Part Number: CC3200-LAUNCHXL
Other Parts Discussed in Thread: UNIFLASH, ENERGIA,
My CC3200-Launchpad device is not getting connected to Code composer studio, Energia or Uniflash. Specified the Uniflash log below. Could anyone help me to resolve the issue.
[12:27:07] Begin GetVersion operation.
[12:27:08] INFO: > Executing Operation: Connect
[12:27:10] INFO: setting break signal
[12:27:11] INFO: detecting FTDI for device reset
[12:27:26] ERROR: ---reading ACK signal failed---
[12:27:26] WARNING: ---seting break signal to false failed---
[12:27:28] INFO: setting break signal
[12:27:29] INFO: detecting FTDI for device reset
[12:27:45] ERROR: ---reading ACK signal failed---
[12:27:45] WARNING: ---seting break signal to false failed---
[12:27:47] INFO: setting break signal
[12:27:48] INFO: detecting FTDI for device reset
[12:28:03] ERROR: ---reading ACK signal failed---
[12:28:03] WARNING: ---seting break signal to false failed---
[12:28:05] INFO: setting break signal
[12:28:06] INFO: detecting FTDI for device reset
[12:28:22] ERROR: ---reading ACK signal failed---
[12:28:22] WARNING: ---seting break signal to false failed---
[12:28:22] FATAL: --- Can't connect to device !! ---
[12:28:22] FATAL: Error connecting to the device. Please check your COM port settings. Error code: -3
[12:28:22] INFO: > Executing Operation: Disconnect
[12:28:22] Operation GetVersion returned.
[12:30:05] Begin GetVersion operation.
[12:30:05] INFO: > Executing Operation: Connect
[12:30:07] INFO: setting break signal
[12:30:08] INFO: detecting FTDI for device reset
[12:30:24] ERROR: ---reading ACK signal failed---
[12:30:24] WARNING: ---seting break signal to false failed---
[12:30:26] INFO: setting break signal
[12:30:27] INFO: detecting FTDI for device reset
[12:30:42] ERROR: ---reading ACK signal failed---
[12:30:42] WARNING: ---seting break signal to false failed---
[12:30:44] INFO: setting break signal
[12:30:45] INFO: detecting FTDI for device reset
[12:31:01] ERROR: ---reading ACK signal failed---
[12:31:01] WARNING: ---seting break signal to false failed---
[12:31:03] INFO: setting break signal
[12:31:04] INFO: detecting FTDI for device reset
[12:31:19] ERROR: ---reading ACK signal failed---
[12:31:19] WARNING: ---seting break signal to false failed---
[12:31:19] FATAL: --- Can't connect to device !! ---
[12:31:19] FATAL: Error connecting to the device. Please check your COM port settings. Error code: -3
[12:31:19] INFO: > Executing Operation: Disconnect
[12:31:19] Operation GetVersion returned.
