CCS/TM4C1294NCPDT: Disable implicit function declarations
Part Number: TM4C1294NCPDT
Other Parts Discussed in Thread: CODECOMPOSER,
I wish the compiler no longer accept implicit function declarations, because of its potential to produce some ugly bugs. That is I want it to be upgraded to error. Is there an option for that in CCS 9?
  • Hi Andrey,
    You can use the --diag_error option to escalate a diagnostic id to an error. The diagnostic ID for implicit function declarations is 225. I believe the default behavior is to treat id 225 as a warning so don't forget to remove it from the --diag_warning option if it is there. It should look like the below:
    ki
  • I did what you've shown, so the window looks the same, but I still get warning instead of error about impliit declarations. Also there is a still an explicit
    --diag_warning=225
    in compile options.
  • Did you remove it from the --diag_warning list as mentioned in my previous post? It is added there by default so you have to explicitly remove it from there.
  • Please provide a screenshot and also all the build output from the build console (you can cut and paste to a text file and attach the file)
  • It was already  (and still is) empty.
  • Can you provide the full build output?
  • In this example I misspelled a function name, and it still built.
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/Zedboard.c"
    Invoking: ARM Compiler
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Zedboard_conn_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="proc_sys/Zedboard.d_raw" --obj_directory="proc_sys" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/Zedboard.c"
    "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/Zedboard.c", line 85: warning #70-D: integer conversion resulted in truncation
    "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/Zedboard.c", line 123: warning #225-D: function "waitForposEdge" declared implicitly
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/Zedboard.c"
    I notice, that my window is slightly different from yours, so you must be using a different version of CCS. I have
    Version: 9.0.1.00004
  • Is this all the messages in the console? I'm looking for everything - every message from start to finish for the build.
    I am using the same version. The difference is that you were using the Linux version and I am on Windows.
  • it is  very long because I included TivaWare drivers in the project. But since you ask here it is
    **** Build of configuration Debug for project MC_Output_test ****
    /home/aluzhanskij/ti/ccs901/ccs/utils/bin/gmake -k -j 4 all -O
    Building file: "../tm4c1294ncpdt_startup_ccs.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="tm4c1294ncpdt_startup_ccs.d_raw" "../tm4c1294ncpdt_startup_ccs.c"
    Finished building: "../tm4c1294ncpdt_startup_ccs.c"
    Building file: "../main.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="main.d_raw" "../main.c"
    "../main.c", line 25: warning #112-D: statement is unreachable
    Finished building: "../main.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/comp.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/comp.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/comp.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/comp.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/aes.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/aes.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/aes.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/aes.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/cpu.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/cpu.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/cpu.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/cpu.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/crc.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/crc.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/crc.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/crc.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/adc.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/adc.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/adc.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/adc.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/des.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/des.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/des.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/des.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/can.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/can.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/can.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/can.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/eeprom.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/eeprom.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/eeprom.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/eeprom.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/fpu.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/fpu.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/fpu.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/fpu.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/flash.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/flash.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/flash.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/flash.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/epi.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/epi.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/epi.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/epi.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/emac.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/emac.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/emac.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/emac.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/i2c.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/i2c.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/i2c.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/i2c.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/hibernate.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/hibernate.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/hibernate.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/hibernate.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/mpu.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/mpu.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/mpu.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/mpu.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/gpio.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/gpio.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/gpio.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/gpio.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/interrupt.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/interrupt.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/interrupt.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/interrupt.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/onewire.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/onewire.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/onewire.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/onewire.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/lcd.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/lcd.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/lcd.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/lcd.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/qei.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/qei.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/qei.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/qei.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/pwm.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/pwm.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/pwm.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/pwm.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/ssi.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/ssi.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/ssi.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/ssi.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sw_crc.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/sw_crc.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sw_crc.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sw_crc.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/shamd5.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/shamd5.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/shamd5.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/shamd5.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sysexc.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/sysexc.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sysexc.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sysexc.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/systick.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/systick.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/systick.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/systick.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/udma.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/udma.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/udma.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/udma.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/timer.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/timer.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/timer.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/timer.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/uart.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/uart.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/uart.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/uart.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sysctl.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/sysctl.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sysctl.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/sysctl.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/watchdog.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/watchdog.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/watchdog.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/watchdog.c"
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/clock_gen.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="proc_sys/clock_gen.d_raw" --obj_directory="proc_sys" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/clock_gen.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/clock_gen.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="proc_sys/Zedboard.d_raw" --obj_directory="proc_sys" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/Zedboard.c"
    "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib/Zedboard.c", line 87: warning #225-D: function "waitForposEdge" declared implicitly
    Building file: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/usb.c"
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/proc_sys_lib" --include_path="/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/MC_Output_test" --include_path="/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi --preproc_with_compile --preproc_dependency="drivers/usb.d_raw" --obj_directory="drivers" "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/usb.c"
    Finished building: "/media/aluzhanskij/1792-47C5/Masterarbeit/CodeComposer/TivaWare/driverlib/usb.c"
    Building target: "MC_Output_test.out"
    Invoking: ARM Linker
    "/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --define=ccs="ccs" --define=PART_TM4C1294NCPDT -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --abi=eabi -z -m"MC_Output_test.map" --heap_size=512 --stack_size=512 -i"/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/lib" -i"/home/aluzhanskij/ti/ccs901/ccs/tools/compiler/ti-cgt-arm_18.12.1.LTS/include" --reread_libs --diag_error=225 --diag_wrap=off --display_error_number --warn_sections --xml_link_info="MC_Output_test_linkInfo.xml" --rom_model -o "MC_Output_test.out" "./main.obj" "./tm4c1294ncpdt_startup_ccs.obj" "./drivers/adc.obj" "./drivers/aes.obj" "./drivers/can.obj" "./drivers/comp.obj" "./drivers/cpu.obj" "./drivers/crc.obj" "./drivers/des.obj" "./drivers/eeprom.obj" "./drivers/emac.obj" "./drivers/epi.obj" "./drivers/flash.obj" "./drivers/fpu.obj" "./drivers/gpio.obj" "./drivers/hibernate.obj" "./drivers/i2c.obj" "./drivers/interrupt.obj" "./drivers/lcd.obj" "./drivers/mpu.obj" "./drivers/onewire.obj" "./drivers/pwm.obj" "./drivers/qei.obj" "./drivers/shamd5.obj" "./drivers/ssi.obj" "./drivers/sw_crc.obj" "./drivers/sysctl.obj" "./drivers/sysexc.obj" "./drivers/systick.obj" "./drivers/timer.obj" "./drivers/uart.obj" "./drivers/udma.obj" "./drivers/usb.obj" "./drivers/watchdog.obj" "./proc_sys/Zedboard.obj" "./proc_sys/clock_gen.obj" "../tm4c1294ncpdt.cmd" -llibc.a
    <Linking>
    undefined first referenced
    symbol in file
    waitForposEdge ./proc_sys/Zedboard.obj
    error #10234-D: unresolved symbols remain
    error #10010: errors encountered during linking; "MC_Output_test.out" not built
    >> Compilation failure
    makefile:178: recipe for target 'MC_Output_test.out' failed
    gmake[1]: *** [MC_Output_test.out] Error 1
    gmake: *** [all] Error 2
    makefile:174: recipe for target 'all' failed
    **** Build Finished ****
  • Thanks. Originally I thought it might be an issue with file specific options. But based on the output, it applies to every file. Not sure what is happening... it looks like the setting was not applied. Can you provide the three project metadata files for your project (.project, .cproject, .ccsproject)?
    ki
  • Thanks. When I import the metadata files and check the build options, I still see:
    It looks like the changes you tried to apply before did not get saved. Can you try applying them again?
  • Yes, I suddenly able to change the setting. The CCS probably lost connection between settings in memory and on the disk, but I believe It may have helped I restarted the CCS.
