Other Parts Discussed in Thread: DRV8323, CONTROLSUITE
My work is designing the HVBLDC driver circuit .
I use controller F28035 to drive BOOSTXL-DRV8323RH and my design circuit .
CCS code name : HVBLDC_sensored level 5
My problem is motor will be stop when SpeedLoopflag turn to 1 ,and then pid1_spd.Out value will be "16777216"
Before motor stopping , it will spin fast shortly.
This situation sometimes occur on BOOSTXL-DRV8323RH ,and happen my driver circuit every time.
I use CCS code name : BLDC_sensored level 6 also . motor can spin but use high current
Can give me suggestion to solve this problem?or can you recommend driver IC similar mine .
My driver ic is Si8273 .
