Part Number: LAUNCHXL-F28379D
Other Parts Discussed in Thread: TI-CGT, CONTROLSUITE
I am using a F28379D launchpad and Embeeded Coder Toolbox on MATLAB. I have the below error message when I compil my code :
Simulation 6 4 1 Clear
09:28 AM Elapsed: 1:24 min
### Starting build procedure for model: Model_0D
### Generating code and artifacts to 'Model specific' folder structure
Code Generation 4 4
Elapsed: 1:22 min
### Generating code into build folder: C:\Users\TD258912\Documents\codes\trunk\MePHYSTO\Projets\Syst_PEMFC\Emulateur_0D\Model_0D_ert_rtw
Warning: File 'codedescriptor.dmr' not found.
### Invoking Target Language Compiler on Model_0D.rtw
### Using System Target File: C:\Program Files\MATLAB\R2019a\rtw\c\ert\ert.tlc
### Loading TLC function libraries
### Initial pass through model to cache user defined code
### Caching model source code
### Writing header file Model_0D_types.h
### Writing header file Model_0D.h
### Writing header file rtwtypes.h
### Writing header file multiword_types.h
### Writing source file Model_0D.c
### Writing header file Model_0D_private.h
### Writing source file Model_0D_data.c
### Writing header file rtmodel.h
### Writing header file rt_nonfinite.h
### Writing source file rt_nonfinite.c
### Writing header file rtGetInf.h
### Writing source file rtGetInf.c
### Writing header file rtGetNaN.h
### Writing source file rtGetNaN.c
### Writing source file ert_main.c
### TLC code generation complete.
### Generating TLC interface API.
### Creating data type transition file Model_0D_dt.h
.### Evaluating PostCodeGenCommand specified in the model
Code Composer Studio Project 1
Elapsed: 0.586 sec
### Creating CCS Project at : C:\Users\TD258912\Documents\codes\trunk\MePHYSTO\Projets\Syst_PEMFC\Emulateur_0D\Model_0D_ert_rtw\CCS_Project
### CCS project created successfully Open project in Code Composer Studio.
### Using toolchain: Texas Instruments Code Composer Studio (C2000)
### Creating 'C:\Users\TD258912\Documents\codes\trunk\MePHYSTO\Projets\Syst_PEMFC\Emulateur_0D\Model_0D_ert_rtw\Model_0D.mk' ...
### Building 'Model_0D': "C:\PROGRA~1\MATLAB\R2019a\bin\win64\gmake" -B -f Model_0D.mk all
C:\Users\TD258912\Documents\codes\trunk\MePHYSTO\Projets\Syst_PEMFC\Emulateur_0D\Model_0D_ert_rtw>cd .
C:\Users\TD258912\Documents\codes\trunk\MePHYSTO\Projets\Syst_PEMFC\Emulateur_0D\Model_0D_ert_rtw>if "" == "" ("C:\PROGRA~1\MATLAB\R2019a\bin\win64\gmake" -B -f Model_0D.mk all ) else ("C:\PROGRA~1\MATLAB\R2019a\bin\win64\gmake" -B -f Model_0D.mk )
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rt_matrx.obj C:/PROGRA~1/MATLAB/R2019a/rtw/c/src/rt_matrx.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rt_printf.obj C:/PROGRA~1/MATLAB/R2019a/rtw/c/src/rt_printf.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=MW_c28xx_board.obj MW_c28xx_board.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=MW_c28xx_csl.obj MW_c28xx_csl.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=Model_0D.obj Model_0D.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=Model_0D_data.obj Model_0D_data.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rtGetInf.obj rtGetInf.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rtGetNaN.obj rtGetNaN.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rt_nonfinite.obj rt_nonfinite.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=f_U_model_0D_Shocapik.obj C:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Lib_general/Fonctions/S-Fonctions/f_U_model_0D_Shocapik.c
"C:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Lib_general/Fonctions/S-Fonctions/f_U_model_0D_Shocapik.c", line 102: warning: argument of type "real_T *" is incompatible with parameter of type "double *"
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=c2837xDBoard_Realtime_Support.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/c2837xDBoard_Realtime_Support.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_CpuTimers.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CpuTimers.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_DefaultISR.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_DefaultISR.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_GlobalVariableDefs.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_headers/source/F2837xD_GlobalVariableDefs.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_PieCtrl.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieCtrl.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_PieVect.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_PieVect.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_SysCtrl.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_SysCtrl.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 -s -v28 -ml --float_support=fpu32 --output_file=F2837xD_usDelay.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_usDelay.asm
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 -s -v28 -ml --float_support=fpu32 --output_file=F2837xD_CodeStartBranch.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_CodeStartBranch.asm
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Dma.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Dma.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Adc.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Adc.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Gpio.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Gpio.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Ipc_Driver_Lite.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Ipc_Driver_Lite.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=F2837xD_Emif.obj C:/ti/controlSUITE/device_support/F2837xD/v190/F2837xD_common/source/F2837xD_Emif.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=profiler_Support.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/profiler_Support.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=MW_c28xGPIO.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/MW_c28xGPIO.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=c2837xDSchedulerTimer0.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/c2837xDSchedulerTimer0.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=ext_svr_c2000.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c
"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include/assert.h", line 80: warning: incompatible redefinition of macro "assert" (declared at line 23 of "C:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common/updown_util.h")
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 145: warning: incompatible redefinition of macro "assert" (declared at line 80 of "C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include/assert.h")
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 248: warning: argument of type "char *" is incompatible with parameter of type "const uint8_T *"
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 1278: warning: argument of type "const uint16_T *" is incompatible with parameter of type "const char *"
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 1282: warning: argument of type "const uint16_T *" is incompatible with parameter of type "const char *"
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 1287: warning: argument of type "const uint16_T *" is incompatible with parameter of type "const char *"
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 1301: warning: argument of type "const uint16_T *" is incompatible with parameter of type "const char *"
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 1304: warning: argument of type "const uint16_T *" is incompatible with parameter of type "const char *"
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_svr_c2000.c", line 315: warning: function "GetPkt" was declared but never referenced
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=updown_c2000.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/updown_c2000.c
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/updown_c2000.c", line 26: warning: incompatible redefinition of macro "assert" (declared at line 80 of "C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include/assert.h")
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=ext_work_c2000.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/ext_work_c2000.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rtiostream_utils_c2000.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_utils_c2000.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rtiostream_interface_c2000.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_interface_c2000.c
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_interface_c2000.c", line 195: warning: type qualifier is meaningless on cast type
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_interface_c2000.c", line 242: warning: function "rtIOStreamBlockingSend8Bits" declared implicitly
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_interface_c2000.c", line 243: warning: type qualifier is meaningless on cast type
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=rtiostream_serial_c28x_ext.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_serial_c28x_ext.c
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_serial_c28x_ext.c", line 198: warning: argument of type "size_t *" is incompatible with parameter of type "int *"
"C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/rtiostream_serial_c28x_ext.c", line 472: warning: variable "byte_select" was declared but never referenced
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=datamodify.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/datamodify.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=daemon_checksum.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/shared/externalmode_daemon/src/daemon_checksum.c
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 --compile_only --large_memory_model --silicon_version=28 --define="LARGE_MODEL" -i"/~SupportFiles/DSP280x_headers" -i"/~SupportFiles/DSP280x_headers/include" -i"C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/include" -g --define="EXTMODE_DISABLEPRINTF" -v28 --float_support=fpu32 -ml -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -DON_TARGET_WAIT_FOR_START=0 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=1 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DEXT_MODE=1 -DINTEGER_CODE=0 -DMT=0 -DON_TARGET_WAIT_FOR_START=0 -DRT -DUSE_RTMODEL -DERT -DTID01EQ=1 -DDAEMON_MODE=1 -DMW_PIL_SCIFIFOLEN=16 -DF2837X_REG_FORMAT -DMW_F2837XD -DSTACK_SIZE=512 -DF28379D -DCPU1 -DBOOT_FROM_FLASH=1 -DMODEL=Model_0D -DNUMST=2 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D -IC:/Users/TD258912/Documents/codes/trunk/MePHYSTO/Projets/Syst_PEMFC/Emulateur_0D/Model_0D_ert_rtw -IC:/PROGRA~1/MATLAB/R2019a/extern/include -IC:/PROGRA~1/MATLAB/R2019a/simulink/include -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/src/ext_mode/common -IC:/PROGRA~1/MATLAB/R2019a/rtw/c/ert -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src -IC:/PROGRA~1/MATLAB/R2019a/toolbox/coder/rtiostream/src/utils -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/inc -IC:/PROGRA~1/MATLAB/R2019a/toolbox/shared/can/src/scanutil -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/SUPPOR~1/tic2000/src -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~4/include -IC:/ti/CONTRO~1/DEVICE~1/F2837xD/v190/F2837X~1 -IC:/PROGRA~1/MATLAB/R2019a/toolbox/rtw/targets/common/can/blocks/tlc_c -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/toolbox/target/shared/EXTERN~1/include --output_file=ert_main.obj ert_main.c
"### Creating standalone executable "../Model_0D.out" ..."
C:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/bin/cl2000 -z -IC:/PROGRA~3/MATLAB/SUPPOR~1/R2019a/3P778C~1.INS/TIC200~1.INS/TI-CGT~1.LTS/lib --stack_size=512 --warn_sections --heap_size=1024 --reread_libs --rom_model -m"Model_0D.map" -l"rts2800_fpu32.lib" --define F28379D --define CPU1 --define BOOT_FROM_FLASH=1 --define BOOT_USING_BL=0 --output_file=../Model_0D.out rt_matrx.obj rt_printf.obj MW_c28xx_board.obj MW_c28xx_csl.obj Model_0D.obj Model_0D_data.obj rtGetInf.obj rtGetNaN.obj rt_nonfinite.obj f_U_model_0D_Shocapik.obj c2837xDBoard_Realtime_Support.obj F2837xD_CpuTimers.obj F2837xD_DefaultISR.obj F2837xD_GlobalVariableDefs.obj F2837xD_PieCtrl.obj F2837xD_PieVect.obj F2837xD_SysCtrl.obj F2837xD_usDelay.obj F2837xD_CodeStartBranch.obj F2837xD_Dma.obj F2837xD_Adc.obj F2837xD_Gpio.obj F2837xD_Ipc_Driver_Lite.obj F2837xD_Emif.obj profiler_Support.obj MW_c28xGPIO.obj c2837xDSchedulerTimer0.obj ext_svr_c2000.obj updown_c2000.obj ext_work_c2000.obj rtiostream_utils_c2000.obj rtiostream_interface_c2000.obj rtiostream_serial_c28x_ext.obj datamodify.obj daemon_checksum.obj ert_main.obj C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/rtlib/IQmath_fpu32.lib C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/c2837xDPeripherals.cmd C:/ProgramData/MATLAB/SupportPackages/R2019a/toolbox/target/supportpackages/tic2000/src/c28377D.cmd
<Linking>
warning: creating output section ".cio" without a SECTIONS specification
undefined first referenced
symbol in file
U_pile_model_0D f_U_model_0D_Shocapik.obj
error: unresolved symbols remain
error: errors encountered during linking; "../Model_0D.out" not built
>> Compilation failure
gmake: *** [../Model_0D.out] Error 1
C:\Users\TD258912\Documents\codes\trunk\MePHYSTO\Projets\Syst_PEMFC\Emulateur_0D\Model_0D_ert_rtw>echo The make command returned an error of 2
C:\Users\TD258912\Documents\codes\trunk\MePHYSTO\Projets\Syst_PEMFC\Emulateur_0D\Model_0D_ert_rtw>exit 1
### Creating HTML report file Model_0D_codegen_rpt.html
### Build procedure for model: 'Model_0D' aborted due to an error.
Error(s) encountered while building "Model_0D":
### Failed to generate all binary outputs.
Component:Simulink | Category:Model error
I investigated the issue with MathWorks Technical Support. According to them, the issue seems related to TICCS and its routine to compile the S-function. In particular, the compilation of the intermediate objects is successful and the error appears at the linking phase, when the compiled S-function is created, to be used by Simulink in a later stage. Up to now, it seems that no issues are encountered at Simulink side.
Thank you in advance for your help.
Timothée
