when
the get frame counter function reads the value from NV it will add this value
to the read value.
#define FRAME_COUNTER_SAVE_WINDOW 25
/* Value returned from findDeviceListIndex() when not found */
#define DEVICE_INDEX_NOT_FOUND -1
/*! NV driver item ID for reset reason */
#define NVID_RESET {NVINTF_SYSID_APP, CSF_NV_RESET_REASON_ID, 0}
External variables
#ifdef NV_RESTORE
/*! MAC Configuration Parameters */
extern mac_Config_t Main_user1Cfg;
#endif
/* Security manager latest state */
extern SM_lastState_t SM_Last_State;
/* Need to re-do commissioning*/
extern bool fCommissionRequired;
#endif
Local variables
/* The application's semaphore */
static Semaphore_Handle collectorSem;
#else
static ICall_Semaphore collectorSem;
#endif
/* Clock/timer resources */
static Clock_Struct trackingClkStruct;
static Clock_Handle trackingClkHandle;
static Clock_Struct broadcastClkStruct;
static Clock_Handle broadcastClkHandle;
/* Clock/timer resources for CLLC */
/* trickle timer */
STATIC Clock_Struct tricklePAClkStruct;
STATIC Clock_Handle tricklePAClkHandle;
STATIC Clock_Struct tricklePCClkStruct;
STATIC Clock_Handle tricklePCClkHandle;
/* timer for join permit */
STATIC Clock_Struct joinClkStruct;
STATIC Clock_Handle joinClkHandle;
/* timer for config request delay */
STATIC Clock_Struct configClkStruct;
STATIC Clock_Handle configClkHandle;
/* timer for LED blink timeout*/
STATIC Clock_Struct identifyClkStruct;
STATIC Clock_Handle identifyClkHandle;
/* NV Function Pointers */
static NVINTF_nvFuncts_t *pNV = NULL;
static bool started = false;
/* The last saved coordinator frame counter */
static uint32_t lastSavedCoordinatorFrameCounter = 0;
#if defined(MT_CSF)
static const NVINTF_itemID_t nvResetId = NVID_RESET;
#endif
Global variables
/* Key press parameters */
uint8_t Csf_keys;
/* pending Csf_events */
uint16_t Csf_events = 0;
/* Saved CLLC state */
Cllc_states_t savedCllcState = Cllc_states_initWaiting;
/* Permit join setting */
bool permitJoining = false;
Local function prototypes
static void processTackingTimeoutCallback(UArg a0);
static void processBroadcastTimeoutCallback(UArg a0);
static void processKeyChangeCallback(uint8_t keysPressed);
static void processPATrickleTimeoutCallback(UArg a0);
static void processPCTrickleTimeoutCallback(UArg a0);
static void processJoinTimeoutCallback(UArg a0);
static void processConfigTimeoutCallback(UArg a0);
static void processidentifyTimeoutCallback(UArg a0);
static bool addDeviceListItem(Llc_deviceListItem_t *pItem, bool *pNewDevice);
static void updateDeviceListItem(Llc_deviceListItem_t *pItem);
static int findDeviceListIndex(ApiMac_sAddrExt_t *pAddr);
static int findUnusedDeviceListIndex(void);
static void saveNumDeviceListEntries(uint16_t numEntries);
static int findBlackListIndex(ApiMac_sAddr_t *pAddr);
static int findUnusedBlackListIndex(void);
static uint16_t getNumBlackListEntries(void);
static void saveNumBlackListEntries(uint16_t numEntries);
void removeBlackListItem(ApiMac_sAddr_t *pAddr);
#if defined(TEST_REMOVE_DEVICE)
static void removeTheFirstDevice(void);
#else
static uint16_t getTheFirstDevice(void);
#endif
Public Functions
The application calls this function during initialization
Public function defined in csf.h
void Csf_init(void *sem)
#ifdef NV_RESTORE
/* Save off the NV Function Pointers */
pNV = &Main_user1Cfg.nvFps;
#endif
/* Save off the semaphore */
collectorSem = sem;
/* Initialize PA/LNA if enabled */
ApiMac_mlmeSetReqUint8(ApiMac_attribute_rangeExtender,
(uint8_t)CONFIG_RANGE_EXT_MODE);
/* Initialize keys */
if(Board_Key_initialize(processKeyChangeCallback) == KEY_RIGHT)
/* Right key is pressed on power up, clear all NV */
Csf_clearAllNVItems();
/* Initialize the LCD */
Board_LCD_open();
LCD_WRITE_STRING("TI Collector", 1);
#if !defined(AUTO_START)
LCD_WRITE_STRING("Waiting...", 2);
#endif /* AUTO_START */
Board_Led_initialize();
Board_Gpio_initialize();
#endif
#if defined(MT_CSF)
uint8_t resetReseason = 0;
if(pNV != NULL)
if(pNV->readItem != NULL)
/* Attempt to retrieve reason for the reset */
(void)pNV->readItem(nvResetId, 0, 1, &resetReseason);
if(pNV->deleteItem != NULL)
/* Only use this reason once */
(void)pNV->deleteItem(nvResetId);
/* Start up the MT message handler */
MTCSF_init(resetReseason);
/* Did we reset because of assert? */
if(resetReseason > 0)
LCD_WRITE_STRING("Restarting...", 2);
/* Tell the collector to restart */
Csf_events |= CSF_KEY_EVENT;
Csf_keys |= KEY_LEFT;
#endif
The application must call this function periodically to
process any Csf_events that this module needs to process.
void Csf_processEvents(void)
/* Did a key press occur? */
if(Csf_events & CSF_KEY_EVENT)
/* No Key is accepted during CM Process*/
if(SM_Last_State != SM_CM_InProgress)
#endif
/* LaunchPad only supports KEY_LEFT and KEY_RIGHT */
if(Csf_keys & KEY_LEFT)
/* Process the Left Key */
if(started == false)
LCD_WRITE_STRING("Starting...", 2);
/* Tell the collector to start */
Util_setEvent(&Collector_events, COLLECTOR_START_EVT);
else
Remove the first device found in the device list.
Nobody would do something like this, it's just
and example on the use of the device list, remove
function and the black list.
removeTheFirstDevice();
#else
Send a Toggle LED request to the first device
in the device list
ApiMac_sAddr_t firstDev;
firstDev.addr.shortAddr = getTheFirstDevice();
if(firstDev.addr.shortAddr != CSF_INVALID_SHORT_ADDR)
firstDev.addrMode = ApiMac_addrType_short;
Collector_sendToggleLedRequest(&firstDev);
#endif
if(Csf_keys & KEY_RIGHT)
uint32_t duration;
if(fCommissionRequired == TRUE)
LCD_WRITE_STRING("PermitJoin blocked", 3);
else
#endif
/* Toggle the permit joining */
if (permitJoining == true)
duration = 0;
LCD_WRITE_STRING("PermitJoin-OFF", 3);
else
permitJoining = true;
duration = 0xFFFFFFFF;
LCD_WRITE_STRING("PermitJoin-ON ", 3);
/* Set permit joining */
Cllc_setJoinPermit(duration);
#if defined(FEATURE_OAD)
if(Csf_keys & KEY_LEFT && Csf_keys & KEY_RIGHT)
if(hUart != NULL)
UART_close(hUart);
OAD_markSwitch();
#endif /* FEATURE_OAD */
/* Clear the key press indication */
Csf_keys = 0;
/* Clear the event */
Util_clearEvent(&Csf_events, CSF_KEY_EVENT);
#if defined(MT_CSF)
MTCSF_displayStatistics();
#endif
The application calls this function to retrieve the stored
network information.
bool Csf_getNetworkInformation(Llc_netInfo_t *pInfo)
if((pNV != NULL) && (pNV->readItem != NULL) && (pInfo != NULL))
NVINTF_itemID_t id;
/* Setup NV ID */
id.systemID = NVINTF_SYSID_APP;
id.itemID = CSF_NV_NETWORK_INFO_ID;
id.subID = 0;
/* Read Network Information from NV */
if(pNV->readItem(id, 0, sizeof(Llc_netInfo_t), pInfo) == NVINTF_SUCCESS)
return(true);
return(false);
The application calls this function to indicate that it has
started or restored the device in a network
void Csf_networkUpdate(bool restored, Llc_netInfo_t *pNetworkInfo)
/* check for valid structure ponter, ignore if not */
if(pNetworkInfo != NULL)
if((pNV != NULL) && (pNV->writeItem != NULL))
NVINTF_itemID_t id;
/* Setup NV ID */
id.subID = 0;
/* Write the NV item */
pNV->writeItem(id, sizeof(Llc_netInfo_t), pNetworkInfo);
started = true;
if(restored == false)
LCD_WRITE_STRING("Started", 2);
else
LCD_WRITE_STRING("Restarted", 2);
LCD_WRITE_STRING("Key Recovery Mode", 2);
#endif
if(pNetworkInfo->fh == false)
LCD_WRITE_STRING_VALUE("Channel: ", pNetworkInfo->channel, 10, 3);
else
LCD_WRITE_STRING("Freq. Hopping", 3);
Board_Led_control(board_led_type_LED1, board_led_state_ON);
#if defined(MT_CSF)
MTCSF_networkUpdateIndCB();
#endif
The application calls this function to indicate that a device
has joined the network.
ApiMac_assocStatus_t Csf_deviceUpdate(ApiMac_deviceDescriptor_t *pDevInfo,
ApiMac_capabilityInfo_t *pCapInfo)
ApiMac_assocStatus_t status = ApiMac_assocStatus_success;
ApiMac_sAddr_t shortAddr;
ApiMac_sAddr_t extAddr;
/* flag which will be updated based on if the device joining is
a new device or already existing one */
bool newDevice;
shortAddr.addrMode = ApiMac_addrType_short;
shortAddr.addr.shortAddr = pDevInfo->shortAddress;
extAddr.addrMode = ApiMac_addrType_extended;
memcpy(&extAddr.addr.extAddr, &pDevInfo->extAddress, APIMAC_SADDR_EXT_LEN);
/* Is the device in the black list? */
if((findBlackListIndex(&shortAddr) >= 0)
|| (findBlackListIndex(&extAddr) >= 0))
/* Denied */
status = ApiMac_assocStatus_panAccessDenied;
LCD_WRITE_STRING_VALUE("Denied: 0x", pDevInfo->shortAddress, 16, 4);
else
/* Save the device information */
Llc_deviceListItem_t dev;
memcpy(&dev.devInfo, pDevInfo, sizeof(ApiMac_deviceDescriptor_t));
memcpy(&dev.capInfo, pCapInfo, sizeof(ApiMac_capabilityInfo_t));
dev.rxFrameCounter = 0;
if(addDeviceListItem(&dev, &newDevice) == false)
#ifdef NV_RESTORE
status = ApiMac_assocStatus_panAtCapacity;
LCD_WRITE_STRING_VALUE("Failed: 0x", pDevInfo->shortAddress,
16, 4);
#else
LCD_WRITE_STRING_VALUE("Joined: 0x", pDevInfo->shortAddress, 16, 4);
#endif
else if (true == newDevice) {
else {
LCD_WRITE_STRING_VALUE("Re-Joined: 0x", pDevInfo->shortAddress, 16, 4);
#if defined(MT_CSF)
MTCSF_deviceUpdateIndCB(pDevInfo, pCapInfo);
#endif
/* Return the status of the joining device */
return (status);
is no longer active in the network.
void Csf_deviceNotActiveUpdate(ApiMac_deviceDescriptor_t *pDevInfo,
bool timeout)
LCD_WRITE_STRING_VALUE("!Responding: 0x", pDevInfo->shortAddress,
16,
5);
#if defined(MT_CSF)
MTCSF_deviceNotActiveIndCB(pDevInfo, timeout);
#endif
has responded to a Config Request.
void Csf_deviceConfigUpdate(ApiMac_sAddr_t *pSrcAddr, int8_t rssi,
Smsgs_configRspMsg_t *pMsg)
LCD_WRITE_STRING_VALUE("ConfigRsp: 0x", pSrcAddr->addr.shortAddr, 16, 5);
#if defined(MT_CSF)
MTCSF_configResponseIndCB(pSrcAddr, rssi, pMsg);
#endif
has reported sensor data.
void Csf_deviceSensorDataUpdate(ApiMac_sAddr_t *pSrcAddr, int8_t rssi,
Smsgs_sensorMsg_t *pMsg)
Board_Led_toggle(board_led_type_LED2);
//LCD_WRITE_STRING_VALUE("Sensor 0x", pSrcAddr->addr.shortAddr, 16, 6);
LCD_WRITE_STRING_VALUE("Humidity=", pMsg->humiditySensor.humidity , 10, 6);
LCD_WRITE_STRING_VALUE("Temperature=", pMsg->humiditySensor.temp, 10, 6);
#if defined(MT_CSF)
MTCSF_sensorUpdateIndCB(pSrcAddr, rssi, pMsg);
#endif
The application calls this function to toggle an LED.
Public function defined in ssf.h
void Csf_identifyLED(uint16_t identifyTime)
Board_Led_control(board_led_type_LED2, board_led_state_BLINKING);
/* Setup timer */
Timer_setTimeout(identifyClkHandle, identifyTime);
Timer_start(&identifyClkStruct);
set a Toggle LED Response message.
void Csf_toggleResponseReceived(ApiMac_sAddr_t *pSrcAddr, bool ledState)
#if defined(MT_CSF)
uint16_t shortAddr = 0xFFFF;
if(pSrcAddr)
if(pSrcAddr->addrMode == ApiMac_addrType_short)
shortAddr = pSrcAddr->addr.shortAddr;
else
/* Convert extended to short addr */
shortAddr = Csf_getDeviceShort(&pSrcAddr->addr.extAddr);
MTCSF_deviceToggleIndCB(shortAddr, ledState);
#endif
The application calls this function to indicate that the
Coordinator's state has changed.
void Csf_stateChangeUpdate(Cllc_states_t state)
if(started == true)
if(state == Cllc_states_joiningAllowed)
/* Flash LED1 while allowing joining */
Board_Led_control(board_led_type_LED1, board_led_state_BLINKING);
else if(state == Cllc_states_joiningNotAllowed)
/* Don't flash when not allowing joining */
/* Save the state to be used later */
savedCllcState = state;
#if defined(MT_CSF)
MTCSF_stateChangeIndCB(state);
#endif
Initialize the tracking clock.
void Csf_initializeTrackingClock(void)
/* Initialize the timers needed for this application */
trackingClkHandle = Timer_construct(&trackingClkStruct,
processTackingTimeoutCallback,
TRACKING_INIT_TIMEOUT_VALUE,
0,
false,
0);
Initialize the broadcast cmd clock.
void Csf_initializeBroadcastClock(void)
broadcastClkHandle = Timer_construct(&broadcastClkStruct,
processBroadcastTimeoutCallback,
0,
false,
0);
Initialize the trickle clock.
void Csf_initializeTrickleClock(void)
/* Initialize trickle timer */
tricklePAClkHandle = Timer_construct(&tricklePAClkStruct,
processPATrickleTimeoutCallback,
TRICKLE_TIMEOUT_VALUE,
0,
false,
0);
tricklePCClkHandle = Timer_construct(&tricklePCClkStruct,
processPCTrickleTimeoutCallback,
0,
false,
0);
Initialize the clock for join permit attribute.
void Csf_initializeJoinPermitClock(void)
/* Initialize join permit timer */
joinClkHandle = Timer_construct(&joinClkStruct,
processJoinTimeoutCallback,
JOIN_TIMEOUT_VALUE,
0,
false,
0);
Initialize the clock for config request delay
void Csf_initializeConfigClock(void)
configClkHandle = Timer_construct(&configClkStruct,
processConfigTimeoutCallback,
CONFIG_TIMEOUT_VALUE,
0,
false,
0);
Initialize the clock for identify timeout
void Csf_initializeIdentifyClock(void)
identifyClkHandle = Timer_construct(&identifyClkStruct,
processidentifyTimeoutCallback,
10,
0,
false,
0);
Set the tracking clock.
void Csf_setTrackingClock(uint32_t trackingTime)
/* Stop the Tracking timer */
if(Timer_isActive(&trackingClkStruct) == true)
Timer_stop(&trackingClkStruct);
if(trackingTime)
/* Setup timer */
Timer_setTimeout(trackingClkHandle, trackingTime);
Timer_start(&trackingClkStruct);
Set the broadcast clock.
void Csf_setBroadcastClock(uint32_t broadcastTime)
if(Timer_isActive(&broadcastClkStruct) == true)
Timer_stop(&broadcastClkStruct);
if(broadcastTime)
/* Setup timer */
Timer_setTimeout(broadcastClkHandle, broadcastTime);
Timer_start(&broadcastClkStruct);
Set the trickle clock.
void Csf_setTrickleClock(uint32_t trickleTime, uint8_t frameType)
uint16_t randomNum = 0;
uint16_t randomTime = 0;
if(trickleTime > 0)
randomNum = ((ApiMac_randomByte() << 8) + ApiMac_randomByte());
randomTime = (trickleTime >> 1) +
(randomNum % (trickleTime >> 1));
if(frameType == ApiMac_wisunAsyncFrame_advertisement)
/* Stop the PA trickle timer */
if(Timer_isActive(&tricklePAClkStruct) == true)
Timer_stop(&tricklePAClkStruct);
if(trickleTime > 0)
/* Setup timer */
Timer_setTimeout(tricklePAClkHandle, randomTime);
Timer_start(&tricklePAClkStruct);
else if(frameType == ApiMac_wisunAsyncFrame_config)
/* Stop the PC trickle timer */
if(Timer_isActive(&tricklePCClkStruct) == true)
Timer_stop(&tricklePCClkStruct);
if(trickleTime > 0)
/* Setup timer */
Timer_setTimeout(tricklePCClkHandle, randomTime);
Timer_start(&tricklePCClkStruct);
Set the clock join permit attribute.
void Csf_setJoinPermitClock(uint32_t joinDuration)
/* Stop the join timer */
if(Timer_isActive(&joinClkStruct) == true)
Timer_stop(&joinClkStruct);
if(joinDuration != 0)
/* Setup timer */
Timer_setTimeout(joinClkHandle, joinDuration);
Timer_start(&joinClkStruct);
Set the clock config request delay.
void Csf_setConfigClock(uint32_t delay)
if(Timer_isActive(&configClkStruct) == true)
Timer_stop(&configClkStruct);
if(delay != 0)
/* Setup timer */
Timer_setTimeout(configClkHandle, delay);
Timer_start(&configClkStruct);
Read the number of device list items stored
uint16_t Csf_getNumDeviceListEntries(void)
uint16_t numEntries = 0;
if(pNV != NULL)
NVINTF_itemID_t id;
uint8_t stat;
/* Setup NV ID for the number of entries in the device list */
id.itemID = CSF_NV_DEVICELIST_ENTRIES_ID;
id.subID = 0;
/* Read the number of device list items from NV */
stat = pNV->readItem(id, 0, sizeof(uint16_t), &numEntries);
if(stat != NVINTF_SUCCESS)
numEntries = 0;
return (numEntries);
Find the short address from a given extended address
uint16_t Csf_getDeviceShort(ApiMac_sAddrExt_t *pExtAddr)
Llc_deviceListItem_t item;
ApiMac_sAddr_t devAddr;
uint16_t shortAddr = CSF_INVALID_SHORT_ADDR;
devAddr.addrMode = ApiMac_addrType_extended;
memcpy(&devAddr.addr.extAddr, pExtAddr, sizeof(ApiMac_sAddrExt_t));
if(Csf_getDevice(&devAddr,&item))
shortAddr = item.devInfo.shortAddress;
return(shortAddr);
Find entry in device list
bool Csf_getDevice(ApiMac_sAddr_t *pDevAddr, Llc_deviceListItem_t *pItem)
if((pNV != NULL) && (pItem != NULL))
uint16_t numEntries;
numEntries = Csf_getNumDeviceListEntries();
if(numEntries > 0)
NVINTF_itemID_t id;
uint8_t stat;
int subId = 0;
int readItems = 0;
/* Setup NV ID for the device list records */
id.itemID = CSF_NV_DEVICELIST_ID;
while((readItems < numEntries) && (subId
< CSF_MAX_DEVICELIST_IDS))
id.subID = (uint16_t)subId;
stat = pNV->readItem(id, 0, sizeof(Llc_deviceListItem_t),
&item);
if(stat == NVINTF_SUCCESS)
if(((pDevAddr->addrMode == ApiMac_addrType_short)
&& (pDevAddr->addr.shortAddr
== item.devInfo.shortAddress))
|| ((pDevAddr->addrMode == ApiMac_addrType_extended)
&& (memcmp(&pDevAddr->addr.extAddr,
&item.devInfo.extAddress,
(APIMAC_SADDR_EXT_LEN))
== 0)))
memcpy(pItem, &item, sizeof(Llc_deviceListItem_t));
return (true);
readItems++;
subId++;
return (false);
bool Csf_getDeviceItem(uint16_t devIndex, Llc_deviceListItem_t *pItem)
if(numEntries > 0)
NVINTF_itemID_t id;
uint8_t stat;
int subId = 0;
int readItems = 0;
&item);
if(readItems == devIndex)
return (true);
readItems++;
subId++;
return (false);
Csf implementation for memory allocation
void *Csf_malloc(uint16_t size)
return OsalPort_malloc(size);
#else
return(ICall_malloc(size));
#endif
Csf implementation for memory de-allocation
void Csf_free(void *ptr)
if(ptr != NULL)
OsalPort_free(ptr);
#else
ICall_free(ptr);
#endif
Update the Frame Counter
void Csf_updateFrameCounter(ApiMac_sAddr_t *pDevAddr, uint32_t frameCntr)
if(pDevAddr == NULL)
/* Update this device's frame counter */
if((frameCntr >=
(lastSavedCoordinatorFrameCounter + FRAME_COUNTER_SAVE_WINDOW)))
NVINTF_itemID_t id;
/* Setup NV ID */
id.itemID = CSF_NV_FRAMECOUNTER_ID;
id.subID = 0;
if(pNV->writeItem(id, sizeof(uint32_t), &frameCntr)
== NVINTF_SUCCESS)
lastSavedCoordinatorFrameCounter = frameCntr;
else
/* Child frame counter update */
Llc_deviceListItem_t devItem;
/* Is the device in our database? */
if(Csf_getDevice(pDevAddr, &devItem))
Don't save every update, only save if the new frame
counter falls outside the save window.
if((devItem.rxFrameCounter + FRAME_COUNTER_SAVE_WINDOW)
<= frameCntr)
/* Update the frame counter */
devItem.rxFrameCounter = frameCntr;
updateDeviceListItem(&devItem);
Get the Frame Counter
bool Csf_getFrameCounter(ApiMac_sAddr_t *pDevAddr, uint32_t *pFrameCntr)
/* Check for valid pointer */
if(pFrameCntr != NULL)
A pDevAddr that is null means to get the frame counter for this device
if((pNV != NULL) && (pNV->readItem != NULL))
NVINTF_itemID_t id;
/* Setup NV ID */
id.subID = 0;
if(pNV->readItem(id, 0, sizeof(uint32_t), pFrameCntr)
== NVINTF_SUCCESS)
/* Set to the next window */
*pFrameCntr += FRAME_COUNTER_SAVE_WINDOW;
return(true);
else
Wasn't found, so write 0, so the next time it will be
greater than 0
uint32_t fc = 0;
/* Setup NV ID */
id.subID = 0;
pNV->writeItem(id, sizeof(uint32_t), &fc);
*pFrameCntr = 0;
return (false);
Delete an entry from the device list
void Csf_removeDeviceListItem(ApiMac_sAddrExt_t *pAddr)
if((pNV != NULL) && (pNV->deleteItem != NULL))
int index;
/* Does the item exist? */
index = findDeviceListIndex(pAddr);
if(index != DEVICE_INDEX_NOT_FOUND)
uint8_t stat;
NVINTF_itemID_t id;
/* Setup NV ID for the device list record */
id.subID = (uint16_t)index;
stat = pNV->deleteItem(id);
/* Update the number of entries */
uint16_t numEntries = Csf_getNumDeviceListEntries();
if(numEntries > 0)
numEntries--;
saveNumDeviceListEntries(numEntries);
Assert Indication
void Csf_assertInd(uint8_t reason)
#if defined(MT_CSF)
/* Attempt to save reason to read after reset */
(void)pNV->writeItem(nvResetId, 1, &reason);
#endif
Clear all the NV Items
void Csf_clearAllNVItems(void)
#ifdef ONE_PAGE_NV
NVINTF_itemID_t id;
/* Clear all information */
id.systemID = 0xFF;
id.itemID = 0xFFFF;
id.subID = 0xFFFF;
#else
NVINTF_itemID_t id;
uint16_t entries;
/* Clear Network Information */
id.subID = 0;
/* Clear the black list entries number */
id.itemID = CSF_NV_BLACKLIST_ENTRIES_ID;
id.subID = 0;
Clear the black list entries. Brute force through
every possible subID, if it doesn't exist that's fine,
it will fail in deleteItem.
id.itemID = CSF_NV_BLACKLIST_ID;
for(entries = 0; entries < CSF_MAX_BLACKLIST_IDS; entries++)
id.subID = entries;
/* Clear the device list entries number */
id.subID = 0;
Clear the device list entries. Brute force through
for(entries = 0; entries < CSF_MAX_DEVICELIST_IDS; entries++)
id.subID = entries;
/* Clear the device tx frame counter */
id.subID = 0;
#endif
Add an entry into the black list
bool Csf_addBlackListItem(ApiMac_sAddr_t *pAddr)
bool retVal = false;
if((pNV != NULL) && (pAddr != NULL)
&& (pAddr->addrMode != ApiMac_addrType_none))
if(findBlackListIndex(pAddr))
retVal = true;
else
uint8_t stat;
NVINTF_itemID_t id;
uint16_t numEntries = getNumBlackListEntries();
/* Check the maximum size */
if(numEntries < CSF_MAX_BLACKLIST_ENTRIES)
/* Setup NV ID for the black list record */
id.subID = (uint16_t)findUnusedBlackListIndex();
/* write the black list record */
stat = pNV->writeItem(id, sizeof(ApiMac_sAddr_t), pAddr);
numEntries++;
saveNumBlackListEntries(numEntries);
retVal = true;
return (retVal);
Check if config timer is active
bool Csf_isConfigTimerActive(void)
return(Timer_isActive(&configClkStruct));
Check if tracking timer is active
bool Csf_isTrackingTimerActive(void)
return(Timer_isActive(&trackingClkStruct));
Local Functions
* @brief Tracking timeout handler function.
* @param a0 - ignored
(void)a0; /* Parameter is not used */
Util_setEvent(&Collector_events, COLLECTOR_TRACKING_TIMEOUT_EVT);
/* Wake up the application thread when it waits for clock event */
Semaphore_post(collectorSem);
Util_setEvent(&Collector_events, COLLECTOR_BROADCAST_TIMEOUT_EVT);
* @brief Join permit timeout handler function.
Util_setEvent(&Cllc_events, CLLC_JOIN_EVT);
* @brief Config delay timeout handler function.
Util_setEvent(&Collector_events, COLLECTOR_CONFIG_EVT);
* @brief Identify timeout handler function.
/* Stop LED blinking - we can write to GPIO in SWI */
Board_Led_control(board_led_type_LED2, board_led_state_OFF);
* @brief Trickle timeout handler function for PA .
Util_setEvent(&Cllc_events, CLLC_PA_EVT);
* @brief Trickle timeout handler function for PC.
Util_setEvent(&Cllc_events, CLLC_PC_EVT);
* @brief Key event handler function
* @param keysPressed - Csf_keys that are pressed
Csf_keys = keysPressed;
* @brief Add an entry into the device list
* @param pItem - pointer to the device list entry
* @param pNewDevice - pointer to a flag which will be updated
* based on if the sensor joining is already assoc with
* the collector or freshly joining the network
* @return true if added or already existed, false if problem
/* By default, set this flag to true;
will be updated - if device already found in the list*/
*pNewDevice = true;
if(findDeviceListIndex(&pItem->devInfo.extAddress)
retVal = true;
/* Not a new device; already exists */
*pNewDevice = false;
else
uint8_t stat;
NVINTF_itemID_t id;
if(numEntries < CSF_MAX_DEVICELIST_ENTRIES)
id.subID = (uint16_t)findUnusedDeviceListIndex();
/* write the device list record */
stat = pNV->writeItem(id, sizeof(Llc_deviceListItem_t), pItem);
numEntries++;
retVal = true;
return (retVal);
* @brief Update an entry in the device list
int idx;
idx = findDeviceListIndex(&pItem->devInfo.extAddress);
if(idx != DEVICE_INDEX_NOT_FOUND)
NVINTF_itemID_t id;
id.subID = (uint16_t)idx;
* @brief Find entry in device list
* @param pAddr - address to of device to find
* @return sub index into the device list, -1 (DEVICE_INDEX_NOT_FOUND)
* if not found
if((pNV != NULL) && (pAddr != NULL))
if(numEntries > 0)
NVINTF_itemID_t id;
uint8_t stat;
int subId = 0;
int readItems = 0;
&item);
/* Is the address the same */
if(memcmp(pAddr, &item.devInfo.extAddress,
== 0)
return (subId);
readItems++;
subId++;
return (DEVICE_INDEX_NOT_FOUND);
* @brief Find an unused device list index
* @return index that is not in use
int subId = 0;
if(pNV != NULL)
if(numEntries > 0)
NVINTF_itemID_t id;
int readItems = 0;
uint8_t stat;
&item);
if(stat == NVINTF_NOTFOUND)
/* Use this sub id */
break;
else if(stat == NVINTF_SUCCESS)
readItems++;
subId++;
return (subId);
* @brief Read the number of device list items stored
* @param numEntries - number of entries in the device list
if(pNV != NULL)
NVINTF_itemID_t id;
id.subID = 0;
pNV->writeItem(id, sizeof(uint16_t), &numEntries);
* @brief Find entry in black list
* @param pAddr - address to add into the black list
* @return sub index into the blacklist, -1 if not found
if(numEntries > 0)
NVINTF_itemID_t id;
uint8_t stat;
int subId = 0;
int readItems = 0;
/* Setup NV ID for the black list records */
while((readItems < numEntries) && (subId < CSF_MAX_BLACKLIST_IDS))
ApiMac_sAddr_t item;
stat = pNV->readItem(id, 0, sizeof(ApiMac_sAddr_t), &item);
if(pAddr->addrMode == item.addrMode)
if(((pAddr->addrMode == ApiMac_addrType_short)
&& (pAddr->addr.shortAddr == item.addr.shortAddr))
|| ((pAddr->addrMode == ApiMac_addrType_extended)
&& (memcmp(&pAddr->addr.extAddr,
&item.addr.extAddr,
== 0)))
return (subId);
readItems++;
subId++;
return (-1);
* @brief Find an unused blacklist index
int subId = 0;
if(pNV != NULL)
if(numEntries > 0)
NVINTF_itemID_t id;
int readItems = 0;
uint8_t stat;
break;
readItems++;
subId++;
return (subId);
* @brief Read the number of black list items stored
* @return number of entries in the black list
if(pNV != NULL)
NVINTF_itemID_t id;
uint8_t stat;
/* Setup NV ID for the number of entries in the black list */
id.subID = 0;
/* Read the number of black list items from NV */
numEntries = 0;
* @param numEntries - number of entries in the black list
if(pNV != NULL)
NVINTF_itemID_t id;
id.subID = 0;
* @brief Delete an address from the black list
* @param pAddr - address to remove from black list.
if(pNV != NULL)
int index;
index = findBlackListIndex(pAddr);
if(index > 0)
uint8_t stat;
NVINTF_itemID_t id;
if(numEntries > 0)
numEntries--;
* @brief This is an example function on how to remove a device
* from this network.
if(pNV != NULL)
if(numEntries > 0)
NVINTF_itemID_t id;
uint16_t subId = 0;
while(subId < CSF_MAX_DEVICELIST_IDS)
uint8_t stat;
&item);
/* Found the first device in the list */
ApiMac_sAddr_t addr;
/* Send a disassociate to the device */
Cllc_sendDisassociationRequest(item.devInfo.shortAddress,
item.capInfo.rxOnWhenIdle);
/* remove device from the NV list */
Cllc_removeDevice(&item.devInfo.extAddress);
/* Remove it from the Device list */
Csf_removeDeviceListItem(&item.devInfo.extAddress);
/* Add the device to the black list so it can't join again */
addr.addrMode = ApiMac_addrType_extended;
memcpy(&addr.addr.extAddr, &item.devInfo.extAddress,
(APIMAC_SADDR_EXT_LEN));
Csf_addBlackListItem(&addr);
break;
subId++;
#else
* @brief Retrieve the first device's short address
* @return short address or 0xFFFF if not found
uint16_t found = CSF_INVALID_SHORT_ADDR;
if(pNV != NULL)
if(numEntries > 0)
NVINTF_itemID_t id;
id.subID = 0;
while(id.subID < CSF_MAX_DEVICELIST_IDS)
uint8_t stat;
&item);
found = item.devInfo.shortAddress;
break;
id.subID++;
return(found);
#endif
* @brief Handles printing that the orphaned device joined back
* @return none
void Csf_IndicateOrphanReJoin(uint16_t shortAddr)
LCD_WRITE_STRING_VALUE("Orphaned Sensor Re-Joined: 0x", shortAddr, 16, 4);
now i am working with Ti 15.4 Stack Sensor and collector example with CC1350 launch pad. that default example is working fine, then i add some code for read temperature and humidity data through i2c (i was already check with i2c example that is working fine that's why i was merge that i2c and sensor example codes). now that sensor board is print restarted statement in uart, i can't find what mistakes i made in code, can you help me to find the mistakes, i have attached Serial monitor output image and sensor and collector codes for your reference.
@file sensor.c
@brief TIMAC 2.0 Sensor Example Application
Group: WCS LPC
are met:
Includes
#include <string.h>
#include <stdint.h>
#include "jdllc.h"
#include "ssf.h"
#include "smsgs.h"
#include "sensor.h"
#include "config.h"
#include <ti/drivers/I2C.h>
#include <ti/drivers/GPIO.h>
#define TMP116_DIE_TEMP 0xE3
#define Si7021_ADDR 0x40
#if defined(HUMIDITY_SENSOR)
I2C_Handle i2c;
I2C_Params i2cParams;
I2C_Transaction i2cTransaction;
float temperature;
double temper;
float humidity;
double humi;
uint8_t txBuffer[1];
uint8_t rxBuffer[2];
#endif
#ifdef FEATURE_NATIVE_OAD
#include "oad_client.h"
#endif /* FEATURE_NATIVE_OAD */
#else
#include "icall.h"
#endif
#endif
#if !defined(CONFIG_AUTO_START)
#if defined(AUTO_START)
#define CONFIG_AUTO_START 1
#else
#define CONFIG_AUTO_START 0
#endif
#endif
/* default MSDU Handle rollover */
#define MSDU_HANDLE_MAX 0x1F
/* App marker in MSDU handle */
#define APP_MARKER_MSDU_HANDLE 0x80
/* App Message Tracking Mask */
#define APP_MASK_MSDU_HANDLE 0x60
/* App Sensor Data marker for the MSDU handle */
#define APP_SENSOR_MSDU_HANDLE 0x40
/* App tracking response marker for the MSDU handle */
#define APP_TRACKRSP_MSDU_HANDLE 0x20
/* App config response marker for the MSDU handle */
#define APP_CONFIGRSP_MSDU_HANDLE 0x60
/* Reporting Interval Min and Max (in milliseconds) */
#define MIN_REPORTING_INTERVAL 1000
#define MAX_REPORTING_INTERVAL 360000
/* Polling Interval Min and Max (in milliseconds) */
#define MIN_POLLING_INTERVAL 1000 //100
#define MAX_POLLING_INTERVAL 10000
/* Blink Time for Identify LED Request (in milliseconds) */
#define IDENTIFY_LED_TIME 1000
/* Inter packet interval in certification test mode */
#if CERTIFICATION_TEST_MODE
#if ((CONFIG_PHY_ID >= APIMAC_MRFSK_STD_PHY_ID_BEGIN) && (CONFIG_PHY_ID <= APIMAC_MRFSK_GENERIC_PHY_ID_BEGIN))
/*! Regular Mode */
#define SENSOR_TEST_RAMP_DATA_SIZE 75
#define CERT_MODE_INTER_PKT_INTERVAL 50
#elif ((CONFIG_PHY_ID >= APIMAC_MRFSK_GENERIC_PHY_ID_BEGIN + 1) && (CONFIG_PHY_ID <= APIMAC_MRFSK_GENERIC_PHY_ID_END))
/*! LRM Mode */
#define SENSOR_TEST_RAMP_DATA_SIZE 20
#define CERT_MODE_INTER_PKT_INTERVAL 300
#else
#error "PHY ID is wrong."
#endif
#endif
Global variables
/* Task pending events */
uint16_t Sensor_events = 0;
/*! Sensor statistics */
Smsgs_msgStatsField_t Sensor_msgStats =
{ 0 };
extern bool initBroadcastMsg;
extern bool parentFound;
#ifdef POWER_MEAS
/*! Power Meas Stats fields */
Smsgs_powerMeastatsField_t Sensor_pwrMeasStats =
{ 0 };
#endif
Local variables
static void *sem;
/*! Rejoined flag */
static bool rejoining = false;
/*! Collector's address */
static ApiMac_sAddr_t collectorAddr = {0};
/* Join Time Ticks (used for average join time calculations) */
static uint_fast32_t joinTimeTicks = 0;
/* End to end delay statistics timestamp */
static uint32_t startSensorMsgTimeStamp = 0;
/*! Device's Outgoing MSDU Handle values */
STATIC uint8_t deviceTxMsduHandle = 0;
STATIC Smsgs_configReqMsg_t configSettings;
#if !defined(OAD_IMG_A)
Temp Sensor field - valid only if Smsgs_dataFields_tempSensor
is set in frameControl.
STATIC Smsgs_tempSensorField_t tempSensor =
{ 0 };
Light Sensor field - valid only if Smsgs_dataFields_lightSensor
STATIC Smsgs_lightSensorField_t lightSensor =
{ 0 };
Humidity Sensor field - valid only if Smsgs_dataFields_humiditySensor
STATIC Smsgs_humiditySensorField_t humiditySensor =
{ 0 };
#endif //OAD_IMG_A
STATIC Llc_netInfo_t parentInfo = {0};
STATIC uint16_t lastRcvdBroadcastMsgId = 0;
/* variable to store the current setting of auto Request Pib attribute
* before it gets modified by SM module, in beacon mode
static bool currAutoReq = 0;
#endif /* FEATURE_SECURE_COMMISSIONING */
#ifdef OAD_IMG_A
static bool Oad_hasSentResetRsp = false;
#endif /* OAD_IMG_A */
static void initializeClocks(void);
static void dataCnfCB(ApiMac_mcpsDataCnf_t *pDataCnf);
static void dataIndCB(ApiMac_mcpsDataInd_t *pDataInd);
static uint8_t getMsduHandle(Smsgs_cmdIds_t msgType);
static void processSensorMsgEvt(void);
static bool sendSensorMessage(ApiMac_sAddr_t *pDstAddr,
Smsgs_sensorMsg_t *pMsg);
static void readSensors(void);
#endif //OAD_IMG_A
#if SENSOR_TEST_RAMP_DATA_SIZE
static void processSensorRampMsgEvt(void);
#endif
static void processConfigRequest(ApiMac_mcpsDataInd_t *pDataInd);
static void processBroadcastCtrlMsg(ApiMac_mcpsDataInd_t *pDataInd);
static bool sendConfigRsp(ApiMac_sAddr_t *pDstAddr, Smsgs_configRspMsg_t *pMsg);
static uint16_t validateFrameControl(uint16_t frameControl);
static void jdllcJoinedCb(ApiMac_deviceDescriptor_t *pDevInfo,
Llc_netInfo_t *pStartedInfo);
static void jdllcDisassocIndCb(ApiMac_sAddrExt_t *extAddress,
ApiMac_disassocateReason_t reason);
static void jdllcDisassocCnfCb(ApiMac_sAddrExt_t *extAddress,
ApiMac_status_t status);
static void jdllcStateChangeCb(Jdllc_states_t state);
/* Security Manager callback functions */
static void smFailCMProcessCb(ApiMac_deviceDescriptor_t *devInfo,
bool rxOnIdle, bool keyRefreshment);
static void smSuccessCMProcessCb(ApiMac_deviceDescriptor_t *devInfo,
#endif
Callback tables
/*! API MAC Callback table */
STATIC ApiMac_callbacks_t Sensor_macCallbacks =
/*! Associate Indicated callback */
NULL,
/*! Associate Confirmation callback */
NULL,
/*! Disassociate Indication callback */
NULL,
/*! Disassociate Confirmation callback */
NULL,
/*! Beacon Notify Indication callback */
NULL,
/*! Orphan Indication callback */
NULL,
/*! Scan Confirmation callback */
NULL,
/*! Start Confirmation callback */
NULL,
/*! Sync Loss Indication callback */
NULL,
/*! Poll Confirm callback */
NULL,
/*! Comm Status Indication callback */
NULL,
/*! Poll Indication Callback */
NULL,
/*! Data Confirmation callback */
dataCnfCB,
/*! Data Indication callback */
dataIndCB,
/*! Purge Confirm callback */
NULL,
/*! WiSUN Async Indication callback */
NULL,
/*! WiSUN Async Confirmation callback */
NULL,
/*! Unprocessed message callback */
NULL
STATIC Jdllc_callbacks_t jdllcCallbacks =
/*! Network Joined Indication callback */
jdllcJoinedCb,
/* Disassociation Indication callback */
jdllcDisassocIndCb,
/* Disassociation Confirm callback */
jdllcDisassocCnfCb,
/*! State Changed indication callback */
jdllcStateChangeCb
STATIC SM_callbacks_t SMCallbacks =
/*! Security authentication failed callback */
smFailCMProcessCb,
/* Security authentication successful callback */
#endif
Public Functions
Initialize this application.
Public function defined in sensor.h
void Sensor_init(uint8_t macTaskId)
#else
void Sensor_init(void)
#endif
uint32_t frameCounter = 0;
/* Initialize the sensor's structures */
memset(&configSettings, 0, sizeof(Smsgs_configReqMsg_t));
#if defined(TEMP_SENSOR)
configSettings.frameControl |= Smsgs_dataFields_tempSensor;
#endif
#if defined(LIGHT_SENSOR)
configSettings.frameControl |= Smsgs_dataFields_lightSensor;
#endif
I2C_init();
GPIO_init();
/* Configure the LED and if applicable, the TMP116_EN pin */
/*GPIO_setConfig(Board_GPIO_LED0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
#ifdef Board_GPIO_TMP116_EN
GPIO_setConfig(Board_GPIO_TMP116_EN, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_HIGH);
// sleep(1);
#endif*/
configSettings.frameControl |= Smsgs_dataFields_humiditySensor;
#endif
configSettings.frameControl |= Smsgs_dataFields_msgStats;
configSettings.frameControl |= Smsgs_dataFields_configSettings;
if(!CERTIFICATION_TEST_MODE)
configSettings.reportingInterval = CONFIG_REPORTING_INTERVAL;
else
/* start back to back data transmission at the earliest */
configSettings.reportingInterval = 100;
configSettings.pollingInterval = CONFIG_POLLING_INTERVAL;
/* Initialize the MAC */
sem = ApiMac_init(macTaskId, CONFIG_FH_ENABLE);
#else
sem = ApiMac_init(CONFIG_FH_ENABLE);
#endif
/* Initialize the Joining Device Logical Link Controller */
Jdllc_init(&Sensor_macCallbacks, &jdllcCallbacks);
/* Register the MAC Callbacks */
ApiMac_registerCallbacks(&Sensor_macCallbacks);
/* Initialize the platform specific functions */
Ssf_init(sem);
/* Intialize the security manager and register callbacks */
SM_init();
SM_registerCallback(&SMCallbacks);
ApiMac_mlmeSetReqUint8(ApiMac_attribute_phyCurrentDescriptorId,
(uint8_t)CONFIG_PHY_ID);
ApiMac_mlmeSetReqUint8(ApiMac_attribute_channelPage,
(uint8_t)CONFIG_CHANNEL_PAGE);
Ssf_getFrameCounter(NULL, &frameCounter);
#ifdef FEATURE_MAC_SECURITY
/* Initialize the MAC Security */
Jdllc_securityInit(frameCounter);
#endif /* FEATURE_MAC_SECURITY */
/* Set the transmit power */
ApiMac_mlmeSetReqUint8(ApiMac_attribute_phyTransmitPowerSigned,
(uint8_t)CONFIG_TRANSMIT_POWER);
/* Set Min BE */
ApiMac_mlmeSetReqUint8(ApiMac_attribute_backoffExponent,
(uint8_t)CONFIG_MIN_BE);
/* Set Max BE */
ApiMac_mlmeSetReqUint8(ApiMac_attribute_maxBackoffExponent,
(uint8_t)CONFIG_MAX_BE);
/* Set MAC MAX CSMA Backoffs */
ApiMac_mlmeSetReqUint8(ApiMac_attribute_maxCsmaBackoffs,
(uint8_t)CONFIG_MAC_MAX_CSMA_BACKOFFS);
/* Set MAC MAX Frame Retries */
ApiMac_mlmeSetReqUint8(ApiMac_attribute_maxFrameRetries,
(uint8_t)CONFIG_MAX_RETRIES);
#ifdef FCS_TYPE16
/* Set the fcs type */
ApiMac_mlmeSetReqBool(ApiMac_attribute_fcsType,
(bool)1);
#endif
/* Initialize the app clocks */
initializeClocks();
if(CONFIG_AUTO_START)
/* Start the device */
Util_setEvent(&Sensor_events, SENSOR_START_EVT);
Application task processing.
void Sensor_process(void)
/* Start the collector device in the network */
if(Sensor_events & SENSOR_START_EVT)
ApiMac_deviceDescriptor_t devInfo;
Llc_netInfo_t parentInfo;
if(Ssf_getNetworkInfo(&devInfo, &parentInfo ) == true)
Ssf_configSettings_t configInfo;
ApiMac_status_t stat;
/* Do we have config settings? */
if(Ssf_getConfigInfo(&configInfo) == true)
/* Save the config information */
configSettings.frameControl = configInfo.frameControl;
configSettings.reportingInterval = configInfo.reportingInterval;
configSettings.pollingInterval = configInfo.pollingInterval;
/* Update the polling interval in the LLC */
Jdllc_setPollRate(configSettings.pollingInterval);
/* Initially, setup the parent as the collector */
if(parentInfo.fh == true && CONFIG_RX_ON_IDLE)
collectorAddr.addrMode = ApiMac_addrType_extended;
memcpy(&collectorAddr.addr.extAddr,
parentInfo.devInfo.extAddress, APIMAC_SADDR_EXT_LEN);
else
collectorAddr.addrMode = ApiMac_addrType_short;
collectorAddr.addr.shortAddr = parentInfo.devInfo.shortAddress;
/* Put the parent in the security device list */
stat = Jdllc_addSecDevice(parentInfo.devInfo.panID,
parentInfo.devInfo.shortAddress,
&parentInfo.devInfo.extAddress, 0);
if(stat != ApiMac_status_success)
Ssf_displayError("Auth Error: 0x", (uint8_t)stat);
if(!CONFIG_FH_ENABLE)
nvDeviceKeyInfo_t devKeyInfo;
SM_seedKey_Entry_t * pSeedKeyEnty;
if(Ssf_getDeviceKeyInfo(&devKeyInfo) == TRUE)
/* Update the seedKeyTable and MAC Key Table */
/* Use its own ext address */
updateSeedKeyFromNV(&devInfo,&devKeyInfo);
pSeedKeyEnty = getEntryFromSeedKeyTable(devInfo.extAddress,devInfo.shortAddress);
/* Do not change the order below to lines */
/* Copy collector ext Address first */
memcpy(commissionDevInfo.extAddress, parentInfo.devInfo.extAddress, sizeof(ApiMac_sAddrExt_t));
addDeviceKey(pSeedKeyEnty,devKeyInfo.deviceKey, true);
LCD_WRITE_STRING("KeyInfo recovered", 6);
#endif
Jdllc_rejoin(&devInfo, &parentInfo);
rejoining = true;
else
/* Get Start Timestamp */
joinTimeTicks = Clock_getTicks();
#else
joinTimeTicks = ICall_getTicks();
#endif
Jdllc_join();
Util_clearEvent(&Sensor_events, SENSOR_START_EVT);
/* Is it time to send the next sensor data message? */
if(Sensor_events & SENSOR_READING_TIMEOUT_EVT)
/* In certification test mode, back to back data shall be sent */
/* Setup for the next message */
Ssf_setReadingClock(configSettings.reportingInterval);
/* if secure Commissioning feature is enabled, read
* sensor data and send it only after the secure
* commissioning process is done successfully.
* else, do not read and send sensor data.
#endif //FEATURE_SECURE_COMMISSIONING
processSensorRampMsgEvt();
#else
/* Read sensors */
readSensors();
/* Process Sensor Reading Message Event */
processSensorMsgEvt();
#endif //SENSOR_TEST_RAMP_DATA_SIZE
#endif //OAD_IMG_A
Util_clearEvent(&Sensor_events, SENSOR_READING_TIMEOUT_EVT);
#if defined(OAD_IMG_A)
if(Sensor_events & SENSOR_OAD_SEND_RESET_RSP_EVT )
/* send OAD reset response */
if( false == Oad_hasSentResetRsp)
OADProtocol_Status_t status;
status = OADProtocol_sendOadResetRsp(&collectorAddr);
if(OADProtocol_Status_Success == status)
//notify to user
LCD_WRITE_STRING("Sent Reset Response", 6);
Oad_hasSentResetRsp = true;
else
LCD_WRITE_STRING(" Failed to send Reset Response", 6);
Util_clearEvent(&Sensor_events, SENSOR_OAD_SEND_RESET_RSP_EVT);
#endif //OAD_IMG_A
#ifdef DISPLAY_PER_STATS
if(Sensor_events & SENSOR_UPDATE_STATS_EVT)
Ssf_displayPerStats(&Sensor_msgStats);
Util_clearEvent(&Sensor_events, SENSOR_UPDATE_STATS_EVT);
#endif /* DISPLAY_PER_STATS */
/* Process LLC Events */
Jdllc_process();
/* Allow the Specific functions to process */
Ssf_processEvents();
/* Allow the security manager specific functions to process */
SM_process();
Don't process ApiMac messages until all of the sensor events
are processed.
/*only if there are no sensor events and security manager events to handle*/
if((Sensor_events == 0) && (SM_events == 0))
#else
if(Sensor_events == 0)
#endif
/* Wait for response message or events */
ApiMac_processIncoming();
* @brief Send MAC data request
* @param type - message type
* @param pDstAddr - destination address
* @param rxOnIdle - true if not a sleepy device
* @param len - length of payload
* @param pData - pointer to the buffer
* @return true if sent, false if not
bool Sensor_sendMsg(Smsgs_cmdIds_t type, ApiMac_sAddr_t *pDstAddr,
bool rxOnIdle, uint16_t len, uint8_t *pData)
bool ret = false;
ApiMac_mcpsDataReq_t dataReq;
/* Timestamp to compute end to end delay */
startSensorMsgTimeStamp = Clock_getTicks();
#else
startSensorMsgTimeStamp = ICall_getTicks();
#endif
/* Fill the data request field */
memset(&dataReq, 0, sizeof(ApiMac_mcpsDataReq_t));
memcpy(&dataReq.dstAddr, pDstAddr, sizeof(ApiMac_sAddr_t));
if(pDstAddr->addrMode == ApiMac_addrType_extended)
dataReq.srcAddrMode = ApiMac_addrType_extended;
else
dataReq.srcAddrMode = ApiMac_addrType_short;
if(rejoining == true)
ApiMac_mlmeGetReqUint16(ApiMac_attribute_panId,
&(parentInfo.devInfo.panID));
dataReq.dstPanId = parentInfo.devInfo.panID;
dataReq.msduHandle = getMsduHandle(type);
dataReq.txOptions.ack = true;
if(CERTIFICATION_TEST_MODE)
dataReq.txOptions.ack = false;
if(rxOnIdle == false)
dataReq.txOptions.indirect = true;
dataReq.msdu.len = len;
dataReq.msdu.p = pData;
extern ApiMac_sAddrExt_t ApiMac_extAddr;
SM_getSrcDeviceSecurityInfo(ApiMac_extAddr, SM_Sensor_SAddress, &dataReq.sec);
#else
Jdllc_securityFill(&dataReq.sec);
if(type == Smsgs_cmdIds_sensorData || type == Smsgs_cmdIds_rampdata)
Sensor_msgStats.msgsAttempted++;
else if(type == Smsgs_cmdIds_trackingRsp)
Sensor_msgStats.trackingResponseAttempts++;
else if(type == Smsgs_cmdIds_configRsp)
Sensor_msgStats.configResponseAttempts++;
/* Send the message */
if(ApiMac_mcpsDataReq(&dataReq) == ApiMac_status_success)
ret = true;
else
/* handle transaction overflow by retrying */
return (ret);
#ifdef IDENTIFY_LED
Send LED Identify Request to collector
void Sensor_sendIdentifyLedRequest(void)
uint8_t cmdBytes[SMSGS_INDENTIFY_LED_REQUEST_MSG_LEN];
/* send the response message directly */
cmdBytes[0] = (uint8_t) Smsgs_cmdIds_IdentifyLedReq;
cmdBytes[1] = (uint8_t) IDENTIFY_LED_TIME;
Sensor_sendMsg(Smsgs_cmdIds_IdentifyLedReq,
&collectorAddr, true,
SMSGS_INDENTIFY_LED_REQUEST_MSG_LEN,
cmdBytes);
#endif
Local Functions
* @brief Initialize the clocks.
/* Initialize the reading clock */
Ssf_initializeReadingClock();
* @brief MAC Data Confirm callback.
* @param pDataCnf - pointer to the data confirm information
uint16_t endToEndDelay = 0;
/* Record statistics */
if(pDataCnf->status == ApiMac_status_channelAccessFailure)
Sensor_msgStats.channelAccessFailures++;
else if(pDataCnf->status == ApiMac_status_noAck)
Sensor_msgStats.macAckFailures++;
Util_setEvent(&Sensor_events, SENSOR_UPDATE_STATS_EVT);
#endif
else if(pDataCnf->status != ApiMac_status_success)
Sensor_msgStats.otherDataRequestFailures++;
#endif
Ssf_displayError("dataCnf: ", pDataCnf->status);
else if(pDataCnf->status == ApiMac_status_success)
Ssf_updateFrameCounter(NULL, pDataCnf->frameCntr);
/* Make sure the message came from the app */
if(pDataCnf->msduHandle & APP_MARKER_MSDU_HANDLE)
/* What message type was the original request? */
if((pDataCnf->msduHandle & APP_MASK_MSDU_HANDLE)
== APP_SENSOR_MSDU_HANDLE)
Sensor_msgStats.msgsSent++;
#endif
/* Calculate end to end delay */
if(Clock_getTicks() < startSensorMsgTimeStamp)
endToEndDelay = Clock_getTicks() +
(0xFFFFFFFF-startSensorMsgTimeStamp);
else
endToEndDelay = Clock_getTicks() - startSensorMsgTimeStamp;
#else
if(ICall_getTicks() < startSensorMsgTimeStamp)
endToEndDelay = ICall_getTicks() +
else
endToEndDelay = ICall_getTicks() - startSensorMsgTimeStamp;
#endif
endToEndDelay = endToEndDelay/TICKPERIOD_MS_US;
Sensor_msgStats.worstCaseE2EDelay =
(Sensor_msgStats.worstCaseE2EDelay > endToEndDelay) ?
Sensor_msgStats.worstCaseE2EDelay:endToEndDelay;
Sensor_msgStats.avgE2EDelay =
(((uint32_t)Sensor_msgStats.avgE2EDelay *
(Sensor_msgStats.msgsSent - 1)) + endToEndDelay)/
Sensor_msgStats.msgsSent;
Ssf_setReadingClock(CERT_MODE_INTER_PKT_INTERVAL);
#endif
== APP_TRACKRSP_MSDU_HANDLE)
Sensor_msgStats.trackingResponseSent++;
== APP_CONFIGRSP_MSDU_HANDLE)
Sensor_msgStats.configResponseSent++;
* @brief MAC Data Indication callback.
* @param pDataInd - pointer to the data indication information
uint8_t cmdBytes[SMSGS_TOGGLE_LED_RESPONSE_MSG_LEN];
if((pDataInd != NULL) && (pDataInd->msdu.p != NULL)
&& (pDataInd->msdu.len > 0))
Smsgs_cmdIds_t cmdId = (Smsgs_cmdIds_t)*(pDataInd->msdu.p);
if(Jdllc_securityCheck(&(pDataInd->sec)) == false)
/* reject the message */
return;
switch(cmdId)
case Smsgs_cmdIds_configReq:
processConfigRequest(pDataInd);
Sensor_msgStats.configRequests++;
break;
case Smsgs_cmdIds_trackingReq:
/* Make sure the message is the correct size */
if(pDataInd->msdu.len == SMSGS_TRACKING_REQUEST_MSG_LENGTH)
/* Update stats */
Sensor_msgStats.trackingRequests++;
/* Indicate tracking message received */
Ssf_trackingUpdate(&pDataInd->srcAddr);
cmdBytes[0] = (uint8_t) Smsgs_cmdIds_trackingRsp;
Sensor_sendMsg(Smsgs_cmdIds_trackingRsp,
&pDataInd->srcAddr, true,
1, cmdBytes);
break;
case Smsgs_cmdIds_toggleLedReq:
if(pDataInd->msdu.len == SMSGS_TOGGLE_LED_REQUEST_MSG_LEN)
cmdBytes[0] = (uint8_t) Smsgs_cmdIds_toggleLedRsp;
cmdBytes[1] = Ssf_toggleLED();
Sensor_sendMsg(Smsgs_cmdIds_toggleLedRsp,
SMSGS_TOGGLE_LED_RESPONSE_MSG_LEN,
cmdBytes);
break;
case Smgs_cmdIds_broadcastCtrlMsg:
if(parentFound)
/* Node has successfully associated with the network */
processBroadcastCtrlMsg(pDataInd);
break;
#ifdef POWER_MEAS
case Smsgs_cmdIds_rampdata:
Sensor_pwrMeasStats.rampDataRcvd++;
break;
#endif
case Smsgs_cmdIds_oad:
//Index past the Smsgs_cmdId
OADProtocol_ParseIncoming((void*) &(pDataInd->srcAddr), pDataInd->msdu.p + 1);
break;
#endif //FEATURE_NATIVE_OAD
case Smgs_cmdIds_CommissionStart:
ApiMac_sec_t devSec;
/* Obtain MAC level security information. Use network key for SM */
Jdllc_securityFill(&devSec);
uint8_t *pBuf = pDataInd->msdu.p;
pBuf += sizeof(Smsgs_cmdIds_t);
SMMsgs_cmdIds_t CMMsgId = (SMMsgs_cmdIds_t)Util_buildUint16(pBuf[0], pBuf[1]);
/* read the current value */
ApiMac_mlmeGetReqBool(ApiMac_attribute_autoRequest, &currAutoReq);
/* beacon-mode of operation and autoRequest is set to true */
if((CONFIG_BEACON_ORDER != 15) && (currAutoReq == true))
/* if false enable explicit polling */
ApiMac_mlmeSetReqBool(ApiMac_attribute_autoRequest, false);
Util_setEvent(&Jdllc_events, JDLLC_POLL_EVT);
if ((SM_Last_State != SM_CM_InProgress) &&
(CMMsgId == SMMsgs_cmdIds_KeyRefreshRequest))
/* Kick off key refreshment process after successful commissioning */
SM_startKeyRefreshProcess(&parentInfo.devInfo, &devSec,
parentInfo.fh, true);
else
/* Kick off commissioning process to obtain security information */
SM_startCMProcess(&parentInfo.devInfo, &devSec, parentInfo.fh,
true, SM_type_device, SM_SENSOR_AUTH_METHOD);
break;
case Smgs_cmdIds_CommissionMsg:
/* Process Security manager commissioning data */
SM_processCommData(pDataInd);
break;
default:
/* Should not receive other messages */
break;
* @brief Get the next MSDU Handle
* <BR>
* The MSDU handle has 3 parts:<BR>
* - The MSBit(7), when set means the the application sent the
* message
* - Bit 6, when set means that the app message is a config request
* - Bits 0-5, used as a message counter that rolls over.
* @param msgType - message command id needed
* @return msdu Handle
uint8_t msduHandle = deviceTxMsduHandle;
/* Increment for the next msdu handle, or roll over */
if(deviceTxMsduHandle >= MSDU_HANDLE_MAX)
else
deviceTxMsduHandle++;
/* Add the App specific bit */
msduHandle |= APP_MARKER_MSDU_HANDLE;
/* Add the message type bit */
if(msgType == Smsgs_cmdIds_sensorData || msgType == Smsgs_cmdIds_rampdata)
msduHandle |= APP_SENSOR_MSDU_HANDLE;
else if(msgType == Smsgs_cmdIds_trackingRsp)
msduHandle |= APP_TRACKRSP_MSDU_HANDLE;
else if(msgType == Smsgs_cmdIds_configRsp)
msduHandle |= APP_CONFIGRSP_MSDU_HANDLE;
return (msduHandle);
@brief Build and send fixed size ramp data
uint8_t *pMsgBuf;
uint16_t index;
pMsgBuf = (uint8_t *)Ssf_malloc(SENSOR_TEST_RAMP_DATA_SIZE);
if(pMsgBuf)
uint8_t *pBuf = pMsgBuf;
*pBuf++ = (uint8_t)Smsgs_cmdIds_rampdata;
for(index = 1; index < SENSOR_TEST_RAMP_DATA_SIZE; index++)
*pBuf++ = (uint8_t) (index & 0xFF);
#ifndef POWER_MEAS
#endif
Sensor_sendMsg(Smsgs_cmdIds_rampdata, &collectorAddr, true,
SENSOR_TEST_RAMP_DATA_SIZE, pMsgBuf);
Ssf_free(pMsgBuf);
#endif
@brief Build and send sensor data message
Smsgs_sensorMsg_t sensor;
uint32_t stat;
memset(&sensor, 0, sizeof(Smsgs_sensorMsg_t));
ApiMac_mlmeGetReqUint32(ApiMac_attribute_diagRxSecureFail, &stat);
Sensor_msgStats.rxDecryptFailures = (uint16_t)stat;
ApiMac_mlmeGetReqUint32(ApiMac_attribute_diagTxSecureFail, &stat);
Sensor_msgStats.txEncryptFailures = (uint16_t)stat;
ApiMac_mlmeGetReqArray(ApiMac_attribute_extendedAddress,
sensor.extAddress);
/* fill in the message */
sensor.frameControl = configSettings.frameControl;
if(sensor.frameControl & Smsgs_dataFields_tempSensor)
memcpy(&sensor.tempSensor, &tempSensor,
sizeof(Smsgs_tempSensorField_t));
if(sensor.frameControl & Smsgs_dataFields_lightSensor)
memcpy(&sensor.lightSensor, &lightSensor,
sizeof(Smsgs_lightSensorField_t));
if(sensor.frameControl & Smsgs_dataFields_humiditySensor)
memcpy(&sensor.humiditySensor, &humiditySensor,
sizeof(Smsgs_humiditySensorField_t));
if(sensor.frameControl & Smsgs_dataFields_msgStats)
memcpy(&sensor.msgStats, &Sensor_msgStats,
sizeof(Smsgs_msgStatsField_t));
if(sensor.frameControl & Smsgs_dataFields_configSettings)
sensor.configSettings.pollingInterval = configSettings.pollingInterval;
sensor.configSettings.reportingInterval = configSettings
.reportingInterval;
/* inform the user interface */
Ssf_sensorReadingUpdate(&sensor);
/* send the data to the collector */
sendSensorMessage(&collectorAddr, &sensor);
* @brief Manually read the sensors
/* Read the temp sensor values */
tempSensor.ambienceTemp = Ssf_readTempSensor();
tempSensor.objectTemp = tempSensor.ambienceTemp;
#endif
/* Read the humidity sensor values */
txBuffer[0] = 0xE3;
i2cTransaction.slaveAddress = Si7021_ADDR;
i2cTransaction.writeBuf = txBuffer;
i2cTransaction.writeCount = 1;
i2cTransaction.readBuf = rxBuffer;
i2cTransaction.readCount = 2;
if (I2C_transfer(i2c, &i2cTransaction))
// char buf[64];
temper = (rxBuffer[0] << 8) | (rxBuffer[1]);
temperature = (175.72*temper)/65536;
temperature -= 46.85;
humiditySensor.temp = temperature;
//sprintf(buf,"Buffer:%.2fC\n",temperature);
// Display_printf(display, 1, 0, "Temp:%.2fC\n",temperature);
LCD_WRITE_STRING_VALUE("Temp:%.2fC\n", temperature, 16, 4);
//Display_printf(display, 1, 0, "%s\n",buf);
else
//Display_printf(display, 0, 0, "I2C Bus fault.");
LCD_WRITE_STRING("I2C Bus fault\n", 6);
txBuffer[0] = 0xE5;
humi = (rxBuffer[0] << 8) | (rxBuffer[1]);
humidity = (125*humi)/65536;
humidity -=6;
humiditySensor.humidity = humidity;
//Display_printf(display, 0, 0, "Humi:%.1f%c",humidity,37);
LCD_WRITE_STRING_VALUE("Humi:%.2f", humidity, 16, 4);
else
/* Sleep for 1 second */
// sleep(1);
#endif
* @brief Build and send sensor data message
* @param pDstAddr - Where to send the message
* @param pMsg - pointer to the sensor data
* @return true if message was sent, false if not
static bool sendSensorMessage(ApiMac_sAddr_t *pDstAddr, Smsgs_sensorMsg_t *pMsg)
bool ret = false;
uint8_t *pMsgBuf;
uint16_t len = SMSGS_BASIC_SENSOR_LEN;
/* Figure out the length */
if(pMsg->frameControl & Smsgs_dataFields_tempSensor)
len += SMSGS_SENSOR_TEMP_LEN;
if(pMsg->frameControl & Smsgs_dataFields_lightSensor)
len += SMSGS_SENSOR_LIGHT_LEN;
if(pMsg->frameControl & Smsgs_dataFields_humiditySensor)
len += SMSGS_SENSOR_HUMIDITY_LEN;
if(pMsg->frameControl & Smsgs_dataFields_msgStats)
//len += SMSGS_SENSOR_MSG_STATS_LEN;
len += sizeof(Smsgs_msgStatsField_t);
if(pMsg->frameControl & Smsgs_dataFields_configSettings)
len += SMSGS_SENSOR_CONFIG_SETTINGS_LEN;
pMsgBuf = (uint8_t *)Ssf_malloc(len);
if(pMsgBuf)
*pBuf++ = (uint8_t)Smsgs_cmdIds_sensorData;
memcpy(pBuf, pMsg->extAddress, SMGS_SENSOR_EXTADDR_LEN);
pBuf += SMGS_SENSOR_EXTADDR_LEN;
pBuf = Util_bufferUint16(pBuf,pMsg->frameControl);
/* Buffer data in order of frameControl mask, starting with LSB */
pBuf = Util_bufferUint16(pBuf, pMsg->tempSensor.ambienceTemp);
pBuf = Util_bufferUint16(pBuf, pMsg->tempSensor.objectTemp);
pBuf = Util_bufferUint16(pBuf, pMsg->lightSensor.rawData);
pBuf = Util_bufferUint16(pBuf, pMsg->humiditySensor.temp);
pBuf = Util_bufferUint16(pBuf, pMsg->humiditySensor.humidity);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.joinAttempts);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.joinFails);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.msgsAttempted);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.msgsSent);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.trackingRequests);
pMsg->msgStats.trackingResponseAttempts);
pMsg->msgStats.trackingResponseSent);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.configRequests);
pMsg->msgStats.configResponseAttempts);
pMsg->msgStats.configResponseSent);
pMsg->msgStats.channelAccessFailures);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.macAckFailures);
pMsg->msgStats.otherDataRequestFailures);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.syncLossIndications);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.rxDecryptFailures);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.txEncryptFailures);
pBuf = Util_bufferUint16(pBuf, Ssf_resetCount);
pBuf = Util_bufferUint16(pBuf, Ssf_resetReseason);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.joinTime);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.interimDelay);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.numBroadcastMsgRcvd);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.numBroadcastMsglost);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.avgE2EDelay);
pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.worstCaseE2EDelay);
pBuf = Util_bufferUint32(pBuf,
pMsg->configSettings.reportingInterval);
pMsg->configSettings.pollingInterval);
ret = Sensor_sendMsg(Smsgs_cmdIds_sensorData, pDstAddr, true, len, pMsgBuf);
Ssf_free(pMsgBuf);
return (ret);
#endif // !defined(OAD_IMG_A)
* @brief Process the Config Request message.
Smsgs_statusValues_t stat = Smsgs_statusValues_invalid;
Smsgs_configRspMsg_t configRsp;
memset(&configRsp, 0, sizeof(Smsgs_configRspMsg_t));
if(pDataInd->msdu.len == SMSGS_CONFIG_REQUEST_MSG_LENGTH)
uint16_t frameControl;
uint32_t reportingInterval;
uint32_t pollingInterval;
/* Parse the message */
configSettings.cmdId = (Smsgs_cmdIds_t)*pBuf++;
frameControl = Util_parseUint16(pBuf);
pBuf += 2;
reportingInterval = Util_parseUint32(pBuf);
pBuf += 4;
pollingInterval = Util_parseUint32(pBuf);
stat = Smsgs_statusValues_success;
collectorAddr.addrMode = pDataInd->srcAddr.addrMode;
if(collectorAddr.addrMode == ApiMac_addrType_short)
collectorAddr.addr.shortAddr = pDataInd->srcAddr.addr.shortAddr;
else
memcpy(collectorAddr.addr.extAddr, pDataInd->srcAddr.addr.extAddr,
configSettings.frameControl = validateFrameControl(frameControl);
if(configSettings.frameControl != frameControl)
stat = Smsgs_statusValues_partialSuccess;
configRsp.frameControl = configSettings.frameControl;
if((reportingInterval < MIN_REPORTING_INTERVAL)
|| (reportingInterval > MAX_REPORTING_INTERVAL))
else
#ifndef POWER_MEAS
configSettings.reportingInterval = reportingInterval;
#endif
uint32_t randomNum;
randomNum = ((ApiMac_randomByte() << 16) +
randomNum = (randomNum % reportingInterval) +
SENSOR_MIN_POLL_TIME;
Ssf_setReadingClock(randomNum);
configRsp.reportingInterval = configSettings.reportingInterval;
if((pollingInterval < MIN_POLLING_INTERVAL)
|| (pollingInterval > MAX_POLLING_INTERVAL))
else
configSettings.pollingInterval = pollingInterval;
configRsp.pollingInterval = configSettings.pollingInterval;
/* Send the response message */
configRsp.cmdId = Smsgs_cmdIds_configRsp;
configRsp.status = stat;
/* Update the user */
Ssf_configurationUpdate(&configRsp);
/* Response the the source device */
sendConfigRsp(&pDataInd->srcAddr, &configRsp);
* @brief Process the Broadcast Control Msg.
Smsgs_broadcastcmdmsg_t broadcastCmd;
memset(&broadcastCmd, 0, sizeof(Smsgs_broadcastcmdmsg_t));
if(pDataInd->msdu.len == SMSGS_BROADCAST_CMD_LENGTH)
uint16_t broadcastMsgId;
uint8_t cmdId = (Smsgs_cmdIds_t)*pBuf++;
broadcastMsgId = Util_parseUint16(pBuf);
/* Process Broadcast Command Message */
Sensor_msgStats.numBroadcastMsgRcvd++;
if(!initBroadcastMsg)
/* Not the first broadcast msg rcvdd after join or a rejoin*/
if((broadcastMsgId - lastRcvdBroadcastMsgId) > 1)
Sensor_msgStats.numBroadcastMsglost +=
((broadcastMsgId - lastRcvdBroadcastMsgId) -1);
lastRcvdBroadcastMsgId = broadcastMsgId;
/*To handle the very first broadcast msg rcvdd after join or a rejoin*/
initBroadcastMsg = false;
/* Switch On or Off LED based on broadcast Msg Id */
if((broadcastMsgId % 2) == 0)
Ssf_OnLED();
else
Ssf_OffLED();
* @brief Build and send Config Response message
* @param pMsg - pointer to the Config Response
uint8_t msgBuf[SMSGS_CONFIG_RESPONSE_MSG_LENGTH];
uint8_t *pBuf = msgBuf;
*pBuf++ = (uint8_t) Smsgs_cmdIds_configRsp;
pBuf = Util_bufferUint16(pBuf, pMsg->status);
pBuf = Util_bufferUint16(pBuf, pMsg->frameControl);
pBuf = Util_bufferUint32(pBuf, pMsg->reportingInterval);
pBuf = Util_bufferUint32(pBuf, pMsg->pollingInterval);
return (Sensor_sendMsg(Smsgs_cmdIds_configRsp, pDstAddr, true,
SMSGS_CONFIG_RESPONSE_MSG_LENGTH, msgBuf));
* @brief Filter the frameControl with readings supported by this device.
* @param frameControl - suggested frameControl
* @return new frame control settings supported
uint16_t newFrameControl = 0;
if(frameControl & Smsgs_dataFields_tempSensor)
newFrameControl |= Smsgs_dataFields_tempSensor;
#endif
if(frameControl & Smsgs_dataFields_lightSensor)
newFrameControl |= Smsgs_dataFields_lightSensor;
#endif
if(frameControl & Smsgs_dataFields_humiditySensor)
newFrameControl |= Smsgs_dataFields_humiditySensor;
#endif
if(frameControl & Smsgs_dataFields_msgStats)
newFrameControl |= Smsgs_dataFields_msgStats;
if(frameControl & Smsgs_dataFields_configSettings)
newFrameControl |= Smsgs_dataFields_configSettings;
return (newFrameControl);
* @brief The device joined callback.
* @param pDevInfo - This device's information
* @param pParentInfo - This is the parent's information
Llc_netInfo_t *pParentInfo)
uint32_t randomNum = 0;
/* Copy the parent information */
memcpy(&parentInfo, pParentInfo, sizeof(Llc_netInfo_t));
/* Set the collector's address as the parent's address */
if (pParentInfo->fh && CONFIG_RX_ON_IDLE)
memcpy(collectorAddr.addr.extAddr, pParentInfo->devInfo.extAddress,
else
collectorAddr.addr.shortAddr = pParentInfo->devInfo.shortAddress;
/* Start the reporting timer */
if(CONFIG_FH_ENABLE)
randomNum = (randomNum % configSettings.reportingInterval) +
else
uint32_t randomNum;
randomNum = (randomNum % configSettings.reportingInterval ) +
/* Inform the user of the joined information */
Ssf_networkUpdate(rejoining, pDevInfo, pParentInfo);
#ifdef FEATURE_SECURE_COMMISSIONING
SM_Sensor_SAddress = pDevInfo->shortAddress;
#endif
if((rejoining == false) && (pParentInfo->fh == false))
/* Add the parent to the security device list */
stat = Jdllc_addSecDevice(pParentInfo->devInfo.panID,
pParentInfo->devInfo.shortAddress,
&pParentInfo->devInfo.extAddress, 0);
#if (CONFIG_SUPERFRAME_ORDER != 15) && defined(MAC_NO_AUTO_REQ)
* Set MAC Auto Request to false to enable multiple poll requests
* per beacon interval
#endif
#ifdef OSAL_PORT2TIRTOS
/* Calculate Join Time */
if(Clock_getTicks() < joinTimeTicks)
joinTimeTicks = Clock_getTicks() + (0xFFFFFFFF-joinTimeTicks);
else
joinTimeTicks = Clock_getTicks() - joinTimeTicks;
#else
if(ICall_getTicks() < joinTimeTicks)
joinTimeTicks = ICall_getTicks() + (0xFFFFFFFF-joinTimeTicks);
else
joinTimeTicks = ICall_getTicks() - joinTimeTicks;
#endif
Sensor_msgStats.joinTime = joinTimeTicks / TICKPERIOD_MS_US;
/* clear the stats used for PER so that we start out at a
* zeroed state
Sensor_msgStats.macAckFailures = 0;
Sensor_msgStats.otherDataRequestFailures = 0;
Sensor_msgStats.msgsSent = 0;
#endif
* @brief Disassociation indication callback.
* @param pExtAddress - extended address
* @param reason - reason for disassociation
static void jdllcDisassocIndCb(ApiMac_sAddrExt_t *pExtAddress,
/* Stop the reporting timer */
Ssf_setReadingClock(0);
Ssf_clearNetworkInfo();
SM_removeEntryFromSeedKeyTable(pExtAddress);
ApiMac_secDeleteDevice(pExtAddress);
Ssf_clearDeviceKeyInfo();
#endif
/* OAD abort with no auto resume */
OADClient_abort(false);
* @brief Disassociation confirm callback to an application intiated
* disassociation request.
* @param status - status of disassociation
static void jdllcDisassocCnfCb(ApiMac_sAddrExt_t *pExtAddress,
#endif
* @brief JDLLC state change callback.
* @param state - new state
if( (state == Jdllc_states_joined) || (state == Jdllc_states_rejoined))
#if (CONFIG_SUPERFRAME_ORDER == 15)
/* resume an OAD that may have aborted */
OADClient_resume(30000);
#else
OADClient_resume(60000);
#endif
else if(state == Jdllc_states_orphan)
Ssf_stateChangeUpdate(state);
#ifdef OAD_IMG_A
Util_setEvent(&Sensor_events, SENSOR_OAD_SEND_RESET_RSP_EVT);
#endif
* @brief Security manager failure processing function
void smFailCMProcessCb(ApiMac_deviceDescriptor_t *devInfo, bool rxOnIdle, bool keyRefreshment)
/* restore, write back current Pib value for auto request attribute */
ApiMac_mlmeSetReqBool(ApiMac_attribute_autoRequest, currAutoReq);
if (keyRefreshment == true)
LCD_WRITE_STRING_VALUE("Key Refresh Failed: 0x", SM_Sensor_SAddress, 16, 4);
else
LCD_WRITE_STRING_VALUE("Commissioning Failed: 0x", SM_Sensor_SAddress, 16, 4);
* @brief Security manager success processing function
void smSuccessCMProcessCb(ApiMac_deviceDescriptor_t *devInfo, bool keyRefreshment)
LCD_WRITE_STRING_VALUE("Key Refreshed: 0x", SM_Sensor_SAddress, 16, 4);
else
LCD_WRITE_STRING_VALUE("Commissioned: 0x", SM_Sensor_SAddress, 16, 4);
@file main.c
@brief main entry of the example application
Group: WCS LPC
Target Device: cc13x0
Copyright (c) 2016-2019, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Includes
#include <xdc/std.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/System.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ioc.h>
#include "sys_ctrl.h"
#include "Board.h"
#include "board_led.h"
#if defined(DeviceFamily_CC13X0) || defined(DeviceFamily_CC13X2)
#include "board_gpio.h"
#endif
#include <inc/hw_ccfg.h>
#include <inc/hw_ccfg_simple_struct.h>
/* Header files required for the temporary idle task function */
#include <ti/drivers/Power.h>
#include <ti/drivers/power/PowerCC26XX.h>
#include <aon_rtc.h>
#include <prcm.h>
#if defined(FEATURE_BLE_OAD) || defined(FEATURE_NATIVE_OAD)
#include <ti/drivers/SPI.h>
#endif
#ifdef FEATURE_UBLE
#include "bleAdv.h"
#endif /* FEATURE_UBLE */
#include "ble_oad/oad_switch.h"
#endif
/* Header files required to enable instruction fetch cache */
#include <vims.h>
#include <hw_memmap.h>
#include <ti/sysbios/hal/Hwi.h>
#include "cpu.h"
#ifdef NV_RESTORE
#include "macconfig.h"
#ifdef ONE_PAGE_NV
#include "nvocop.h"
#else
#include "nvoctp.h"
#endif
#endif
#include <string.h>
#include "macTask.h"
#include"rom_jt.h"
#else
#include "api_mac.h"
#include "icall.h"
#endif
#include "ssf.h"
#include "uart_printf.h"
#include "sensor.h"
#if defined(ASSERT_LEDS)
#endif
#ifndef USE_DEFAULT_USER_CFG
#include "mac_user_config.h"
/* MAC user defined configuration */
macUserCfg_t macUser0Cfg[] = MAC_USER_CFG;
#endif /* USE_DEFAULT_USER_CFG */
#if ((CONFIG_RANGE_EXT_MODE == APIMAC_HIGH_GAIN_MODE) && \
defined(DeviceFamily_CC13X0) && !defined(FREQ_2_4G))
#include "board_palna.h"
#endif
Constants
/* Assert Reasons */
#define MAIN_ASSERT_ICALL 2
#define MAIN_ASSERT_MAC 3
#define MAIN_ASSERT_HWI_TIRTOS 4
#define MAX_ASSERT_TOGGLE_COUNT 500000
#define RFC_MODE_BLE PRCM_RFCMODESEL_CURR_MODE1
#define RFC_MODE_IEEE PRCM_RFCMODESEL_CURR_MODE2
#define RFC_MODE_ANT PRCM_RFCMODESEL_CURR_MODE4
#define RFC_MODE_EVERYTHING_BUT_ANT PRCM_RFCMODESEL_CURR_MODE5
#define RFC_MODE_EVERYTHING PRCM_RFCMODESEL_CURR_MODE6
/* Extended Address offset in FCFG (LSB..MSB) */
#define EXTADDR_OFFSET 0x2F0
#define APP_TASK_PRIORITY 1
#if defined(DeviceFamily_CC13X2) || (DeviceFamily_CC26X2)
#define APP_TASK_STACK_SIZE 1536
#else
#define APP_TASK_STACK_SIZE 900
#endif
#define SET_RFC_MODE(mode) HWREG( PRCM_BASE + PRCM_O_RFCMODESEL ) = (mode)
External Variables
Global Variables
Task_Struct appTask; /* not static so you can see in ROV */
static uint8_t appTaskStack[APP_TASK_STACK_SIZE];
static uint8_t _macTaskId;
#endif
#ifdef NV_RESTORE
mac_Config_t Main_user1Cfg = { 0 };
#endif
#if defined(BOARD_DISPLAY_USE_UART)
UART_Params uartParams;
#endif
Local Variables
/* Used to check for a valid extended address */
static const uint8_t dummyExtAddr[] =
{ 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
#ifdef NV_RESTORE
#ifdef ONE_PAGE_NV
/* NVOCOP load API pointers */
static void NVOCOP_loadApiPtrs(NVINTF_nvFuncts_t *pfn)
// Load caller's structure with pointers to the NV API functions
pfn->initNV = &NVOCOP_initNV;
pfn->compactNV = &NVOCOP_compactNV;
pfn->createItem = NULL;
pfn->deleteItem = &NVOCOP_deleteItem;
pfn->readItem = &NVOCOP_readItem;
pfn->writeItem = &NVOCOP_writeItem;
pfn->writeItemEx = NULL;
pfn->getItemLen = NULL;
#endif
#endif
* @brief Fill in your own assert function.
* @param assertReason - reason: MAIN_ASSERT_HWI_TIRTOS,
* MAIN_ASSERT_ICALL, or
* MAIN_ASSERT_MAC
void Main_assertHandler(uint8_t assertReason)
int toggleCount = 0;
bool toggle = true;
Hwi_disable();
while(1)
if(toggleCount == 0)
if(toggle == false)
Board_Led_control(board_led_type_LED1, board_led_state_OFF);
#if !defined(DeviceFamily_CC13X0) && !defined(DeviceFamily_CC26X0) && !defined(DeviceFamily_CC13X2) && !defined(DeviceFamily_CC26X2)
Board_Led_control(board_led_type_LED3, board_led_state_OFF);
Board_Led_control(board_led_type_LED4, board_led_state_OFF);
#endif
else if(toggle == true)
Board_Led_control(board_led_type_LED1, board_led_state_ON);
Board_Led_control(board_led_type_LED2, board_led_state_ON);
Board_Led_control(board_led_type_LED3, board_led_state_ON);
Board_Led_control(board_led_type_LED4, board_led_state_ON);
#endif
toggleCount++;
if(toggleCount >= MAX_ASSERT_TOGGLE_COUNT)
toggleCount = 0;
if(toggle == true)
toggle = false;
else
toggle = true;
#else /* ASSERT_LEDS */
Ssf_assertInd(assertReason);
/* Pull the plug and start over */
SysCtrlSystemReset();
#endif /* !ASSERT_LEDS */
* @brief Main task function
* @param a0 -
* @param a1 -
Void appTaskFxn(UArg a0, UArg a1)
#ifdef TIMAC_AGAMA_FPGA
/* FPGA build disables POWER constraints */
Power_setConstraint(PowerCC26XX_IDLE_PD_DISALLOW);
Power_setConstraint(PowerCC26XX_SB_DISALLOW);
IOCPortConfigureSet(IOID_20, IOC_PORT_RFC_GPO0, IOC_STD_OUTPUT);
IOCPortConfigureSet(IOID_18, IOC_PORT_RFC_GPI0, IOC_STD_INPUT);
// configure RF Core SMI Command Link
IOCPortConfigureSet(IOID_22, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_OUT, IOC_STD_OUTPUT);
IOCPortConfigureSet(IOID_21, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_IN, IOC_STD_INPUT);
#endif
#ifndef OSAL_PORT2TIRTOS
/* Initialize ICall module */
ICall_init();
#endif
/* Copy the extended address from the CCFG area */
memcpy(ApiMac_extAddr, (uint8_t *)&(__ccfg.CCFG_IEEE_MAC_0),
(APIMAC_SADDR_EXT_LEN / 2));
memcpy(ApiMac_extAddr + (APIMAC_SADDR_EXT_LEN / 2), (uint8_t *)&(__ccfg.CCFG_IEEE_MAC_1),
/* Check to see if the CCFG IEEE is valid */
if(memcmp(ApiMac_extAddr, dummyExtAddr, APIMAC_SADDR_EXT_LEN) == 0)
/* No, it isn't valid. Get the Primary IEEE Address */
memcpy(ApiMac_extAddr, (uint8_t *)(FCFG1_BASE + EXTADDR_OFFSET),
#ifdef NV_RESTORE
/* Setup the NV driver */
#ifdef ONE_PAGE_NV
NVOCOP_loadApiPtrs(&Main_user1Cfg.nvFps);
#else
NVOCTP_loadApiPtrs(&Main_user1Cfg.nvFps);
#endif
if(Main_user1Cfg.nvFps.initNV)
Main_user1Cfg.nvFps.initNV( NULL);
#endif
/* Initialize the application */
Sensor_init(_macTaskId);
#else
ICall_createRemoteTasks();
Sensor_init();
#endif
#ifdef FEATURE_BLE_OAD
uint8_t blinkCnt = 8;
/* blink to let user know sensor is initializing */
while(blinkCnt)
Board_Led_toggle(board_led_type_LED1);
Task_sleep(10000);
blinkCnt--;
/* reset led back to known state */
#endif /* FEATURE_BLE_OAD */
/* Kick off application - Forever loop */
while(1)
Sensor_process();
* @brief TIRTOS HWI Handler. The name of this function is set to
* M3Hwi.excHandlerFunc in app.cfg, you can disable this by
* setting it to null.
* @param excStack - TIROS variable
* @param lr - TIROS variable
xdc_Void Main_excHandler(UInt *excStack, UInt lr)
/* User defined function */
Main_assertHandler(MAIN_ASSERT_HWI_TIRTOS);
* @brief HAL assert handler required by OSAL memory module.
void halAssertHandler(void)
Main_assertHandler(MAIN_ASSERT_ICALL);
* @brief MAC HAL assert handler.
void macHalAssertHandler(void)
Main_assertHandler(MAIN_ASSERT_MAC);
* @brief "main()" function - starting point
int main(void)
Task_Params taskParams;
/* float temperature;
double temper;
float humidity;
double humi;
I2C_Handle i2c;
I2C_Transaction i2cTransaction;*/
/* Call driver init functions */
macUser0Cfg[0].pAssertFP = macHalAssertHandler;
#endif
macUser0Cfg[0].pSetRE = Board_Palna_initialize;
#endif
Initialization for board related stuff such as LEDs
following TI-RTOS convention
PIN_init(BoardGpioInitTable);
/* If FEATURE_BLE_OAD is enabled, look for a left button
* press on reset. This indicates to revert to some
* factory image
if(!PIN_getInputValue(Board_PIN_BUTTON0))
OAD_markSwitch();
#if defined(POWER_MEAS)
/* Disable external flash for power measurements */
Board_shutDownExtFlash();
#endif
SPI_init();
#endif
#ifndef POWER_MEAS
/* Enable System_printf(..) UART output */
UART_init();
UART_Params_init(&uartParams);
#ifndef TIMAC_AGAMA_FPGA
uartParams.baudRate = 115200;
#else
uartParams.baudRate = 460800;
#endif
UartPrintf_init(UART_open(Board_UART0, &uartParams));
#endif /* BOARD_DISPLAY_USE_UART */
#endif
_macTaskId = macTaskInit(macUser0Cfg);
#endif
/* Configure task. */
Task_Params_init(&taskParams);
taskParams.stack = appTaskStack;
taskParams.stackSize = APP_TASK_STACK_SIZE;
taskParams.priority = APP_TASK_PRIORITY;
Task_construct(&appTask, appTaskFxn, &taskParams, NULL);
#ifdef DEBUG_SW_TRACE
IOCPortConfigureSet(IOID_8, IOC_PORT_RFC_TRC, IOC_STD_OUTPUT
| IOC_CURRENT_4MA | IOC_SLEW_ENABLE);
#endif /* DEBUG_SW_TRACE */
/* I2C_Params_init(&i2cParams);
i2cParams.bitRate = I2C_400kHz;
i2c = I2C_open(Board_I2C_TMP, &i2cParams);
if (i2c == NULL) {
LCD_WRITE_STRING("Error Initializing I2C\n", 6);
while (1);
else {
LCD_WRITE_STRING("I2C Initialized!\n", 6);
BIOS_start(); /* enable interrupts and start SYS/BIOS */
return (0);
