Linux: TDA2 OpenVX TIDL OD ### XDC ASSERT - ERROR CALLBACK START ###
Tool/software: Linux
SDK:PROCESSOR_SDK_VISION_03_07_00_00
run on TDA2xx
MAKECONFIG?=tda2xx_evm_linux_all
OPENVX_INCLUDE=yes
I check the folder, and download the OpenVX TIDL Object Detection.
And got error,
Output showed the logo and some icons, but it didn't show image of video and result.
[HOST] [HOST ] OPENVX Usecases
[HOST] [HOST ] ----------------------------
[HOST] [HOST ] 1: OpenVX v1.1 Conformance Test
[HOST] [HOST ] 2: OpenVX Tutorials
[HOST] [HOST ] 3: OpenVX TIDL Object Classification
[HOST] [HOST ] 4: OpenVX TIDL Object Detection
[HOST] [HOST ]
[HOST] [HOST ] x: Exit
[HOST] [HOST ]
[HOST] [HOST ] Enter Choice:
[HOST] [HOST ]
4
[HOST] [HOST ] 690.590861 s:
[HOST] [HOST ] 690.609040 s: IPC_OUT_0 : Create in progress !!!
[HOST] [HOST ] 690.609101 s: IPC_OUT_0 : Create Done !!!
[HOST] [IPU2 ] 690.609253 s: IPC_IN_0 : Create in progress !!!
[HOST] [IPU2 ] 690.610382 s: IPC_IN_0 : Create Done !!!
[HOST] [IPU2 ] 690.610839 s: DECODE: Create in progress ... !!!
[HOST] [IPU2 ] 690.856890 s: DECODE: Creating CH0 of 768 x 320 [1] [0],target bitrate = 10000 Kbps ...
[HOST] [IPU2 ] 690.857774 s: DECODE: All CH Create ... DONE !!!
[HOST] [IPU2 ] 690.859635 s: DECODE: Create ... DONE !!!
[HOST] [IPU2 ] 690.860031 s: VPE: Create in progress !!!
[HOST] [DSP1 ] 690.953394 s: IPC_IN_0 : Create in progress !!!
[HOST] [DSP1 ] 690.953913 s: IPC_IN_0 : Create Done !!!
[HOST] [DSP1 ] 690.954126 s: ALGORITHM: Create in progress (algId = 40) !!!
[HOST] [IPU2 ] 690.950741 s: VPE: Loading Down-scaling Co-effs
[HOST] [IPU2 ] 690.950985 s: VPE: Co-effs Loading ... DONE !!!
[HOST] [IPU2 ] 690.951198 s: VPE: Create Done !!!
[HOST] [IPU2 ] 690.952723 s: IPC_OUT_0 : Create in progress !!!
[HOST] [IPU2 ] 690.953089 s: IPC_OUT_0 : Create Done !!!
[HOST] [HOST ] 690.964405 s: IPC_IN_0 : Create in progress !!!
[HOST] [HOST ] 690.964710 s: IPC_IN_0 : Create Done !!!
[HOST] [HOST ] 690.964771 s: ALGORITHM: Create in progress (algId = 14) !!!
[HOST] [DSP1 ] 690.963856 s: UTILS: DMA: Allocated CH (TCC) = 56 (56)
[HOST] [DSP1 ] 690.963917 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 56 (0x43305200)
[HOST] [DSP1 ] 690.963948 s: ALGORITHM: Create Done (algId = 40) !!!
[HOST] [DSP1 ] 690.964161 s: IPC_OUT_0 : Create in progress !!!
[HOST] [DSP1 ] 690.964253 s: IPC_OUT_0 : Create Done !!!
[HOST] [HOST ] 691.210699 s: Creating OpenVx graph
[HOST] [HOST ] 691.215823 s: Verifying OpenVx graph
[HOST] [HOST ] 693.084761 s: ALGORITHM: Create Done (algId = 14) !!!
[HOST] [HOST ] 693.084822 s: IPC_OUT_1 : Create in progress !!!
[HOST] [HOST ] 693.084853 s: IPC_OUT_1 : Create Done !!!
[HOST] [IPU2 ] 693.084975 s: IPC_IN_1 : Create in progress !!!
[HOST] [IPU2 ] 693.086134 s: IPC_IN_1 : Create Done !!!
[HOST] [IPU2 ] 693.088025 s: ALGORITHM: Create in progress (algId = 1) !!!
[HOST] [IPU2 ] 693.089184 s: UTILS: DMA: Allocated CH (TCC) = 32 (32)
[HOST] [IPU2 ] 693.089306 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 32 (0x63304800)
[HOST] [IPU2 ] 693.105929 s: ALGORITHM: Create Done (algId = 1) !!!
[HOST] [IPU2 ] 693.106356 s: DISPLAY: Create in progress !!!
[HOST] [IPU2 ] 693.106966 s: DISPLAY: Create Done !!!
[HOST] [IPU2 ] 693.107362 s: GRPXSRC: Create in progress !!!
[HOST] [IPU2 ] 693.620020 s: GRPXSRC: Create Done !!!
[HOST] [IPU2 ] 693.620508 s: DISPLAY: Create in progress !!!
[HOST] [IPU2 ] 693.621027 s: DISPLAY: Create Done !!!
[HOST] [DSP1 ] 693.721679 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [DSP1 ] 693.721710 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[HOST] [DSP1 ] 693.721740 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 511864 B (499 KB)
[HOST] [DSP2 ] 693.721984 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [DSP2 ] 693.722015 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[HOST] [DSP2 ] 693.722045 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 515976 B (503 KB)
[HOST] [EVE1 ] 693.722534 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [EVE1 ] 693.723906 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1328 B (1 KB)
[HOST] [EVE1 ] 693.725980 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254120 B (248 KB)
[HOST] [EVE2 ] 693.728603 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [EVE2 ] 693.729884 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE2 ] 693.732019 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254120 B (248 KB)
[HOST] [EVE3 ] 693.734703 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [EVE3 ] 693.735954 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE3 ] 693.738089 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254120 B (248 KB)
[HOST] [EVE4 ] 693.740651 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [EVE4 ] 693.741902 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE4 ] 693.744098 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254120 B (248 KB)
[HOST] [HOST ] 693.755871 s:
[HOST] [HOST ]
[HOST] [HOST ] ====================
[HOST] [HOST ] Chains Run-time Menu
[HOST] [HOST ]
[HOST] [HOST ] 0: Stop Chain
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ] p: Print Performance Statistics
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [IPU2 ] 693.746446 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [IPU2 ] 693.746629 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 244168 B (238 KB)
[HOST] [IPU2 ] 693.746782 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[HOST] [IPU2 ] 693.746934 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 237309440 B (226 MB)
[HOST] [IPU2 ] 693.747117 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 851840 B (0 MB)
[HOST] [IPU2 ] 693.747575 s: DISPLAY: Start in progress !!!
[HOST] [IPU2 ] 693.747666 s: DISPLAY: Start Done !!!
[HOST] [IPU2 ] 693.750015 s: DISPLAY: Start in progress !!!
[HOST] [IPU2 ] 693.750106 s: DISPLAY: Start Done !!!
[HOST] [IPU2 ] 694.180961 s:
[HOST] [IPU2 ] 694.181022 s: ### XDC ASSERT - ERROR CALLBACK START ###
[HOST] [IPU2 ] 694.181083 s:
[HOST] [IPU2 ] 694.181235 s: E_hardFault: FORCED
[HOST] [IPU2 ] 694.181296 s:
[HOST] [IPU2 ] 694.181327 s: ### XDC ASSERT - ERROR CALLBACK END ###
[HOST] [IPU2 ] 694.181418 s:
[HOST] [IPU2 ] 694.181632 s:
[HOST] [IPU2 ] 694.181662 s: ### XDC ASSERT - ERROR CALLBACK START ###
[HOST] [IPU2 ] 694.181754 s:
[HOST] [IPU2 ] 694.181876 s: E_busFault: PRECISERR: Immediate Bus Fault, exact addr known, address: 00714bc4
[HOST] [IPU2 ] 694.181967 s:
[HOST] [IPU2 ] 694.181998 s: ### XDC ASSERT - ERROR CALLBACK END ###
[HOST] [IPU2 ] 694.182089 s:
what did it cause this error ?
Ting
