CCS/CC3220S-LAUNCHXL: Build Errors
Part Number: CC3220S-LAUNCHXL
Other Parts Discussed in Thread: CC3220S
Trying to start a project from the SDK I have encoutered a few build problems. Which are visible in the picture below. I have already re-installed Code Composer Studio and have installed in a path without whitespaces. I hope you can help me.
Kind regards,
Erwin
  • Erwin,
    Which version of CCS are you using and how did you import the project?
    Could you right-click on the tirtos_builds_CC3220S_LAUNCHXL_release_ccs project in the Project Explorer, select Rebuild Project, then save the build log to a text file (as described here) and attach the file here for us to look at?
  • Dear AartiG,
    My apologies. I have already found the issue. Apparently the problem was that not only Code Composer Studio has to be installed in a folder without whitespaces. But the folder where you install the SDK's also has to be without whitespaces.
    Thank you for your time.
    Erwin
